Helfen Samba Member
Joined: January 19, 2009 Posts: 3450 Location: Vulcania
Posted: Sat Mar 11, 2017 8:08 pm Post subject: Re: Beetle Air Cleaners - picture reference thread |
panicman wrote: |
No sign of an o ring. If I get one that is approximately 1 5/8", I assume it just rides on the intake tube, and the filter portion (top part) just rests on top of it?
I have a slightly later Knecht filter, and the intake has an obvious shoulder at the top where an o ring would sit. The Mann does not appear to have any obvious shoulder, but does have a distress- or wear- line where an o ring could have sat. |
Here you go, click on the link:
http://www.thesamba.com/vw/archives/manuals/aug62bug/page53.jpg |
panicman Samba Member
Joined: December 18, 2011 Posts: 2290 Location: Canby, OR
Posted: Mon Mar 13, 2017 7:41 am Post subject: Re: Beetle Air Cleaners - picture reference thread |
That doesn't look like a common o ring... Anyone know where I might find one of those? _________________ Plate of shrimp |
nlorntson Crazy VW Lady
Joined: March 13, 2004 Posts: 3783 Location: Twin Cities, MN
Helfen Samba Member
Posted: Mon Mar 13, 2017 1:29 pm Post subject: Re: Beetle Air Cleaners - picture reference thread |
panicman wrote: |
That doesn't look like a common o ring... Anyone know where I might find one of those? |
I matched up my old one at my True Value Hardware store a couple of years ago, it's still doing fine. It is not a "O" ring |
jays58s Samba Member
Joined: August 23, 2004 Posts: 2133 Location: Nor-Cal
Posted: Wed Jan 17, 2018 11:16 pm Post subject: Re: Beetle Air Cleaners - picture reference thread |
Has anyone seen an air cleaner with two decals? The decals also have a total of 4 different languages. This is the original filter on my 55 oval, and it’s dated 2/55.
bnam Samba Member
Joined: July 02, 2006 Posts: 2936 Location: El Dorado Hills CA/ Bangalore, India
Posted: Thu Jan 18, 2018 5:16 am Post subject: Re: Beetle Air Cleaners - picture reference thread |
71 Airfilter and decals. _________________ 1971 1302LS Convertible (RHD) owned since '74
Click to view image
1952 Citroen TA 11BL |
herbie1200 Samba Member
Joined: April 27, 2006 Posts: 833 Location: Rome - Italy
Posted: Wed Jan 16, 2019 6:46 am Post subject: Re: Beetle Air Cleaners - picture reference thread |
I post a couple of photos of a very strange (for me) situation.
I realized I had 2 air filters exteriorilly identical but different inside.
The main difference is, in the lower part, the vertical pipe size and shape.
On the small one the pipe is narrower and has an edge to seat an oring.
On the larger one the pipe is bigger and no edge.
On my stock 1200 the bigger gives the same performance but adds a sort of audible "scream" at 2500-3000 rpm.
The narrower sounds a bit quiter.
I did not found that evidence in this thread... are perhaps those filters only for the italian market?
p.s. don't care for wiring from filter, I'm testing a solenoid to governate flap action depending on temperature. |
4bolts Samba Member
Joined: June 01, 2016 Posts: 102 Location: West Virginia
Posted: Wed Jan 16, 2019 7:15 am Post subject: Re: Beetle Air Cleaners - picture reference thread |
Found this one in an old stash of parts I had from years ago.
113129611C
... _________________ 1966 Beetle - Euro
1965 Single Cab |
Navydave73 Samba Member
Joined: March 09, 2017 Posts: 414 Location: Alta Loma/Los Angeles
Posted: Mon Mar 18, 2019 6:39 pm Post subject: Re: Beetle Air Cleaners - picture reference thread |
What the heck is this? It doesn’t resemble any of the other air cleaners I’m seeing, part number ends with 611 and a letter i cant make out. It is on a 40hp in my daughters 1960 bug.
Found this inside a bug we just scored.
And, this one inside also. According to this thread, looks correct for my daughters 1960 bug.
