0to60in6min Samba Member
Joined: November 27, 2006 Posts: 3417 Location: OR & CA (Oregon/California)
Posted: Mon Jan 23, 2012 11:55 am Post subject: Adding backup light, your recommendation please |
hi all,
Sometimes maneuvering in the dark at camp site is quite scary.. trees, boulder, ravine etc. so I plan to add some lighting in the back so I can see better.. I am thinking some kind of light similar to the fog light/off-road light in the front but not as strong...
do you have something to recommend?
thanks in advance |
RBEmerson Samba Member
Joined: November 05, 2011 Posts: 2108 Location: SE PA
Posted: Mon Jan 23, 2012 12:32 pm Post subject: |
Try DDM Tuning - they're running a 10% off sale on this stuff right now.
DISCLAIMER: I have no connection with DDM Tuning save as a customer (motorcycle HID lighting kit). _________________ Lord, give me coffee to change the things I can change, and wine to accept the things I can't change. |
ragnarhairybreeks Samba Member
Joined: October 26, 2009 Posts: 1890 Location: Sidney B.C. Canada
madspaniard Samba Member
Posted: Mon Jan 23, 2012 12:39 pm Post subject: |
cannot find the link to Samba member 1621 backup light install, very neat, maybe somebody has it bookmarked? _________________ 1991 Westy auto w/ Peloquin TBD
"The only difference between me and a madman is that I'm not mad” - Salvador Dali |
teej Samba Member
Joined: November 26, 2010 Posts: 897 Location: Seattle
Posted: Mon Jan 23, 2012 12:48 pm Post subject: |
I used a backup light kit from KC Hi-Lite, uses a relay (I put it behind L taillight), set of two rectangular lights which I bolted to the rear bumper. Excellent illumination when backing, they are triggered by the backup lights circuit. I also wired a switch at the dash. _________________ 1986+ Wolfsburg Weekender Pop-Top 2.3 WBX Manual Trans |
Timwhy Samba Member
Posted: Mon Jan 23, 2012 1:00 pm Post subject: |
thanks, you guys are fast...
teej ...
does a relay is necessity or optional with a 55w light? I plan to hook them up to the reverse circuit at the tail light, which will be turned on when I engage the reverse...
another option is wiring them independently with a switch on the dash and turn them on and off at will when required... but then it needs long wiring from rear to front..
what do you think?
thanks again |
Timwhy Samba Member
Posted: Mon Jan 23, 2012 1:25 pm Post subject: |
add relay for sure.
alistair _________________ '86 7 passenger syncro, converted to westy pop top, project still in progress
https://shufti.blog/
Old address still works...
http://shufti.wordpress.com |
teej Samba Member
Posted: Mon Jan 23, 2012 1:30 pm Post subject: |
0to60in6min wrote: |
teej ...
what do you think?
thanks again |
Well, I have a pretty limited electrical knowledge, so I will not indulge in much advice. I used a relay because the kit came with it. But it was easy enough to keep the load off of the old wiring and just use it (reverse circuit at tail light) to trigger the relay. I got power from the post in the forward left engine compartment box and added a fuse. Actually the real pain was running another optional wire up for the dash switch, which I rarely use (although knowing I have it when being tailgated is satisfying ).
The lights themselves look very similar to those in Timwhy's pic, I mounted them above the bumper inboard of the tailight assemblies. Protected yes, but I do bump them with my knees sometimes when reaching in. _________________ 1986+ Wolfsburg Weekender Pop-Top 2.3 WBX Manual Trans |
Posted: Mon Jan 23, 2012 1:49 pm Post subject: |
[...]does a relay is necessity or optional with a 55w light? I plan to hook them up to the reverse circuit at the tail light, which will be turned on when I engage the reverse...[...] |
In a word, yes. The reverse switch is going to be handed something like 6 amps from that light alone (assuming the stock reverse lights - probably pulling about 2 amps each or a total of 10A with the added 55 W lamp - aren't disconnected). You might get by with that - the operative phrase being "getting by". With a relay, you can use both the existing switch and add another, manual switch, too, and not worry about cooking the reverse switch's contacts. Put the switches in parallel to power the lights as you need them, or to have them come on "automagically". _________________ Lord, give me coffee to change the things I can change, and wine to accept the things I can't change. |
rubbachicken Samba Member
Posted: Mon Jan 23, 2012 6:44 pm Post subject: |
i added a bosche spotlight as a reverse light, i am fed up with people tailgating me, riding so close i can see their faces
i bolted the light, midway between the license plate and the light cluster i have it wired through an extra rear defroster switch in the dash pod
i can now put it on to reverse, or shine it on numbheads who want to ride my bumper _________________ lucy our westy
lucy's BIG adventure
meet 'burni'
619 201 0310 or 617 935 4182 |
Posted: Mon Jan 23, 2012 7:45 pm Post subject: |
good idea rubbachicken
shine them till they back off.
Posted: Mon Jan 23, 2012 8:20 pm Post subject: |
speed is not something we have, so i always try to keep as far kerb side as i can, to give people as much overtaking room as possible _________________ lucy our westy
meet 'burni'
Saguache Samba Member
Joined: December 28, 2009 Posts: 360 Location: Gunnison, CO
Posted: Mon Jan 23, 2012 9:46 pm Post subject: |
I've been thinking about doing pretty much the same thing, but with these caveats.
1) It must be independently switched (not on the reverse switch) because you don't always need it on.
2) I must be mounted high on the back of the van and be bright enough to illuminate the area behind and a little to the sides.
