thewump Samba Member
Posted: Mon Feb 06, 2012 5:43 pm Post subject: Exterior Sliding Door Handle Questions (and anyone got one?) |
Hi All, I guess the freeze + me > tensile stength of outer sliding door handle and it snapped.
Question:
- I found the steps to remove the handles, but can anyone confirm whether or not the lock barrel is transferable to a replacement?
- Anyone got one lying around that they want to sell me cheap? Can't stomach $80 - $100 for a new one!
Thanks in advance
Keith (in Denver) _________________ 87 Weekender |
Timwhy Samba Member
?Waldo? Samba Member
Posted: Mon Feb 06, 2012 6:03 pm Post subject: |
Switching the lock cylinder is easy. Pull the handle, there's a tiny set screw in the side, usually covered by grime. |
crazyvwvanman Samba Member
Joined: January 28, 2008 Posts: 9940 Location: Orbiting San Diego
Posted: Mon Feb 06, 2012 6:06 pm Post subject: Re: Exterior Sliding Door Handle Questions (and anyone got o |
Since you only need the shorter later handle you should find a used one with ease for around $40. 80-84 used a longer handle known for snapping off. You need the 85-91 shorter one that only rarely break.
Mark
thewump wrote: |
Question:
Thanks in advance
Keith (in Denver) |
70coupyel Samba Member
Joined: September 06, 2006 Posts: 1657 Location: So.Cal
Posted: Mon Feb 06, 2012 8:57 pm Post subject: |
The short sliding door handles you can buy new. Check our Vanagon vendors. Here is one example here.
Edit fixed link _________________
TheAndante wrote: |
Saying that specs are different than dimensions doesn't make sense. Porsche specs/VW specs/engineering specs are nothing but a series of dimensions,sizes,percentages,measurements, etc. |
http://www.thesamba.com/vw/forum/viewtopic.php?t=338946&highlight=
70 KG Coup
83 Westy Waterboxer
Posted: Tue Feb 07, 2012 11:16 am Post subject: |
Thanks all.
Keith _________________ 87 Weekender |
r39o Samba Polizei
Posted: Tue Feb 07, 2012 11:26 am Post subject: |
Do not forget the after market "grommet." I have brain fade, but I know you can get them at fleaharbor. Like $20 but keeps the handle fitting well. I am sure someone else will remember better than me. _________________ "Use the SEARCH, Luke" But first visit the Vanagon FAQ!
Tom Powell Samba Member
Joined: December 01, 2005 Posts: 4855 Location: Kaneohe
Posted: Wed Feb 08, 2012 10:09 am Post subject: |
r39o wrote: |
Do not forget the after market "grommet." I have brain fade, but I know you can get them at fleaharbor. Like $20 but keeps the handle fitting well. I am sure someone else will remember better than me. |
I got mine on ebay
VW DELRIN Vanagon sliding door handle bushing spacer 92 (300301769275)
Seller: Member id mark1svc
Aloha
tp |
Vsyevolod Samba Member
Posted: Fri Feb 10, 2012 1:40 pm Post subject: |
I too just broke off my side door handle in the 'Great Seattle Snowstorm of 2012'.
New OEM handles are available at Bus Depot for $70 and the rubber escutcheon is $8.
I called their service department about replacing the original lock and they said they didn't think it was possible. I checked here at the Samba and the general opinion is that it is possible, though there was some uncertainty about it. Has anyone here successfully replaced their side door lock into a new side door handle?
Stephen
turbotransporter Samba Member
Joined: February 19, 2006 Posts: 459 Location: Bainbridge Island WA
Posted: Fri Feb 10, 2012 2:05 pm Post subject: |
Vsyevolod wrote: |
Stephen
Yes, you can remove the lock from your broken handle and install it in a replacement handle.
The Bus Depot has a "Service Department"???
Based solely upon that answer I would NOT be asking them any additional Vanagon repair questions! Ron is a big supporter of the Vanagon community but I don't believe they are in the service/repair business.