Eric&Barb Samba Member
Joined: September 19, 2004 Posts: 24733 Location: Olympia Wash Rinse & Repeat
Posted: Mon Mar 18, 2019 7:33 pm Post subject: Re: Beetle Air Cleaners - picture reference thread |
Looks like "611 G" probably 1961 beetle. You can look up part numbers in the original VW dealer type 1 parts manual here:
http://www.oacdp.org/
Type 1 manual for now is available thru the "Upcoming" button at the top... _________________ In Stereo, Where Available! |
Posted: Tue Mar 19, 2019 12:18 pm Post subject: Re: Beetle Air Cleaners - picture reference thread |
That’s it. Thanks for the response. Looks like the previous owner replaced the 36hp in my daughters 60 with a very early 40HP with the original air cleaner. I was thinking about removing that engine and finding an original date correct 36hp, but if this 40hp turns over.....i might try to save it.
Thanks again. |
Danwvw Samba Member
Posted: Fri Dec 20, 2019 5:39 pm Post subject: Re: Beetle Air Cleaners - picture reference thread |
What about this air cleaner on an 1960 Beetle is it correct? It doesn't seem to fit because the flat spot side is too tight to the fan shroud, could this just be my manifold on wrong or should I turn it with it's flat spot away from the shroud so it fits.
111.129.611B
My 36hp engine shown here with a 40 horse air cleaner which fits fine except there is no place for a breather hose on the 36hp oil fill. Also there is no warm air hook up.
_________________ 1960 Beetle And 1679cc DP W-100 & Dual Zeniths! |
Posted: Fri Dec 20, 2019 6:02 pm Post subject: Re: Beetle Air Cleaners - picture reference thread |
Danwvw wrote: |
Could be the intake upper pipe was bent forward. _________________ In Stereo, Where Available! |
Jonasckx Samba Member
Posted: Mon Jan 20, 2020 3:00 pm Post subject: Re: Beetle Air Cleaners - picture reference thread |
Danwvw wrote: |
What about this air cleaner on an 1960 Beetle is it correct? It doesn't seem to fit because the flat spot side is too tight to the fan shroud, could this just be my manifold on wrong or should I turn it with it's flat spot away from the shroud so it fits. https://www.thesamba.com/vw/gallery/pix/1981244.jpg
That is not the correct one, the one from Navydave73's post that should be on an '60 Beetle
https://www.thesamba.com/vw/gallery/pix/1886238.jpg
Here's a picture of my Beetle with the correct one
_________________ '60 L 346 type 1 |
Posted: Wed Mar 11, 2020 4:37 pm Post subject: Re: Beetle Air Cleaners - picture reference thread |
Early 1961 only air cleaner with no breather nipple.
41mb04tj Samba Member
Joined: January 28, 2020 Posts: 7 Location: Marin County, CA
Posted: Fri Apr 10, 2020 11:38 pm Post subject: Re: Beetle Air Cleaners - picture reference thread |
bnam wrote: |
71 Airfilter and decals. |
I see this is a old thread, but Im researching. Could you tell me what that little weight is on the air filter suction side? |
thomas. Samba Member
Joined: July 31, 2010 Posts: 1291 Location: South West (Pa.)
Posted: Sat Apr 11, 2020 1:51 am Post subject: Re: Beetle Air Cleaners - picture reference thread |
The weight keeps intake closed from outside air while idleing drawing in heated air from the pre heat hose/tube. When you give it some gas (hit the fast pedal) the suction opens the intake weight. |
pastellgreen Samba Member
Joined: January 06, 2012 Posts: 1048 Location: Germany
Posted: Wed Apr 22, 2020 1:02 am Post subject: Re: Beetle Air Cleaners - picture reference thread |
I don't know, if it belongs here, if not, please advice me.
I was searching for the seal 113 129 625 A for the early 40 hp air cleaner and could not find it in all of the online beetle stores in Europe. But VW Classic Parts sells them:
EverettB Administrator
Joined: April 11, 2000 Posts: 69809 Location: Phoenix Metro
