Pushrod tubes German vs. aftermarket ones
EMPIImp69
EMPIImp69 is offline
PostPosted: Mon Feb 06, 2012 7:57 am    Post subject: Pushrod tubes German vs. aftermarket ones Reply with quote
Any big difference in quality in German pushrod tubes compared to the cheaper aftermarket ones? Is the metal thicker/stronger? Any other reasons to use German ones over the aftermarket ones? thanks
1963 Ragtop Bug
MURZI
MURZI is offline
PostPosted: Mon Feb 06, 2012 8:01 am    Post subject: Reply with quote
My favorite for mild/stock builds is just the stainless windage empi tubes. They look nice and work great. I polish them before the install... Laughing
62 vert
2276
Tim’s welded heads
45 Dells
A1 sidewinder
Fk44 cam
yamaducci
yamaducci is offline
PostPosted: Mon Feb 06, 2012 8:45 am    Post subject: Reply with quote
I would always pick German first unless it didn't fit the situation. Meaning if you needed "Windage tubes", Wide mouth tubes for Hight Lift or drive in salt and buy stainless to avoid rusting.
Always use original seals.
-John Cox
My 2498 Turbo Re-Build Thread: http://www.thesamba.com/vw/forum/viewtopic.php?p=5578697#5578697
3rd Brake Light Safety Stars- I still have a couple with blue light left. Email me if interested.
baked beetle
baked beetle is offline
PostPosted: Mon Feb 06, 2012 9:22 am    Post subject: Reply with quote
On the last 5 builds (haven't leaked a drop ) I have had good luck with Stainless tubes and empi silicone seals, as well as wolfsburg west silicone sump plate seals.
These days people like me are hard to find- we don't give a damn what you think, about what we think. - JR
____________________
66' His
57' Theirs
63' Hers
62' Drag Bug - Theirs 13.1 @ 101 mph (GONE)
andy198712
andy198712 is offline
And don't polish them, flat black in a thin coating Smile
craigman
craigman is offline
PostPosted: Mon Feb 06, 2012 9:28 am    Post subject: Reply with quote
Hmm, I didn't know you could even get german tubes..
VIN
VIN is offline
PostPosted: Mon Feb 06, 2012 9:32 am    Post subject: Reply with quote
empi silicone seals rock! gonna have to try the silicone sump plate seal.
Co-owner, 2 Brothers Guns
[email protected]
Click to view image
Buellistic
Buellistic is offline
PostPosted: Mon Feb 06, 2012 9:56 am    Post subject: Reply with quote
The white silicon seals hold up for replacing the heads too. I don't know how many rebuilds they can be used though.
As for tubes, they're all pretty much equal I would think. It's a really simple part, hard to get wrong.
neil68
neil68 is offline
PostPosted: Mon Feb 06, 2012 7:21 pm    Post subject: seals Reply with quote
Ditto. The transparent "whitish" EMPI silicone pushrod seals are the best I've ever come across. Maybe they're working on their quality control Wink
Neil.
Der Kleiner Rennwagens
68 Beetle 2332 cc, 204 WHP
12.5 seconds @ 107 mph
Dynojet Test: https://www.youtube.com/watch?v=M9B_H3eklAo
earthquake
earthquake is offline
PostPosted: Tue Feb 07, 2012 10:34 am    Post subject: Reply with quote
Does any body make fined aluminum PR tubes?
That way they would act as mini oil coolers.
Casey
74 CLASS 11 LOOK-A-LIKE
69 DUNE BUGGY
79 INTERNATIONAL SCOUT II
05 SCION XB SERIES RELEASE 2[#437]
95 Chevy C3500 dually
98 Ford E150
Link to Kelly J. Nolte 3/20/53 - 11/6/08
https://time-zonelabs.blogspot.com/p/about-kelly.html
DEATH TO CHINGERS!
[From a military recruitment poster in the novel "The Stainless Steel Rat" By Harry Harrison]
jfats808
jfats808 is offline
PostPosted: Tue Feb 07, 2012 10:45 am    Post subject: Reply with quote
The ss empi tubes are my preference as well.
2276 IDA's 86C 11-1 DD !
2017 48 Trijet DRLA's W125
Rockstar Suzuki wrote:
You might as well put 10 year build in your bullshit sig, as it will NEVER run. Also your a dick
You can always learn something new, even from a fool.
Check your oil levels routinely!
slalombuggy
slalombuggy is offline
PostPosted: Tue Feb 07, 2012 11:49 am    Post subject: Reply with quote
Yep, it's the only place I haven't had a leak from.....SS windage tubes and silicone seals
brad
the2ndcashboy
the2ndcashboy is offline
PostPosted: Tue Feb 07, 2012 12:08 pm    Post subject: Reply with quote
Casey
Why not just run hard lines to a remote oil filter and then put fins on them Rolling Eyes ?
I think the whole "let's put fins on it to dissipate heat" thing gets taken a little too far sometimes.
Oh and I've also not had any leaks from my EMPI windage tubes and seals.
SRP1 wrote:
You see....... He talks in code and translation requires a priest, geologist, astronomer, biophysicist, and Indiana Jones.
modok wrote:
If anything comes out perfect it just means your measuring tools are substandard.
earthquake
PostPosted: Tue Feb 07, 2012 4:01 pm    Post subject: Reply with quote
Casey
Hey, It worked on a Thompson Submachine Gun Very Happy
Casey
69 DUNE BUGGY
98 Ford E150
DEATH TO CHINGERS!
slalombuggy
PostPosted: Tue Feb 07, 2012 6:02 pm    Post subject: Reply with quote
Hey Casey, I thought you'd be trying to minimise drag on the parts on your car????? Fins are just going to increase turbulence under the motor and slow you down Cool
brad
LyleGB
LyleGB is offline
PostPosted: Tue Feb 07, 2012 10:12 pm    Post subject: Reply with quote
I think they would act as maxi heat soakers since they're right in the path of the shroud's exhaust.
