sts9292 Samba Member
Posted: Sat Jan 14, 2012 11:38 am Post subject: What is this - buchered rods ? |
My mechanic opened the case of the engine to find the reason for the excesive crank play .... full story here in case you are bored .. http://www.thesamba.com/vw/forum/viewtopic.php?t=489822&highlight=
but I was surprised to see the piston rods. The engine is a stroker 2276cc and the case clearanced, but I have never seen rods like this. It appears to me that these are standard rods filed to fit the case. According to the PO who sold me this POC engine the rods are "clearanced, dynamically balanced and weight matched to 0.5g" ... Is this the normal way to clear the rods to fit the case for a stroker engine? Someone please comment ....
Case:
Case:
Rods:
[/img] |
earthquake Samba Member
Joined: January 10, 2008 Posts: 3984 Location: SANDY VALLEY, NEVADA
Posted: Sat Jan 14, 2012 11:54 am Post subject: |
The only tools the guy must own are a bench grinder, right angle grinder and a chain saw, I would take it back and throw it through his biggest window.
Casey _________________ 74 CLASS 11 LOOK-A-LIKE
69 DUNE BUGGY
79 INTERNATIONAL SCOUT II
05 SCION XB SERIES RELEASE 2[#437]
95 Chevy C3500 dually
98 Ford E150
Link to Kelly J. Nolte 3/20/53 - 11/6/08
https://time-zonelabs.blogspot.com/p/about-kelly.html
DEATH TO CHINGERS!
[From a military recruitment poster in the novel "The Stainless Steel Rat" By Harry Harrison] |
DarthWeber Samba Member
Joined: November 24, 2007 Posts: 7543 Location: Whittier,CA
Posted: Sat Jan 14, 2012 12:26 pm Post subject: |
Wow! Those rods are junk now. I wouldn't use them in a stock 1600 rebuild. What a hack job....on the case too! _________________
Mitey62 wrote: |
Swapped the Compufire for a Bosch blue and some points I had sitting around, started 1st crank. Took her out for a drive, pulls harder, more RPM, and runs smoother. I think I'll be sticking with points from now on. |
RockCrusher wrote: |
JB weld the case halves....that'll keep the fretting to a minimum. |
kielbasa Samba Member
Joined: November 28, 2007 Posts: 1443 Location: Garbage Grove, CA
Posted: Sat Jan 14, 2012 12:55 pm Post subject: |
Your pictures look funny, distorted, squished and stretched. I think the pics are making it look worse then they are. Looks like they did a fairly rough job on the rods, but if they took their time making sure they didn't heat the rods too much while grinding, you should be okay, they look really thin, but that could be the funky picture.
For the case, if everything clears, and nothing went through or super thin. You are fine. Go inthere with a air grinder, even a dremel and take off all the rough and Sharp corners. Relieves windage and thus more HP! While your at it, open the small Windows between each cylinder hole to allow 3 fingers to fit. That will help a lot. _________________ Gotta give my props to:
Wolfsburg Motorsports
Dubbers Toy Box
Jeff's VW Speed and Fab
4inbore.com
Kielbasa Industries |
modok Samba Member
Joined: October 30, 2009 Posts: 26781 Location: Colorado Springs
Posted: Sat Jan 14, 2012 2:27 pm Post subject: |
Rods are junk, bolt heads and caps too thin |
Posted: Sat Jan 14, 2012 2:38 pm Post subject: |
Pictures are fine. They are close-up/macro lens from my camera and I had to make them smaller to upload. I have the originals posted on the link below.
http://www.flickr.com/photos/sts9292/sets/72157628870034225/show/
But the questions has not been answered ... Is this the normal way to clear the rods to fit the case for a stroker engine? and a new question: should I just trash them and what should I get then?
Can someone post pictures of a good stroker crank / rod combo so I have a way to compare? |
Koyote Samba Member
Joined: March 31, 2008 Posts: 193 Location: Dijon, home of the mustard.France
Posted: Sat Jan 14, 2012 2:49 pm Post subject: |
sts9292 wrote: |
Pictures are fine. |
No. They are obviously not fine.
