hobbybob517 Samba Member
Joined: June 02, 2011 Posts: 1194 Location: Netherlands
Posted: Thu Feb 02, 2012 6:02 am Post subject: Opinion on central locking |
Hi guys,
i was looking on the web, and i found this cool remote central locking kit,
i was wondering if i should get it,
my friends warned me about these aftermarket central door locks as they might burn down the car?
but then again my friends are mostly a bunch of morons who wire 20000 watts of speakers and amps to a 20 year old opel which is worth about as much as a opened can of beer.
_________________ THE BUILD http://www.thesamba.com/vw/forum/viewtopic.php
SBD wrote: |
3 million rpm? Well there's your problem! No wonder it blew up! |
runamoc Samba Member
Joined: June 19, 2006 Posts: 5601 Location: 37.5N 77.1W
Posted: Thu Feb 02, 2012 7:25 am Post subject: |
Those solenoids need to push/pull the lock on a door. Are they up to it? _________________ Daily driver: '69 Baja owned 44 yrs - Plan B: '81 Rabbit Diesel LS Deluxe - Plan C: '72 Ghia
Yard Art: 2 Sandrails
Outback: '69 Ghia - '68,'69,'70,'72 Beetle - '84 Scirocco, GTI - Pair of '02 Golfs-
VW Wiring = It's just wires |
Posted: Thu Feb 02, 2012 7:26 am Post subject: |
i don't know,
i guess its pulling the rod on the door lock _________________ THE BUILD http://www.thesamba.com/vw/forum/viewtopic.php
SBD wrote: |
GNandGS Samba Member
Joined: September 25, 2006 Posts: 292 Location: Kuala Lumpur
Posted: Thu Feb 02, 2012 7:38 am Post subject: |
I'm of the mind that the aftermarket in general has solutions that work... I'll add to that though:
A friend working at a dealer seems to think many issues including no-start are caused by aftermarket alarms etc. Could be lots of reasons for that and no point debating anecdotal stuff.
So get something decent and do a good job on the install. If it looks like trailer wiring expect trouble. _________________ http://www.volksriders.org http://hecmalaysia.com |
Posted: Thu Feb 02, 2012 7:41 am Post subject: |
it looks pretty descent , i'm not actualy going to install the alarm, it just comes with the kit,
had the aftermarket alarm-no start problem on my t-bird, i'll never do that again. _________________ THE BUILD http://www.thesamba.com/vw/forum/viewtopic.php
SBD wrote: |
Posted: Thu Feb 02, 2012 7:43 am Post subject: |
The wires will be 'exposed' when the door opens. If not protected correctly there the wires could short and set the door panels on fire. _________________ Daily driver: '69 Baja owned 44 yrs - Plan B: '81 Rabbit Diesel LS Deluxe - Plan C: '72 Ghia
Posted: Thu Feb 02, 2012 7:46 am Post subject: |
yea it would be a good idea to run a bit of rubber hose over the wires,
i got plenty of cool looking flexhose _________________ THE BUILD http://www.thesamba.com/vw/forum/viewtopic.php
SBD wrote: |
Posted: Thu Feb 02, 2012 10:17 am Post subject: |
The best install I've seen has been a short piece of copper pipe/tubing fastened in a hole on the side of the door and the other end sliding back and forth in a hole in the "a" pillar that had a groment 'seal'. _________________ Daily driver: '69 Baja owned 44 yrs - Plan B: '81 Rabbit Diesel LS Deluxe - Plan C: '72 Ghia
Posted: Thu Feb 02, 2012 10:21 am Post subject: |
sounds like a good idea, if i do order this kit, i will surely do the pipe-gromet thing _________________ THE BUILD http://www.thesamba.com/vw/forum/viewtopic.php
SBD wrote: |
jhoefer Samba Member
Joel Samba Member
Joined: September 04, 2006 Posts: 11099 Location: NSW Australia
Posted: Thu Feb 02, 2012 12:56 pm Post subject: |
I've had that same kit in my bug for 12 years now, works well.
As noted the only fire risk would be shorting the wires where they go through the door if they aren't adequately shielded but even that would only be if you didn't have a fuse wired in which is just common sense. _________________ Quick little bug, you got a Porsche motor in that?
