GEEBEE Samba Member
Posted: Thu Feb 02, 2012 8:53 am Post subject: ?? |
Correct
seals could be die-cut or molded like a grommet
I will be gone the 22 thru the 03/02 for a diving trip to Palau/ Micronesia
GB |
Stuartzickefoose Samba Post Whore
Joined: February 07, 2008 Posts: 10350 Location: SoCal for now...
Posted: Thu Feb 02, 2012 9:10 am Post subject: Re: Das Boots |
Stuartzickefoose wrote: |
GEEBEE wrote: |
I can do those intake boots also....
I would need to make those other nla hoses, need to be wrapped in metal tape to hold there set fo the mandrell could be made...
I can do various sizes on the same assy if we know the outlet in mm ?
GB |
so, lets say someone gave you a full set of the seals for FI and a full set for Carb engines, could you make a kit for us? THAT i would be interested in....no more frackin vacuum leaks... |
my bad, i meant like hoses and tubes and the grommets that go on them n such... _________________ Stuart Zickefoose
206-841-7324
[email protected] |
BUSLUVR42 Samba Member
Posted: Thu Feb 02, 2012 9:13 am Post subject: |
Hey GEEBEE, any chance of vanagon 2.0l parts? _________________ - '81 Fed Vanagon L |
GEEBEE Samba Member
Posted: Thu Feb 02, 2012 9:25 am Post subject: 2.0 |
Send me pics at [email protected]
I can make what ever you guys want , contact Peter at Vancafe and see if he has a interest
I make all of stuff that was NLA
I also make MK I , MKII
GB |
Posted: Thu Feb 02, 2012 1:09 pm Post subject: Re: 2.0 |
GEEBEE wrote: |
GB |
someone with a better knowledge of hoses and tubes should do that...i have little knowledge, which is why a kit would be nice....an easy mix n match to find where they go...lol _________________ Stuart Zickefoose
206-841-7324
[email protected] |
germansupplyscott Samba Member
Posted: Fri Feb 03, 2012 9:58 am Post subject: |
ben919 wrote: |
I've installed the GeeBee C-hose and breather hose on my 79. Nice, snug fit, perfect lengths and great clamps.
Now ... about that S-boot ... |
these hoses are not supposed to be clamped. the reason for no clamps is to allow the hose to blow off in the event of a backfire. guy's hoses fit very well and should need clamps anyhow, but i recommend no clamps. _________________ SL |
GEEBEE Samba Member
brandt Samba Member
Hoody Samba Member
Posted: Tue Feb 07, 2012 10:28 am Post subject: |
He did not reproduce them. He is saying he could reproduce them out of silicone. My understanding is if you use the clamps and you have a backfire you can kiss your AFM goodbye. |
jtauxe Samba Member
Joined: September 30, 2004 Posts: 5780 Location: Los Alamos, New Mexico
Posted: Tue Feb 07, 2012 12:33 pm Post subject: |
germansupplyscott wrote: |
these hoses are not supposed to be clamped. the reason for no clamps is to allow the hose to blow off in the event of a backfire. guy's hoses fit very well and should not need clamps anyhow, but i recommend no clamps. |
Were you missing a "not", Scott?
I guess that all that is really needed to handle a backfire is to have at least one hose connection not clamped. _________________ John
http://vw.tauxe.net
1979 Champagne Sunroof, 1974 Westfalia Automatic, 1979 Transporter, 1972 Sportsmobile, 1973 Transporter Wild Westerner, 1974 Westfalia parts bus, 1975 Mexican single cab *FOR SALE*, 1978 Irish 4-door double cab RHD
secretsubmariner Champagne Wrangler
Joined: January 08, 2011 Posts: 3104 Location: Tulsa, OK
Posted: Tue Feb 07, 2012 1:23 pm Post subject: |
jtauxe wrote: |
Were you missing a "not", Scott? |
yes, your correction is what i meant to say... _________________ SL |
Posted: Tue Feb 21, 2012 5:22 pm Post subject: |
I just got the same two hoses as pictured above in the mail, and installed them. They are an amazing fit around the ends. The lower L shaped one was a little long though. It will serve it's purpose just fine! It'll probably last longer than my engine too _________________ -Tony
ᏣᎳᎩᎯ ᎠᏰᎵ
1978 Champagne Edition Bus FI
1970 Auto Fastback FI |
Posted: Tue Feb 21, 2012 5:23 pm Post subject: |
these hoses are not supposed to be clamped. the reason for no clamps is to allow the hose to blow off in the event of a backfire. guy's hoses fit very well and should need clamps anyhow, but i recommend no clamps. |
If they were clamped and there was a back fire, would there be considerable damage? _________________ -Tony
ᏣᎳᎩᎯ ᎠᏰᎵ
Westfabulous Samba Member
Joined: January 07, 2007 Posts: 4207 Location: The tropic of Canada, dodging the giant flying moose of Surrey!
Posted: Tue Feb 21, 2012 6:01 pm Post subject: |
secretsubmariner wrote: |
If they were clamped and there was a back fire, would there be considerable damage? |
Probably not. Some hoses might get damaged. _________________ *****************
"I will gladly pay you Tuesday for a hamburger today." |
GEEBEE Samba Member
Posted: Wed Feb 29, 2012 7:59 am Post subject: Stock |
Matte black in both are now in stock.......
GB |
Posted: Wed Feb 29, 2012 8:20 am Post subject: |
Westfabulous wrote: |
Probably not. Some hoses might get damaged. |
it is the airflow metre that can get damaged. if the hose blows in a backfire off the AFM flap will not deflect as explosively, this is why the big hoses are not meant to be clamped. _________________ SL |
GEEBEE Samba Member
Posted: Fri Mar 02, 2012 10:19 pm Post subject: INTAKE HOSES ( FOR TUBE ) |
I want to make those to finish the compartment
Who has i.d. and length needed ??
GB |
curtis4085 Samba Member
Posted: Sat Mar 03, 2012 12:19 am Post subject: Re: INTAKE HOSES ( FOR TUBE ) |
GEEBEE wrote: |
GB |
those what? _________________ Special Thanks to:
Headflow Masters - Vista, CA
www.headflowmasters.com |
