awalls Samba Member
Joined: March 21, 2005 Posts: 128 Location: Beaverton, OR
Posted: Thu Jan 26, 2012 11:33 pm Post subject: Reserve valve / fuel tap leak |
Out searching for that gas smell I found the fuel tap dripping fuel. Is there a gasket or seal where it threads into the gas tank? Or is it leaking from inside and need a rebuild? I just filled the tank too!!! So do I need to drain it and get a rebuild kit from WW or yet and tighten it? Any help would be great. Thanks _________________ '64 Bug
'58 Kombi |
EverettB Administrator
Joined: April 11, 2000 Posts: 69813 Location: Phoenix Metro
Eric&Barb Samba Member
Joined: September 19, 2004 Posts: 24738 Location: Olympia Wash Rinse & Repeat
Clara Samba Member
Posted: Fri Jan 27, 2012 10:48 am Post subject: |
You may need to rebuild your fule tap, replace the seal from tap to tank, and/ or replace the fuel line under the bus.
When I have has a tap need rebuilding, generally there is an internal leak. This means when you turn it to OFF, some still gets past... enough to drive at idle or stop and go, but the bus mysteriously dies on the freeway.
First check fuel line under bus.
And disconnect the battery ground strap from the battery before messing about under there. _________________ The Obsolete Air-Cooled Documentation Project http://oacdp.org/ |
awalls Samba Member
Posted: Fri Jan 27, 2012 11:40 am Post subject: |
Just ordered new fuel sock, washer and rebuild kit from WW. Yeah, first thing I did was disconnect the battery due to being so close the starter. Now I need to figure out the best way to drain the tank. I'm thining another fuel hose a let it slowly daub out into gas cans. Thanks for the info _________________ '64 Bug
'58 Kombi |
Krustybus Samba Member
Joined: February 16, 2004 Posts: 442 Location: SE Michigan
Posted: Fri Jan 27, 2012 1:07 pm Post subject: |
I use a simple self prime siphon hose. You can get these at almost any boat, power sport, lawn equipment, etc store. Here's one from Harbor Freight.
http://www.harborfreight.com/self-priming-copper-jiggler-pump-47334.html
Empty most of the tank through the filler. Beats 10 gallons out the bottom with the small fuel line. _________________ Tim |
awalls Samba Member
Posted: Fri Jan 27, 2012 1:47 pm Post subject: |
Thanks Krusty, that might speed up the process a bit. _________________ '64 Bug
'58 Kombi |
guatebus Samba Member
Joined: May 12, 2003 Posts: 392 Location: Oakland, CA
Posted: Fri Jan 27, 2012 7:44 pm Post subject: |
I just rebuilt and added a fuel reserve tap to my '64. Some tips:
It will be a whole lot easier to do with the engine out.
As for rebuilding the tap, consult your Bentley as there are good pictures in there. There's a little retaining ring that's a pain in the ass...I had to struggle with it a bit to get it back on. Use a socket or something to compress the tap while simultaneously compressing the ring and slipping it into its groove. Make sure the little disc thing is oriented properly before you put in the retaining ring...you can blow through the tap pipes to check to see which ones are open for the three different positions of the tap.
Replace all your fuel lines at the same time. I used 30R9-rated hose, which is resistant to stuff in modern gasoline, but couldn't find a metric version. I had to use REALLY tight hose clamps to make the SAE hose work. I wish there was metric 30R9 hose.
Make sure you understand how the nut on the bottom of your tank works...it has left-hand and right-hand threads which allow it to tighten onto the reserve tap and the tank at the same time. If you mess this up, you'll get leaks. I would test for leaks by adding one gallon of gas to the tank. See if there are immediate leaks, and if not, check back the next day to see if there are seeping leaks. The nut needs to be tight on the tank and the tap for leak-free operation.
Have fun...reserve taps are cool. _________________ '64 standard microbus
'69 deluxe microbus |
awalls Samba Member
Posted: Sun Jan 29, 2012 12:10 am Post subject: |
Any tips or trick to remove the black disk with 5 holes. I'm haveing a hell of a time getting it out. _________________ '64 Bug
'58 Kombi |
BarryL Samba Member
Joined: November 01, 2004 Posts: 14259 Location: Casa de Oro, California
Posted: Sun Jan 29, 2012 8:05 am Post subject: |
awalls wrote: |
Just ordered new ...rebuild kit from WW. |
Link to this? I didn't see it. |
Posted: Sun Jan 29, 2012 8:21 am Post subject: |
Quote: |
Any tips or trick to remove the black disk with 5 holes. I'm haveing a hell of a time getting it out. |
I use a small pick with a hooked end. The disc just sits in there.
Link to kit:
http://www.wolfsburgwest.com/cart/DetailsList.cfm?ID=111209113A _________________ Tim |
Posted: Sun Jan 29, 2012 9:34 am Post subject: |
awalls wrote: |
I agree, a small pick is good. If the disk is old and crusty, it might come out in a million pieces. Be careful about getting too rough with it, though, as you don't want to mess up the brass tubes that pass through it. _________________ '64 standard microbus
cru62 Samba Member
Joined: December 31, 2002 Posts: 4117 Location: Margaritaville.....24/7
Posted: Sun Jan 29, 2012 9:45 pm Post subject: |
Is the rubber boot that covers up the valve available anywhere? I didn't see it on the WW site. _________________ "My biggest worry is that when I die, my wife will sell all my parts for what I told her I paid for them"-Jon
Jokes about German sausage are the wurst.
Posted: Sun Jan 29, 2012 10:10 pm Post subject: |
Only some of the reserve switches used the rubber cap.
You can check the obsolete "air-cooled documentation project" website @
http://oacdp.org/
The type 2 parts manuals there are a must for parts research.
Other possibility if you just want something to work, is maybe a brake wheel cylinder boot might fit. _________________ In Stereo, Where Available! |
cru62 Samba Member
Posted: Sun Jan 29, 2012 10:22 pm Post subject: |
I have the boot. It came on my valve. It is just too shot to reuse. The WW site shows one on the bug valve, but not the bus one. And the bug one isn't shown in the kit. Just wondered what others are using. _________________ "My biggest worry is that when I die, my wife will sell all my parts for what I told her I paid for them"-Jon
Posted: Sun Jan 29, 2012 10:42 pm Post subject: |
Well then you might try calling them and see if they will sell you just a boot! _________________ In Stereo, Where Available! |
awalls Samba Member
Posted: Thu Feb 02, 2012 7:21 am Post subject: |
Okay so this is how it came off the bus, and the second pic is how its going back on if I'm correct? Do I need another washer to slide over the fuel sock? Also the washer on the underside of the nut is a copper one? Thanks for everyones help.
Oh and there was no fuel sock or washer on the top of the nut when I took it off the tank.
'58 Kombi |
Posted: Thu Feb 02, 2012 10:10 am Post subject: |
The parts manuals mentioned previously have almost a complete listing of the parts used, AND nice exploded diagrams of the parts. _________________ In Stereo, Where Available! |
awalls Samba Member
Posted: Thu Feb 02, 2012 10:31 am Post subject: |
Yeah I looked through http://oacdp.org/ but the exploded diagram does not explode the nut on top of the fuel tap to show if there is a washer... And my transporter service manual has a differnt version of the fuel tap... _________________ '64 Bug
'58 Kombi |