1974 Germanlook 1303 2.5 Suba-Beetle |
CarlIseminger Samba Member
Joined: May 12, 2008 Posts: 833 Location: Grand Forks, ND
Posted: Thu Feb 02, 2012 2:36 pm Post subject: |
If I ever have to remove the door panels for anything, I am going to install a set of central locks with remote control. I don't need them for when I am IN the car as it is so easy to reach across, but it would be nice to have the remote so I don't have to wear out the key in the door lock. And of course, it is far easier to click then to work the key in and then turn it. |
Joel Samba Member
Posted: Thu Feb 02, 2012 3:49 pm Post subject: |
Trust me when your bug is parked out in pouring rain remote keyless entry is the greatest thing ever.
You do get some strange looks though in carparks when people see you unlock a 40 year old car by remote though _________________ Quick little bug, you got a Porsche motor in that?
mnakandala Samba Member
Joined: September 28, 2009 Posts: 245 Location: Sri Lanka
Posted: Thu Feb 02, 2012 8:36 pm Post subject: |
Joel wrote: |
You do get some strange looks though in carparks when people see you unlock a 40 year old car by remote though |
x2 _________________ 1964 bug
1983 mitsubishi Delica |
Posted: Fri Feb 03, 2012 3:14 am Post subject: |
yea, the whole reason i was going to get it, was mainly because i wanted that cool factor of a 40 year old car going bleep bleep!
second i wanted this kit because my doors both have a different key, and so does my ignition. _________________ THE BUILD http://www.thesamba.com/vw/forum/viewtopic.php
SBD wrote: |
Posted: Fri Feb 03, 2012 3:15 am Post subject: |
Jezz, i hope that's hongkong dollars man. _________________ THE BUILD http://www.thesamba.com/vw/forum/viewtopic.php
SBD wrote: |
TjdTaylor Samba Member
Joined: July 04, 2011 Posts: 1727 Location: Niagara Falls, Ontario
Posted: Fri Feb 03, 2012 1:24 pm Post subject: |
hobbybob517 wrote: |
Jezz, i hope that's hongkong dollars man. |
well, that is some pretty clasy looking braided wire _________________ 1974 SuperBeetle Build
Beetle Bums VW Club Member
Jamies74sb wrote: |
I can't see myself cutting up my super beetle . Maybe a oval or 61 or so with the small windows |
'69Custom Samba Member
Joined: September 16, 2008 Posts: 2497 Location: Ventura, California
Posted: Fri Feb 03, 2012 1:45 pm Post subject: |
TjdTaylor wrote: |
well, that is some pretty clasy looking braided wire |
I'd be willing to bet it wouldn't be difficult to fab something similar using braided stainless household water supply lines. Those have a rubber hose running inside under the stainless sheath and might cost $5 apiece before mods. _________________ -Tim
1969 Frankenbug
1965 Ford Mustang
:2gunfire: F-U-M-P!
~"I thought I was wrong once, but I was mistaken." ~The Boss
Please excuse any typos as my iPhone doesn't speak English very well.
tham64 wrote: |
Why tune a big round again and again????? For me.... 1 hour will solve the case |
www.endlesscustomz.com |
Posted: Sat Feb 04, 2012 2:05 am Post subject: |
'69Custom wrote: |
TjdTaylor wrote: |
I'd be willing to bet it wouldn't be difficult to fab something similar using braided stainless household water supply lines. Those have a rubber hose running inside under the stainless sheath and might cost $5 apiece before mods. |
exactly what i was thinking! _________________ THE BUILD http://www.thesamba.com/vw/forum/viewtopic.php
SBD wrote: |
Posted: Sat Feb 04, 2012 12:21 pm Post subject: |
'69Custom wrote: |
TjdTaylor wrote: |
exactly what i was thinking! |
I might just start playing with that if I ever get some free time. I really have too many fab ideas rolling around in my head already though. My main concern over the notion is that braided lines can eventually fray a bit, snagging on any rubber grommet I'd install in the jam and maybe tearing up the rubber over time. _________________ -Tim
1969 Frankenbug
1965 Ford Mustang
:2gunfire: F-U-M-P!
tham64 wrote: |
