teej Samba Member
Joined: November 26, 2010 Posts: 897 Location: Seattle
Posted: Wed Feb 01, 2012 12:41 pm Post subject: source for spade terminal with locking tab? |
The kind with the little tab that must be pushed down to release the spade from a plastic wiring harness connector? I have had several occasions where I have needed to remove a female spade from the harness, and crimp on a fresh one. I have been unable to find female 1/4" spades with the little tab that locks them into the plastic harness. I have made do with regular spades and taken extra care when connecting, but having a box of the OE style would be better. Anyone know where to get some? Thus far my internet search has struck out, but maybe I don't know what they are properly called. Anyone? Thanks. _________________ 1986+ Wolfsburg Weekender Pop-Top 2.3 WBX Manual Trans |
Vanagon Nut Samba Member
Joined: February 08, 2008 Posts: 10371 Location: Sunshine Coast B.C.
r39o Samba Polizei
Posted: Wed Feb 01, 2012 1:33 pm Post subject: |
It is an AMP part.
I forget the series, but Google should be your friend.
You can (used to) get them from the VW dealer for expensive.
Buy thousands from an AMP dealer
Or get them from a surplus outlet (which I used to do.)
I thought I saw a place on line that used to sell Bosch FI loose electrical parts and they had such things too for sort of expensive. _________________ "Use the SEARCH, Luke" But first visit the Vanagon FAQ!
BillM Samba Member
Joined: June 18, 2004 Posts: 1381 Location: Stonington,CT
Posted: Wed Feb 01, 2012 2:10 pm Post subject: |
You can get a kit here http://www.vintageconnections.com/
for about 80.00
Scott at Germansupply.com sells various quanities from singles,six packs
and up.
Their out there just gotta find them. I try and convert my connections to
a gm/ford factory style connector. The trade name slips my mind
right now but it's just like what was used on my Zetec harness.
A bit pricey for the kit I bought but has multiple size connectors
in various gauges. _________________ Bill M
87 Westy |
trailnewt Samba Member
Joined: February 17, 2008 Posts: 248 Location: Northern California
I have ordered the AMP connectors in small quantities from onlinecomponents.com
Brent _________________ '87 Syncro Westy TDI
Too many bicycles
Maybe an old unicycle around here somewhere |
thatvwbusguy Samba Member
Joined: April 18, 2007 Posts: 1712 Location: Newmarket, New Hampshire
Posted: Wed Feb 01, 2012 2:21 pm Post subject: |
The technical name is an open barrel locking female faston. If you only need a couple dozen or so, I can hook you up. I buy thousands at a time, so I buy from a terminal wholesaler. Otherwise, I have gotten small orders of specialty stuff from here:
http://easternbeaver.com/Main/Elec__Products/Terminals/Open_Barrel/body_open_barrel.html#receptacles
All of the components I have gotten from them have been good quality and the pricing is very fair. The main problem with buying just a few pieces at a time is the cost of shipping vs. the value of the goods.
There are several different models of 1/4" connectors to choose from based on the gauge of the wire you will be crimping. For use in your van, the 42100-2 is good for 18-14GA wire and the 60253-2 is good for 14-10GA wire and will snap into most VW plastic housings.
You will also need a specific type of crimper to use these terminals. These can range from about $25.00 to $400.00+ Here is an example of what you will need for occasional use:
http://www.amazon.com/Sargent-Crimper-Open-Barrel-14-24/dp/B0000WUN1O
These crimpers will require you to make two separate crimps on each terminal, but I used a set just like this with good results for a while before I bought a few nicer, more expensive crimpers. _________________ Jay Brown
'85 Zetec Westfalia
Newmarket, NH
If you want others to be happy, practice compassion.
If you want to be happy, practice compassion. |
bquigs Samba Member
Joined: March 01, 2008 Posts: 116 Location: Kittery, ME
Posted: Wed Feb 01, 2012 2:30 pm Post subject: |
You may be surprised to find these at your FLAPS, I was. I used them to re-purpose some old VW relay blocks. You would have better luck if you weren't at one of the big chain stores. They are WAY overpriced though like 4 bucks for 4 of them so if you need more than a few its probably best to get them online. _________________ -----------------
87 Syncro Zetec |
presslab Samba Member
Joined: September 29, 2008 Posts: 1730 Location: Sonoma County
Posted: Wed Feb 01, 2012 2:32 pm Post subject: |
thatvwbusguy wrote: |
There are several different models of 1/4" connectors to choose from based on the gauge of the wire you will be crimping. For use in your van, the 42100-2 is good for 18-14GA wire and the 60253-2 is good for 14-10GA wire and will snap into most VW plastic housings. |
Another possible option. Digi-Key has both of these in stock, pick USPS first class shipping for about $2.50. _________________ 1986 Vanagon Westfalia EJ25
1988 Subaru GL-10 EJ20G --- 2000 Honda XR650L
2010 Titus El Guapo --- 2011 On-One 456 Ti |
crazyvwvanman Samba Member
Joined: January 28, 2008 Posts: 9923 Location: Orbiting San Diego
Posted: Wed Feb 01, 2012 2:43 pm Post subject: |
Around me even the big chain FLAPS carry them, in a small pack on the electrical rack, labeled as Ford connectors for some reason. Only for small gauge wire so I solder them on larger wires if I need to. Not perfect but workable.
Mark
Last edited by crazyvwvanman on Wed Feb 01, 2012 3:04 pm; edited 1 time in total |
teej Samba Member
Posted: Wed Feb 01, 2012 2:52 pm Post subject: |
Wow, I went out to the shop and came back inside to find all of these leads already! Thanks all! _________________ 1986+ Wolfsburg Weekender Pop-Top 2.3 WBX Manual Trans |
Posted: Thu Feb 02, 2012 12:13 am Post subject: |
crazyvwvanman wrote: |
Mark |
That's one thing I love about visiting the U.S. Great selection! That said, maybe my local FLAPS in North Vancouver had those connectors hidden away. Somewhere.....
1988 West DIY 50º ABA
VE7TBN |
rubbachicken Samba Member
Posted: Thu Feb 02, 2012 6:24 am Post subject: |
sorry to hijack,
what is the correct tool for removing these crimp connectors from the connector blocks _________________ lucy our westy
lucy's BIG adventure
meet 'burni'
619 201 0310 or 617 935 4182 |
Posted: Thu Feb 02, 2012 7:06 am Post subject: |
Hi Mark,
A small flathead jewelers screwdriver will do the job nicely. Just push it into the recessed groove on the plastic housing and the locking tab will bend in to release the terminal. _________________ Jay Brown
'85 Zetec Westfalia
Newmarket, NH
