88 westy automatic
flemming grove
flemming grove is offline
PostPosted: Sat Jan 14, 2012 8:14 pm    Post subject: 88 westy automatic Reply with quote
Been restoring an 88 westy that has been sitting for 7-8 years. After changing the entire fuel system, the engine is purring, the automatic transmission (after changing fluid and filter) only has 1st and reverse gear. Any suggestions to diagnose this problem?
How complicated would it be to convert this to a standard transmission, have access to a complete donor 1990 vanagon with a standard transmission?
rcook52459
rcook52459 is offline
PostPosted: Sat Jan 14, 2012 8:54 pm    Post subject: Reply with quote
did trans shift before fluid change?are you sure you put enough fluid back in?
85 westy tiico conversion.auto trans triumph TR250 1980 Suzuki GS1000l
Terry Kay
Banned
Terry Kay is offline
PostPosted: Sat Jan 14, 2012 10:44 pm    Post subject: Reply with quote
2-3 brake band actuating piston seals are dried up & leaking.
No-2-3 shift, just 1 & R
T.K.
flemming grove
PostPosted: Sun Jan 15, 2012 1:18 pm    Post subject: Reply with quote
the fluid level is right on the mark
The bus came from an estate sale so the history is unknown
I am going to check the governor next
many years ago on an Audi 4000 with a similiar problem I checked and fixed the governor
I will check that next on this one
many thanks for your reply
Terry Kay
Banned
PostPosted: Sun Jan 15, 2012 9:36 pm    Post subject: Reply with quote
You can do that.
Check the pistion O-Rings, & the 2nd gear brake band adjustment.
if either one of those two are outa wack--no 2-3 shifts.
T.K.
