Sportbugger Samba Member
Posted: Fri Jan 27, 2012 5:26 pm Post subject: |
pittwagen wrote: |
Well that Sewfine upholstery doesn't look that great. I think I'll stick with the original stuff a while longer.
Sportsbugger you have done well. |
Yeah the Sewfine material as it appears so far doesn't impress me either.
I found some corderoy at a fabric store that matched the OEM pattern exactly, I'm going to use that and have it re-dyed to match the stock color.
Thanks for your compliment, it's so far been a 3 year project, should be done by this Spring/Summer. I'm enjoying every minute, I use to build a lot of model cars when I was a kid and often I look at this as a full size version.
I've always been into VW Bugs since before I could drive,
This one will be Bug #7 and the 3rd Sports Bug that I've owned.
I've always wanted a Marathon Blue one.
Still debating on whether or not to finish it with the optional stripe on or not?
Thanks
Todd
Todd |
69 Jim Samba Member
Joined: September 27, 2004 Posts: 6264 Location: Chickengeorge's Neighbor
Posted: Fri Jan 27, 2012 5:29 pm Post subject: |
One vote here for the stripe. |
pittwagen Samba Member
Joined: November 08, 2005 Posts: 765 Location: North of the 49th parallel
Posted: Fri Jan 27, 2012 5:41 pm Post subject: |
The stripe kit came in a box and was installed at the dealership. I hated stripes then and still do. I told them to keep the kit. I did order the black trim for the upper cooling slots under the rear window though. It was later stolen and replacements were long gone from the dealer.
I like the cleaner look without the stripes.
I do regret not getting the Sports Bug order sheet for the trim and accessories. I didn't get everything. |
Posted: Fri Jan 27, 2012 5:53 pm Post subject: |
19-VW-74 wrote: |
Hey sportbugger,
I read your restoration thread on SBO a while back but you stopped updating the car after the body came back from paint...
You should start a new build thread here - I don't think there are any Sport Bug restoration threads on TheSamba yet. |
Hi 19-VW-74
Thanks!
Unfortunatley because of the climate up here in Canada I'm at a stand still, It's too cold to progress any further, I still need to complete the final sections of the Headliner then Install the windows with new Seals...this is done better when warm out, before I install the carpeting I still need to run a bead of black Seam Sealer where the Floor pans joined onto the Tunnel that and the capet install also need it to be relatively warm out.
In the mean time I'm just puttering with a few small jobs for the car in my basement until the weather turns better and continuing to look for the remaining parts I need to finish it.
Once I get the ball rolling I will continue to update - probably just Hi-jack this thread and use it unless Early (who started it) objects. The title is appropriate.
Thanks
Todd |
19-VW-74 Samba Member
Posted: Fri Jan 27, 2012 6:00 pm Post subject: |
Sportbugger wrote: |
That's where I'm at too, though. It's too darn cold in my garage to finish painting my chassis with POR-15 - won't cure right. I've had to move most of my operations into my basement where I can powdercoat and paint without harming anyone with the fumes. _________________ -Austin
My 1974 Standard Beetle Build:
http://www.thesamba.com/vw/forum/viewtopic.php?t=492617 |
Posted: Fri Jan 27, 2012 6:02 pm Post subject: |
19-VW-74 wrote: |
Hey sportbugger,
I read your restoration thread on SBO a while back but you stopped updating the car after the body came back from paint... |
Actually I did the painting myself right where you see it still...yup never held a paint gun in my life,
took 2 attempts, the first time it didn't work out and I was considering making a roll-around fixture to send it off to a body shop..then I thought I would give it another go and it turned out amazing.
Mind you I waited for the Clear to dry 1 week then wet sanded it with 600grit using soap and water, then 1000g then 1500g then 2000g once all sanded I hi-speed polished it with compound, washed the car, then polished it with Meguire's #9 Swirl Remover then washed it again and hand waxed it with Carnuba paste wax....took 12 hours that day
The finish is like glass, you can see by the reflections of my other car.
Posted: Fri Jan 27, 2012 6:13 pm Post subject: |
69 Jim wrote: |
It's great to see a proper restoration. Once again, great, tastefully done work. |
Thanks Jim
I'm being very meticulous about each step and each part that gets installed and how they get installed.
I work in the Aerospace industry so I'm applying the same methology with this project as well,
All mating surfaces are coated and all the threads of the fasteners are coated with this stuff:
http://www.skygeek.com/ppg-mastinox-6856k-yellow-160-ml-catridge.html
Todd |
early Samba Member
Joined: January 19, 2012 Posts: 186 Location: Glen Carbon, IL
Posted: Fri Jan 27, 2012 6:57 pm Post subject: |
I also vote for the stripe ! But I'm thinking you will have to paint it since the stripe kits are long gone.
What type paint did you use? is that a Urethane Base coat / Clear Coat paint ? and if so what kind of Respirator did you use?
