71 Super on a 74 pan
Vinnems
Vinnems is offline
PostPosted: Fri Feb 03, 2012 12:52 am    Post subject: 71 Super on a 74 pan Reply with quote
Want to do this as easy as possible. I put a 71 Super body on my 74 pan. Everything on the 74 pan is new. Spring, strut cartridge, bushings, etc from Topline along with a disc brake kit. Can I simply enlarge the hole on the body so the strut mount will fit and call it a day? If not, can I simply swap strut mounts?
I'm running stock wheels and tires, if that matters. The Sports+ springs lower the front an inch or so, I think.
Thanks!
Joel
Joel is offline
PostPosted: Fri Feb 03, 2012 3:09 am    Post subject: Reply with quote
Just run the early upper bearing assemblies, I did the same thing with mine.
A lot easier than opening up the holes and also if you use the early upper spring hats it will lower it about 1" too.
Quick little bug, you got a Porsche motor in that?
1974 Germanlook 1303 2.5 Suba-Beetle
