awalls Samba Member
Joined: March 21, 2005 Posts: 128 Location: Beaverton, OR
Posted: Sat Jan 21, 2012 1:49 pm Post subject: Adding filter to single relief ? |
First off, I read a ton of post on this subject, and there are a ton of mixed answers. I'm looking to add some sort of oil filter to my stock 1600 with a single relief case. The reason is because its my daily driver and I would like the engine to last. Is there a way to do this with out pulling the engine? I also feel the need to let everyone know I'm still learing... Thanks _________________ '64 Bug
'58 Kombi |
modok Samba Member
Joined: October 30, 2009 Posts: 26785 Location: Colorado Springs
Posted: Sat Jan 21, 2012 1:50 pm Post subject: |
You can run a cb maxi-pump with filter.
IT would interfere with a bugpack merged header, but clears most stock and heater-box type exhaust systems |
Cusser Samba Member
Joined: October 02, 2006 Posts: 31362 Location: Hot Arizona
Posted: Sat Jan 21, 2012 5:27 pm Post subject: |
I've used the CB Maxi2 combined pump/filter for 30 years now on my 1835cc engine, I like it. You'll need to remove the crankshaft pulley and the oil pump with the engine in place, if you don't pull the engine. So you'd definitely need a decent oil pump puller, maybe even the special pulley puller as well, because of the limited space.
Does this "stock 1600" single relief engine have a flat camshaft or the later dished camshaft? That's important, as the oil pump shaft with the gear is longer for the dished-cam use (why there are two models of the Maxi2). Once the oil pump is pulled, this can be determined by looking, as to which type of camshaft gear is in your engine.
It sounds like you've never pulled an engine before. Well, this is pretty straightforward with a VW. _________________ 1970 VW (owned since 1972) and 1971 VW Convertible (owned since 1976), second owner of each. The '71 now has the 1835 engine, swapped from the '70. Second owner of each. 1988 Mazda B2200 truck, 1998 Frontier, 2014 Yukon, 2004 Frontier King Cab. All manual transmission except for the Yukon. http://www.thesamba.com/vw/forum/album_page.php?pic_id=335294 http://www.thesamba.com/vw/forum/album_page.php?pic_id=335297 |
