Lifted Van, Cargo Space Below
Page: Previous  1, 2, 3, 4, 5, 6, 7, 8
Syncronoid
Syncronoid is offline
PostPosted: Fri May 31, 2019 3:15 pm    Post subject: Reply with quote
After 6 years, I'm finally getting around to having the permanent, locking metal top made for my under floor storage. Lid will be made of 0.105" thick steel with formed over twice each edge, then welded at all 5 corners. Welded L-brackets for stiffening and recessed handles. Having the formed edges providing the thickness for the lid will actually allow almost a 1/2" extra storage height inside than the current wood board as the lid will have no bottom layer. Still have yet to determine the final locking mechanism, but I think there are lots of options.
Here's the mockup....
Syncronoid wrote:
Here's the progress I made today, mostly getting things sealed, final bolt selection and getting the temporary cover cut to fit (still need my sander from my neighbor to dial in the edges).
Cut the two existing bolts out as they were slightly corroded and did not allow enough space between it and the side of the box to fit a nut over.
Silicone injected into openings to seal out dust and moisture.
Rear and front rubber insulation strip to seal the rear of the box where, as a result of the cross cut, left a 1/4 inch gap between the flange and floor.
...front....
Bolt connection. 6 in all.....
Rubber pad cut to fit...
Now just waiting for my neighbor to return my sander so I can finish the temporary wood cover...
[/url]
'90 Syncro Westy w/2.5L GW
Steve M.
Steve M. is offline
PostPosted: Sat Jun 01, 2019 5:22 am    Post subject: Reply with quote
I'll probably get around to doing mine in 6 yrs. too!
dobryan
dobryan is offline
PostPosted: Sat Jun 01, 2019 6:35 am    Post subject: Re: Lifted Van, Cargo Space Below Reply with quote
Going to do something similar on my euro bus project. Your topic is the inspiration.
Dave O
The West Coast Westy
Syncronoid
PostPosted: Wed Jun 19, 2019 12:17 pm    Post subject: Re: Lifted Van, Cargo Space Below Reply with quote
Here's the completed metal lid. Next step is figuring out and installing the locks. Ideas??
E1
E1 is offline
PostPosted: Wed Jun 19, 2019 12:24 pm    Post subject: Re: Lifted Van, Cargo Space Below Reply with quote
Want.
1984 Westy-Ferrari firing at 33% capacity
I drive by the seat of my pants but then get behind on my steering
Thank You Bob Lazier, Forever Golden
Steve Arndt
Steve Arndt is offline
PostPosted: Wed Jun 19, 2019 12:25 pm    Post subject: Re: Lifted Van, Cargo Space Below Reply with quote
Nice!
Luke:
It's a good thing you have these compartments.
Han Solo:
Yeah, I use them for smuggling. I'd never thought I'd be smuggling myself in them.
Steve
Steve's 87 Syncro project
Slimvest
Slimvest is offline
PostPosted: Wed Jun 19, 2019 1:35 pm    Post subject: Re: Lifted Van, Cargo Space Below Reply with quote
Inspiring stuff. I'm always chasing storage options.
I cut a hole in my roof, so I suppose I could do the same in the floor...
'87 GL w/ Reimo top
0cean
0cean is offline
PostPosted: Wed Jun 19, 2019 1:51 pm    Post subject: Re: Lifted Van, Cargo Space Below Reply with quote
LOL...J/K Say no to drugs kids.. Very nice job on the compartment.
I'm not a mechanic, I just play one on the internet
Cluster Rebuild:
http://www.thesamba.com/vw/forum/viewtopic.php?t=569920&highlight=
Left for Dead the Resurrection Story Build:
http://www.thesamba.com/vw/forum/viewtopic.php?t=613669
(Number of Different Donor VW Vans Body Parts Used: 12)
(Number of completely different vehicles parts used: 3)
Syncronoid
PostPosted: Thu Jun 27, 2019 10:06 pm    Post subject: Re: Lifted Van, Cargo Space Below Reply with quote
Locking mechanism coming along......
Syncronoid
PostPosted: Fri Jun 28, 2019 11:52 am    Post subject: Re: Lifted Van, Cargo Space Below Reply with quote
Done! .....except for painting the lid (will likely use spray on bedliner) and putting a nicer trim than duct tape around the edges of the box.
michaelbteam
michaelbteam is offline
PostPosted: Fri Jun 28, 2019 2:08 pm    Post subject: Re: Lifted Van, Cargo Space Below Reply with quote
Inspiring "art project." Well done, thanks for sharing!
kguarnotta Premium Member
kguarnotta is offline
PostPosted: Mon Sep 07, 2020 6:36 pm    Post subject: Re: Lifted Van, Cargo Space Below Reply with quote
super impressive...did you figure out how to deal with the edge condition?
-Kevin
Woodstock, NH
'86 Triple Knob Syncro w/EJ22
'78 Westy
'69 Single Cab
'65 Kombi - EZ-Camper
Page 8 of 8
