JohnnyRingo Samba Member
Joined: October 22, 2011 Posts: 415 Location: United States
Posted: Sat Mar 30, 2013 5:30 pm Post subject: |
gatorwyatt wrote: |
Getting the reserve to pull is usually no issue but getting it to go back in is usually an issue I always have...I have a fresh cable and the angle of the dangle is correct and when I go to push the reserve in it gets springy and won't go back...
Any suggestions.. |
Thats the problem I had when I rebuilt mine w/ww parts....it would pull out fine for reserve, but would not push in all the way, like you said it would spring back. So I just bit the bullet and found a nos tap.......smoothe as butter |
gatorwyatt Samba Member
Joined: April 24, 2002 Posts: 1867 Location: Clearwater Fl.
Posted: Sun Mar 31, 2013 6:45 am Post subject: |
Eric&Barb wrote: |
gatorwyatt wrote: |
Any suggestions.. |
Did you grease/graphite the reserve tap??
Did you pull out the cable from the sheath and do same to it??
Did you oil the outer portion of the reserve tap?
The last one really helped with that spring back for us. |
No...it was new so taking it apart wasn't thought to be an issue...
Yes...
Please elaborate on what you oiled... _________________ www.blastserv.com
wanted:
RHD Barndoor floor mat..reproduction is fine |
Eric&Barb Samba Member
Joined: September 19, 2004 Posts: 24764 Location: Olympia Wash Rinse & Repeat
Posted: Sun Mar 31, 2013 8:10 am Post subject: |
gatorwyatt wrote: |
Yes...
Please elaborate on what you oiled... |
If it is not leaking that should be fine.
Good!
The reserve switch as assembled needs a little oil in the outer metal parts so it is lubricated and smoothly moves. Otherwise those metal parts are dry and GRIND as you move them back and forth.
All it takes is a little oil squirted into the reserve switch from the outside. Some models have a rubber boot over those parts, but easy enough to unwire the boot and move it out a bit to get the oil in there. Slide the boot back in place and test/work in oil and see if it gets easier to work the cable. Repeat oiling as need till it moves easy with the cable. Then rewire the boot.
Only took once to slide underneath and a shot of 30 Wt oil for us!
All the metal parts shown below starting out from the cork/rubber seal on left to the outer C-clip on the right need a bit of lubrication.
_________________ In Stereo, Where Available! |
KevinAlbrecht Samba Member
Joined: March 07, 2002 Posts: 970 Location: Ocean City > Boca > Pompano > Kirkland > Eugene
Posted: Sat Apr 13, 2013 6:11 pm Post subject: |
BulliBill wrote: |
Once rebuilt, that tap will work as a fuel tap. When you run low, you'll have to pull over, crawl under the bus and operate that tap manually (not remotely by cable). But it will work, just NOT remotely.
Otherwise, you'll need to locate and rebuild a "Bus" fuel tap with the different shaft and matching "lever/clamp nut", a complete fuel tap cable and devise some way to mount up the forward end in the front cab pedestal with a steel tube running back to the tap to keep the cable from flexing all over the place. Unless you are very handy, just rebuild and mount up the Type 1 Beetle tap and accept the slight inconvienence of crawling under the bus to operate it occassionally.
Bill |
When I crawled under there this morning the head of the stock tap appeared to be quite a bit larger than this (beetle) tap. I didn't pull it off because I didn't want gas in the face, if I was not certain it was going to fit.
Understandably, I can see how the outer wrench size may be different. Can someone verify the actual threaded portion is the same size?
- Thanks, Kevin _________________ Kevin Albrecht
Wait, what...?
WideFive wrote: |
Single carbs are for lawn mowers! |
Don't forget those seat-belts!
Click to view image |
Posted: Sat Apr 13, 2013 6:22 pm Post subject: |
KevinAlbrecht wrote: |
It is the same thread size. _________________ In Stereo, Where Available! |
prodaddy Samba Member
Posted: Thu May 16, 2013 9:47 pm Post subject: |
Does anyone know the actual tread size on the bottom of the fuel tanks, I need to get a die to repair the threads on my tank, I could not find that info. Thanks guys. _________________ 1957 23 window samba,1963 23 window deluxe(work in progress),1967 westy,1967 21 window deluxe,1963 vw bug ragtop,1962 vw bug. |
Posted: Sat May 18, 2013 1:07 am Post subject: |
Thanks for the tip. I'm going to go look for the m18 by 1.0 thread chaser tomorrow. Hopefully that will save me from pulling the motor to get the tank out for repair. _________________ 1957 23 window samba,1963 23 window deluxe(work in progress),1967 westy,1967 21 window deluxe,1963 vw bug ragtop,1962 vw bug. |
Posted: Sat May 18, 2013 6:13 am Post subject: |
No problem!
If you take the nut that goes on that outlet, the shop can double check the size and thread.
As always use grease or anti-seize to keep those threads from corroding up. _________________ In Stereo, Where Available! |
perello Samba Member
Joined: April 15, 2005 Posts: 829 Location: where social security comes for free
Posted: Sun Jun 27, 2021 2:03 am Post subject: Re: Reserve valve / fuel tap leak |
i post here because is a related topic,
i rebuilt my fuel tap and works flawlessly, yesterday i used it for the first real need though...and found that the reserve only lasted for few km?
my guess is that reserve is at least a gallon which should be good for 30 km? _________________ Aug '58 pressed bumper SO23
1974 German Thing
1978 Bug 1200 |
EverettB Administrator
Joined: April 11, 2000 Posts: 69824 Location: Phoenix Metro
Posted: Sun Jun 27, 2021 9:32 am Post subject: Re: Reserve valve / fuel tap leak |
I believe it is around 1 gallon but not sure of the exact amount.
It definitely lasts for more than a few KM.
I've driven on reserve from my house to my preferred gas station 10-12km away multiple times.
Did the longer reserve pipe look pretty long?
I've seen one or both them cut or broken so they are shorter.
A couple pics:
I don't have one right in front of me but I can measure the pipes if necessary. _________________ How to Post Photos
mandraks Samba Member
Joined: November 28, 2004 Posts: 7050 Location: Lawrenceville, Ga
Posted: Sun Jun 27, 2021 4:52 pm Post subject: Re: Reserve valve / fuel tap leak |
yes, i would expect something like 15-20 miles on a stock bus. in my beetle i have driven over 30 miles on reserve once. (i needed to!) _________________ regards
Uli
Posted: Mon Jun 28, 2021 12:37 am Post subject: Re: Reserve valve / fuel tap leak |
thanks guys for your kind answers.
Will check the tap again when I empty the tank.
On the meantime I know that adding 5 liters of gas on an empty tank didn't allow me to start the engine if reserve was not set. _________________ Aug '58 pressed bumper SO23
1974 German Thing
1978 Bug 1200 |
Posted: Mon Jun 28, 2021 7:54 am Post subject: Re: Reserve valve / fuel tap leak |
Mayhaps the brass tube for normal running broke off when being installed.
Good to remove the reserve tube to keep water and junk from accumulating in the bottom of the gas tank. Lot easier to run a fuel filter under the tank and pull the carb drain plug if water gets into it. _________________ In Stereo, Where Available! |