I've been thinking really seriously about something like this _________________ Matt Thyer
http://zenoswagen.wordpress.com/ |
IdahoDoug Samba Member
Joined: June 12, 2010 Posts: 10251 Location: N. Idaho
Posted: Mon Jan 23, 2012 10:08 pm Post subject: |
For 17 years and 220,000 miles I have had a Bosch FF dual beam work lamp on the rear of the roof of my daily driver LandCruiser. The high up location has proven invaluable, and the dual 55 watt bulbs have provided serious light when I seriously needed it. I realize it takes a commitment of drilling a hole or two for a roof mount, but the high angle and powerful area lighting cannot be disputed. I have had to back out of difficult narrow trails for hundreds of yards, and it is worth the trouble of mounting. Heh - also won a car rally where the finale event was my co driver in the back in the dark maneuvering us through a technical maze (we were ruled OK since the vehicle came equipped this way to the event - heh).
The light goes for about $50 and they still sell it. You can purchase your choice of beam patterns from wide and long to narrow and tall and the patterns are designed for high mounting on a vehicle such as farming and mining equipment. Get the swivel mount as it's easy to mount on sheetmetal and gives you the ability to point it off to the side to look in ditches for something as you drive, etc.
Edit: here it is http://www.rallylights.com/detail.aspx?ID=4133 and they have it on sale right now for $37. That's a great deal for a "rest of your life" light.
DougM _________________ 1987 2WD Wolfsburg Vanagon Weekender "Mango", two fully locked 80 Series LandCruisers. 2017 Subaru Outback boxer. 1990 Audi 90 Quattro 20V with rear locking differential, 1990 burgundy parts Vanagon. 1984 Porsche 944, 1988 Toyota Supra 5 speed targa, 2002 BMW 325iX, 1982 Toyota Sunrader |
syncrodoka Samba Member
Joined: December 27, 2005 Posts: 12008 Location: Santa Cruz, CA
Posted: Mon Jan 23, 2012 11:11 pm Post subject: |
I run a Hella 76mm deep 55W rubberized work light on my rear bumper just under the DS tail light. http://www.rallylights.com/detail.aspx?ID=471
I run it relayed on a independent switch not on the taillight circuit. The light is too bright for daily use in parking lots but on the trails it does the job nicely. A advantage on not having it on the reverse circuit and the relay wired hot all of the time is that I can turn it on without the van running and regardless of gear position.
I agree with IdahoDoug that the light mounted up higher is better as it will cast less shadows on uneven terrain. I have used mine to back out of trails in the night and to set up camp and am happy with the compact unit. |
thatvwbusguy Samba Member
Joined: April 18, 2007 Posts: 1712 Location: Newmarket, New Hampshire
Posted: Tue Jan 24, 2012 12:00 am Post subject: |
The stock VW fog light switch is a great way to go for a dash mounted switch, it is a 3 position switch set up to run both front and rear fog lights. The only caveat being that the rear lights can't be illuminated seperately from the front, only in tandem with them, which could tend to run down your battery if you leave them on for extended periods.
There are some decent 12V LED work lights that are the same basic size and shape as standard fog lights. The good ones are not cheap, but they put out a pretty amazing amount of light while pulling very few Amps. Replacement LED bulbs for most styles of fog lights should be available from superbrightleds.com, but light output and pattern likely won't be nearly as good as with the purpose designed LED lights.
If anyone wants a simple relay setup for a rear fog light triggered from the reverse switch, I can put together a plug and play harness for around $20.00 + shipping. _________________ Jay Brown
'85 Zetec Westfalia
Newmarket, NH
If you want others to be happy, practice compassion.
If you want to be happy, practice compassion. |
PDXWesty Samba Member
Joined: April 11, 2006 Posts: 6247 Location: Portland OR
Posted: Tue Jan 24, 2012 8:57 am Post subject: |
I'm pretty sure I've seen regulations about mounting white lights on the back of cars. You need to check with your local state laws about it. I beleive it's similar to driving lights mounted forward that if their higher than the bumber, you need to have them covered on public roads. _________________ 89 Westy 2.1 Auto |
joseph928 Samba Member
Joined: September 22, 2011 Posts: 2114 Location: flagstaff az.
Posted: Tue Jan 24, 2012 9:30 am Post subject: lights |
PDXWesty wrote: |
I'm pretty sure I've seen regulations about mounting white lights on the back of cars. You need to check with your local state laws about it. I beleive it's similar to driving lights mounted forward that if their higher than the bumber, you need to have them covered on public roads. |
Don't know about laws but i've been running kc lights for 15 years in COLO.,NM,AZ, and never cover them up and never been stopped.I have yakima roof racks, they make a driving light mount for the rack, it holds two lights. The one on the back has two lights , one looks up one looks down. That covers close things and the other covers the idiots that follow to close! And yes you need to run a fuse and a relay . Put in an extra defroster switch in the 3rd hole down on the dash to run them. _________________ 1987 syncro westy tin top sun roof , GW2.3, rear locker, decoupler, Gary Lee tire rack & winch mount, lift, south african grill, big brakes , rhein alloy ,15 BFG AT, Fiamma 10 foot awning ,140 watt rear 85 watt front solar , mppt, truckfridge, automatic fire extinguishing system, tencent oil cooler, And a RMW SS exhaust! - 1971 bug convertible 1776 engine- 2010 Subaru turbo - 1993 Toyota 4x4 truck - 1999 Harley 95 CI, big bore, Andrews cams . Also 80-84- vans. Stock 65 sunroof bug. |