I've painted cars in the past but not with the new Urethane paints and I understand they are quite Toxic. _________________ early-
Barnfind westy project
my 73 sports bug project build
http://www.thesamba.com/vw/forum/viewtopic.php?t=497088
Current Projects :
73 Sport Bug - L13M gone now
67 Westfalia
57 oval window ragtop - sold june 2021
61 sedan
68 Corvette Roadster - Small Block, 4 Speed
86 GMC Sierra Classic- 4x4, Shortbed
94 Harley Flstn |
Posted: Fri Jan 27, 2012 7:34 pm Post subject: |
early wrote: |
I've painted cars in the past but not with the new Urethane paints and I understand they are quite Toxic. |
Dupont Acrylic Urethane Base Coat Clear Coat, I believe it was their Chromapremier Series.
Base Coat tinted in L96M Marathon Blue Metalic.
Yup I used a NIOSH approved mask, in the "Body/Paint" section of these forums, in the Sticky Section, there's a thread called Paint Process Explained.... where Chilkoot says it well: "SAFETY!!!! RESPIRATORS>>> NIOSH approved Only!! some of this stuff is CYONIDE !!! dont be scared.. just be SAFE!!" |
a.wilson Samba Member
Joined: January 11, 2007 Posts: 2033 Location: Georgia
Posted: Sat Jan 28, 2012 8:01 am Post subject: |
Having a hard time getting a set of good Sports Bug Rims, I have 8 of them and none of them are worth restoring, all corroded and pitted.
Mid America Motor Works was talking about reproducing them, but no one there is getting back to me on this
There was a link to this on their site but they recently disabled the blog: http://blog.autotainment.com/2010/03/29/ne...ree-months.aspx
guess it's not going to happen. |
Probably good they aren't. Half of me wishes those wheels were reproduced... but like so many parts these days, if they were going to be made cheaper quality than originals, just as well if no one bothered. _________________ Be kind to all critters. America's "H8TERZ" can drink sludgy used Motor Oil!
oemwolf |
mrbigmax Samba Member
Joined: September 10, 2011 Posts: 1289 Location: Modesto, CA
Posted: Sat Jan 28, 2012 11:56 am Post subject: |
[quote="pittwagen"]The stripe kit came in a box and was installed at the dealership. [quote]
Here's a picture of the box:
Posted: Sat Jan 28, 2012 12:07 pm Post subject: |
a.wilson wrote: |
Probably good they aren't. Half of me wishes those wheels were reproduced... but like so many parts these days, if they were going to be made cheaper quality than originals, just as well if no one bothered. |
+1
And I don't want any repros to reduce the cool factor or value of the original Sport Bug wheels.... like those repro Cosmics have done. _________________ -Austin
early Samba Member
Posted: Wed Feb 22, 2012 9:02 am Post subject: project getting underway |
Guess I'm getting started on this project. Had to pull the engine to locate a Missing "solex Dump Tube" ( found it setting in #4 intake port). Now I'm trying to decide if i tear down or go with engine as is.
Pulled of rear fenders to begin removal of PO Rattle can Undercoating.
Rattlecan Undercoating
still more much work to do:
basically I'm just getting started. Just trying to determine just how much rust I have and what is required.
cheers.. _________________ early-
Current Projects :
67 Westfalia
61 sedan
94 Harley Flstn |
early Samba Member
Posted: Thu Mar 01, 2012 8:27 am Post subject: My 73 Sports Bug - Progress Updates |
have been removing the original Undercoating which appears to be Factory or Dealer applied. I had originally thought that it was applied by one of the previous owner so I thought I best remove it to see what was hidden. I havent found Much at all under the undercoat which leads me to believe it was Original.
Front pan looks very nice and original
Saturn Gelb L 13 M
drivers door Jamb
side shot
( notice the Old steering wheel hanging on the wall - from my 67 Bug from the 70's)
found this Under the Undercoating the number 233 in red grease Paint (very fragile ) I had to stop cleaning at that point to get some pics.
decided to separate the Body and Pan because of the small rust issue in the Rear Wheelhouse on each side , I can clean up the Pan while im at it
the pan is in very nice shape as well, I havent found ANY Holes in it, the battery box had some rust but nothing thru the pan so it should be salvageable
all said I'm pretty happy with the condition of the Old Sport Bug at this point.
I'm really torn as to what to do with the Paint. for the most part the body is OG Paint but has f few spots and the rear fenders need repaint and the Hood has a spot where the PO did some body work .
Current Projects :
67 Westfalia
61 sedan
94 Harley Flstn |
early Samba Member
Posted: Thu Mar 01, 2012 9:43 am Post subject: my 73 Sport Bug - Progress |
@ 19-vw-74 Yep its not bad the rust is limited to the lower rear quarters and the rear lower wheelhouse area on either side. the Torsion bar was in the way so I had to get the Pan out of the way.
drivers door jamb has some rust in the meeting of door jamb and rocker panel area. this one might be some work
even has the original Cardboard Trunk liners
rusty quarter... somehow the digital pics make the Rust look worse than it actually is ! not sure what's up with that
wheelhouse area
Current Projects :
67 Westfalia
61 sedan
94 Harley Flstn |
bluedirtbeetle Samba Member
Joined: January 30, 2012 Posts: 121 Location: Tierra Azul, NM
Posted: Thu Mar 01, 2012 9:48 am Post subject: |
Its always nice to see these old things being so lovingly handled. Keep up the good work.
Also my 2 cents on the stripe, definitely keep it. Everyone knows that they are faster and stop better with a stripe on them. |
