walter kandetzki Samba Member
Joined: June 02, 2003 Posts: 783 Location: Dillwyn, VA
Posted: Fri Jan 13, 2012 9:14 pm Post subject: master series |
hi folks,im doing the bugs chassis in master series.i have the silver rust sealer and i have some black.i used a wire wheel and cleaned the frame head really clean.do i just lay the silver right on it or will i need to do anything before i do?also whats the best type of brush?just a regular paint brush?thanks |
Krmnnghia Samba Member
Joined: March 28, 2005 Posts: 797 Location: Michigan, Land of salty roads!
Posted: Sat Jan 14, 2012 7:23 am Post subject: |
Yah you can lay it right down on the wired surface. I used a foam roller and a regular paint brush for the crevices. That stuff goes on like a dream.
Love this stuff...
from
to
beetlenut Samba Member
Posted: Sat Jan 14, 2012 10:56 am Post subject: |
For the record, it would help to go over the clean bright metal you just wire-wheeled with some sand paper, maybe 100 grit or so, before you apply the Master Series silver. The silver likes to have a surface with some bite to it, to better hang on to. _________________ scrapyards are for quitters
Wetstuff wrote: |
... I spend more time shaking it than directing it?! I get a pretty decent blast for 8sec. then have to shake it again. |
- Words to live by right there!
My 74 Super rebuild thread: http://www.thesamba.com/vw/forum/viewtopic.php?p=6507104#6507104 |
Posted: Sat Jan 14, 2012 11:11 am Post subject: |
i had my buddy who works for a bodyshop paint the beam in master series using the spray gun instead of brushing it.good stuff |
Posted: Sat Jan 14, 2012 5:24 pm Post subject: |
i got a small chip in the paint on the framhead while i was doing something and the rest of it peeled off..i dont think paint should peel.i layed on the silver stuff then i layed on the black after it dried.im trying to figure what i did wrong |
hpw Samba Member
Posted: Mon Jan 16, 2012 3:24 am Post subject: |
walter kandetzki wrote: |
beetlenut wrote: |
For the record, it would help to go over the clean bright metal you just wire-wheeled with some sand paper, maybe 100 grit or so, before you apply the Master Series silver. The silver likes to have a surface with some bite to it, to better hang on to. |
_________________ http://www.youtube.com/watch?v=3SLIzSCt_cg&list=FLIX26sGa8__1F1loczLPTtg&index=2 |
Vinnems Samba Member
Joined: December 23, 2008 Posts: 1181 Location: Simi Valley, CA
Posted: Mon Jan 16, 2012 9:30 am Post subject: |
Wire wheeling leaves a metal surface too smooth for paint. It polishes more than preps. Like the guy said before, you need to go over the smooth metal with some sandpaper. Just get some big sheets and go to town on your pans in every direction you can.
Loved Masterseries silver, the black not so much. |
GtiKyle Samba Member
Joined: March 27, 2008 Posts: 211 Location: Tacoma, WA
Posted: Mon Jan 16, 2012 12:15 pm Post subject: |
It came too thin. Took way to many coats to get good coverage. Next time I'll just use Rustoleum. Finished the rest of my suspension with it, looks great. The silver though I love, great sealer and primer in one. |
c21darrel Samba Member
Joined: January 22, 2009 Posts: 7579 Location: San Dimas
Posted: Mon Jan 16, 2012 3:33 pm Post subject: |
I had great luck w/ MS and their chassis black, looks suprisingly good for foam brush and roller work. If I did it again I would get a cheap harbor freight gun and shoot it, would look completly professional. |
