revolution337 Samba Member
Joined: May 23, 2009 Posts: 372 Location: Pennsylvania
Posted: Thu Oct 22, 2020 4:22 am Post subject: Re: Custom Indicator Panel Insert |
Bumping this thread. Does anyone have a source for custom inserts today? I checked with small car performance, but they do not have the style I am looking for.
With my engine conversion, I repurposed the old EGR warning light in the lowermost right corner as my CEL. I was hoping to be able to find an insert that had the CEL logo in the lower right, and is blank in the lower left. (small car has one that has CEL the lower left and blank lower right, so opposite of what I am looking for). |
WestyKlaus Samba Member
Posted: Fri Mar 12, 2021 4:46 pm Post subject: Re: Custom Indicator Panel Insert |
revolution337 -
I might have some unfinished ones with check engine in the lower right and blank in the lower left.
Send me a PM if still interested. |
valvecovergasket Samba Member
Posted: Fri Mar 12, 2021 5:43 pm Post subject: Re: Custom Indicator Panel Insert |
revolution337 wrote: |
Theirs is just a sticker over a new backer piece. I bet using a sharp blade you could carefully swap sides for the lower logo before applying the sticker, and I bet you'd not notice once it was assembled _________________ MegaSquirt resource - SpitfireEFI.com
gone, but not forgotten: '83 tdi westy - swap thread |
dwdufour Samba Member
Posted: Wed Apr 21, 2021 7:09 pm Post subject: Re: Custom Indicator Panel Insert |
How the heck do you install these? |
syncrodoka Samba Member
Joined: December 27, 2005 Posts: 12006 Location: Santa Cruz, CA
Posted: Wed Apr 21, 2021 9:08 pm Post subject: Re: Custom Indicator Panel Insert |
dwdufour wrote: |
IIRC you just remove the factory indicator panel and replace it. I did this 10 years ago with one from westyklaus and it still looks fresh.
I went in for a smog today with my non KEP conversion. With my bar sticker the tech was happy to see the CEL in the stock position and functioning as it should. Passed the emissions test with flying colors |
uberaudi Samba Member
Joined: June 24, 2013 Posts: 503 Location: Hi-top Country
Posted: Wed Apr 21, 2021 9:20 pm Post subject: Re: Custom Indicator Panel Insert |
syncrodoka wrote: |
Brilliant! _________________ '84 Adventurewagen 1Z Tdi, '89 Tintop ABA, and a 86 Syncro tintop WBX. |
dbartisan Samba Member
Joined: January 24, 2010 Posts: 14 Location: Aliso Viejo CA
Posted: Thu Apr 22, 2021 11:17 am Post subject: Re: Custom Indicator Panel Insert |
Hello dwdufour,
I just added some images to the gallery if that helps.
VW Vanagon indicator panel from WestyKlaus
-Steve C.
Posted: Sat Apr 24, 2021 12:47 pm Post subject: Re: Custom Indicator Panel Insert |
Thanks for posting pictures of the install. I guess it's obvious if you've taken the cluster apart before. But I understand how it would be a mystery if you've never done so. Pictures explain the process very well. |