If you want a good used handle check with Kirk @ North Westy in Renton or Jamal @ Absolute German in South Seattle. |
squeegee_boy Samba Member
Joined: April 27, 2008 Posts: 762 Location: Langley, BC, Canada
Posted: Fri Feb 10, 2012 3:55 pm Post subject: |
Vsyevolod wrote: |
...and the rubber escutcheon is $8.
I *highly* recommend the Delrin bushing mentioned above. It'll completely change the feel of your handle from floppy to square and precise. The effect is most pronounced ont he old style doors, but it helps the new ones too. It's one of the best $20 I've ever spent on my van.
Robyn _________________ 1984 FrankenSyncro Westy. EJ25 RMW kit
1971 Super Beetle with an EJ22. Oh yes. Daily driver |
msinabottle Samba Member
Posted: Wed Feb 15, 2012 4:16 pm Post subject: Another vote on the Delrin escutcheon |
You guys convinced me--and I hated how loose Winston's exterior door handle always felt. Ordered the Delrin bushing off of E-bay, he has TWO offered, for the early and the late. Mark at once sent a note it was on its way, and to look for a little green-labeled package, which arrived today.
Inside that (the package itself shows a clever mind) was a useful little blue sheet of instructions, which I followed. I have a right angle ratchet screw driver, so I only had to loosen Winston's interior sliding door panel a bit to get that in to remove the outer handle's screw. Mark suggests using motor oil to lubricate the Delrin, I was worried about the acid in 'detergent' motor oil and used white lithium, Mark answered my note and thanks by saying that the Lithium dries out and the oil is safe for Delrin. I did use BLUE Loc-Tite on the screws for both door handles, both of which were loose...
The improvement is incredible. It no longer feels like the handle's about to fall off the door every time I use it. Mark is doing a very good thing by supporting the Vanagon community with a useful, well-thought out upgrade product.
scottf3334 Samba Member
Joined: May 26, 2006 Posts: 205 Location: Davenport, FL
Posted: Wed Feb 15, 2012 6:49 pm Post subject: |
Funny, I just put mine on yesterday after reading this thread
The handle now feels solid. Would recommend Marks bushing to everyone, especially if you have people other than yourself opening the door _________________ 84 Westy
78 Super vert
87 Westy Zetec |
randywebb Samba Member
Posted: Wed Feb 15, 2012 8:01 pm Post subject: |
how do you tell if you need a round one or an oval one?? _________________ 1986 2.1L Westy 2wd Auto Trans. |
Posted: Wed Feb 15, 2012 8:37 pm Post subject: |
Vsyevolod wrote: |
I called their service department about replacing the original lock and they said they didn't think it was possible. I checked here at the Samba and the general opinion is that it is possible, though there was some uncertainty about it. Has anyone here successfully replaced their side door lock into a new side door handle? |
What uncertainty? I stated that it was easy and then gave the pertinent info on how. Yes, I've replaced the lock cylinder on several vanagon handles. It takes less than 15 minutes if you know what you're doing. |
Posted: Wed Feb 15, 2012 8:42 pm Post subject: |
70coupyel wrote: |
The short sliding door handles you can buy new. Check our Vanagon vendors. Here is one example here. |
Hmmm, what's the link? |
Posted: Wed Feb 15, 2012 8:54 pm Post subject: |
Click on the word "Here"!! _________________
TheAndante wrote: |
70 KG Coup
83 Westy Waterboxer |
Posted: Wed Feb 15, 2012 9:01 pm Post subject: |
Yup. It takes me to a camera control....
AXIS 214 PTZ Network Camera |
shadetreetim Samba Member
Joined: January 10, 2011 Posts: 1994 Location: Riverside, California
Posted: Wed Feb 15, 2012 9:10 pm Post subject: |
Andrew A. Libby wrote: |
Those AXIS Cameras are fun to play with. Looks cold there. I didn't see any Vanagon parts though... _________________ Tim Potts
Doing my best every time I drive it to dispel the myth these Vanagons have to be slow!
'89 Vanagon Bluestar/Country Homes 1.8T & .77 4th
'74 Jeep CJ5 |