But it's enough to say about your rods, that the best place to store them is in the trash. _________________ 2276cc daily draw through. |
jbbugs Samba Member
Joined: September 16, 2002 Posts: 2152 Location: Behind the wheel
Posted: Sat Jan 14, 2012 2:51 pm Post subject: |
Looks like a motor from West Woast Core. _________________ Drag bus! http://www.youtube.com/watch?v=s2MOVmKdhX4
69 OG paint Transporter
73' Super Beetle Champcar Endurance Roadracer
Patina my ass, that's a Rust Bucket! |
speedyshift74 Samba Member
Posted: Sat Jan 14, 2012 3:01 pm Post subject: |
Not everyone out there that builds these engines has a Machine shop with CNC equiptment to Stroker Clearence the inside of a case. The method above looks like it was done with a milling machine and a few air files . So what!! I have witnessed people sit and clearence with a Dremal tool. If a pretty looking inside of the case is what you are looking for, then send it to a big name shop like CB or JayCee. If things clear when the crank and rods are dropped in, then things will be fine. As for the rods???? They need to be replaced. They were not clearenced with a very good technique. |
mark tucker Samba Member
Posted: Sat Jan 14, 2012 3:09 pm Post subject: |
kinda looks like some berger man rods I saw, but worse,a lot worse.trash them and get a new set of stroker rods.I do like the pics thou.kinda looks like an old tractor motor. |
t0ne321 Samba Member
Joined: February 06, 2006 Posts: 119 Location: San Diego, Ca.
Posted: Sat Jan 14, 2012 3:10 pm Post subject: |
Seeing as the bolts are grinded through, it looks like he installed the rods on the crank THEN grinded away with an angry beaver. This also probably means he didn't balance the assembly. If all he has to work with is an angle grinder, i doubt he had access to a dynamic balancer.
Sorry for your bad luck, I'm not surprised this engine didn't make it more than a mile. _________________ my 1965 sedan > yo mama. |
slalombuggy Samba Member
Posted: Sat Jan 14, 2012 4:05 pm Post subject: |
No this is not the way to clearance for a stroker crank. Yes, you can shave the rod caps and bolts down a bit, but not near this much. The rods are now junk. The case on the other hand looks to be done not too badly. Grab a die grinder and a flapper wheel and get rid of all the sharp edges and ridges.
brad |
Glenn Mr. 010
Joined: December 25, 2001 Posts: 76902 Location: Sneaking up behind you
Posted: Sat Jan 14, 2012 4:09 pm Post subject: |
Sure looks like Bernie Bergmann to me. _________________ Glenn
Member #1009
#BlueSquare |
Posted: Sat Jan 14, 2012 4:12 pm Post subject: |
sts9292 wrote: |
No, that is not the normal way to clearance stock rods. This isn't the greatest picture but this IS the proper way VW rods should be clearanced. These are rods done by Jose at DPR:
The two ridges on the bottom of the cap are not completely ground away nor is the head of the bolt butchered. Compare.
Personally, I would trash the rods you have and buy a set from DPR or a set of Rimco Super Rods. 5.4" Chinese CroMo rods are also a choice for you.
This is a good stroker crank, again DPR:
Mitey62 wrote: |
tstevenson Samba Member
Posted: Sat Jan 14, 2012 4:17 pm Post subject: |
Case and crank look fine. Rods do look very clearanced. Did you weigh them? Can you check if they are balanced? |
Jake Raby Samba Member
Joined: August 23, 2003 Posts: 7433 Location: Aircooled Heaven USA
Posted: Sat Jan 14, 2012 4:20 pm Post subject: |
I just threw up in my mouth. _________________ Jake Raby
Raby Engine Development
www.rabyenginedevelopment.com
"I've never given anyone Hell, I just told them the truth and they thought it was Hell" |
Posted: Sat Jan 14, 2012 4:23 pm Post subject: |
Ah !!! Making sense now. I do know much about this kind of suff but ... things like this raise my eyebrows ... specially when you suspect that the whole build is compromised based on my previous posts.
I just wish that the PO steps up to the plate and admits the fault and agrees refund my $$$$. .. \\ |
Posted: Sat Jan 14, 2012 4:27 pm Post subject: |
Hey Jake ... BTW I used one of your DTM (263) on this POC !! .. but anyway I still planning to put it to work. Great product ! |
Posted: Sat Jan 14, 2012 4:33 pm Post subject: |
Sad but typical. _________________ Jake Raby
Posted: Sat Jan 14, 2012 5:04 pm Post subject: |
Jake Raby wrote: |
Sad but typical. |
yup.all too comon.talked to a guy today ,he is on his 4th motor in 4 years,and it is mostly junk,1 big valve head,1 head hemi cut,leeks like the horizion drill rig.he says thats all you can get in new mexico, the same guy builds these killer motors for everybody out there..gladd Im in fl & do my own shit.. |
