HamburgerBrad Je suis Napoléon!
Joined: February 21, 2003 Posts: 6957 Location: SoCal
Posted: Fri May 16, 2003 11:57 pm Post subject: 12v flywheel clearancing |
i recently installed a 1641 with a 12v flywheel on a 65? bus. i test fitted the flywheel into the bellhousing of the tranny to see if any material would need to be removed, it fit fine. the engine is in and it wont turn, even if it's push started. i think the flywheel is bindind up against the tranny. where should material be removed from the case, i know with the T1 there is 4 spots, is it the same with a bus tranny and where do i do it? A quick response would be appreciated as i am pulling the engine on sunday. Thanks.
Brad |
Scotts 63 23 Samba Member
Joined: March 09, 2002 Posts: 1280 Location: Somewhere in my mind... The Real er Laguna Beach :)
Posted: Sat May 17, 2003 6:14 am Post subject: 12v flywheel clearancing |
When I had my tranny done by Rancho, my housing was cracked and I told them that I had a 12v flywheel so I figured it had been clearanced. They didn't clearance it and the engine went in easily, but just like yours it wouldn't turn, so it sounds like the same problem. I clearanced it all around on the high spots. I can't recall if there were 4 spots, but it is pretty easy to see where it needs to be taken down. |
k29349@yahoo Samba Member
Joined: May 10, 2003 Posts: 652 Location: Inman, S.C.
Posted: Sat May 17, 2003 6:28 am Post subject: 12v flywheel clearancing |
Yes, it is the same as a bug. |
Posted: Sat May 17, 2003 12:26 pm Post subject: 12v flywheel clearancing |
problem solved, i hope, but where are the 4 spots?
Brad |
zackG Samba Member
Posted: Sat May 17, 2003 12:48 pm Post subject: 12v flywheel clearancing |
like scott said it's pretty easy to see, especially since your flywheels been grindin' up against it. |
Posted: Sun May 18, 2003 10:34 am Post subject: 12v flywheel clearancing |
alright, thanks everyone, i hope it does the trick. off to work i go. |
Stocknazi Samba Member
Posted: Sat Jul 29, 2006 5:17 am Post subject: |
i need to clearance my belhousing in my 66 bus to accept a 1600 single port with a 12 volt flywheel. i will probably pull the flywheel to replace the pilot bearing and install a new oil seal b/c i am already in there.
i have never done this clearancing before so i am a little timid about grinding on my tranny. i am thinking i can hold the flywheel up to it and see where i need to grind. approx. how much material will i need to remove? will this make the bellhousing weaker and cause stress cracking?
thanks for your help _________________ WANTED:
"Resistance to tyrants is obedience to God."
Thomas Jefferson |
chazwood Samba Member
Joined: February 11, 2006 Posts: 678 Location: The last word in edgewise
DubStyle SBS Hit Squad
Joined: July 26, 2003 Posts: 6250 Location: SBS headquarters: Missery
Posted: Sat Jul 29, 2006 9:57 am Post subject: |
HBB what bus do you speak of? Did you move up in the VW world and buy that logo'd panel? _________________ Anthony
SBS #1
SBS #1 on FB
"The original & best lowered Split Bus website/club" |
Posted: Sat Jul 29, 2006 4:17 pm Post subject: |
thanks for the link, i searched and dont see how i missed that one.
i found out today i have an auto starter, 12 volt. part # starts with 003.
the po said he converted to 12 volt. i have no idea what motor he installed with it bc it was missing. i guess ill get a new 12 volt starter bushing and install it anyway just in case my auto starter decides to take a crap on me. sounds like there is nothing to the grinding. wish me luck on monday _________________ WANTED:
Thomas Jefferson |
mulk Samba Member
Joined: November 19, 2003 Posts: 333 Location: Your rear-view mirror
Posted: Sat Jul 29, 2006 8:56 pm Post subject: |
We just took an old flywheel and put it over the shaft, turned over the started and applied light pressure, and let the flywheel do all the work. Equal clearance all around in about 30 seconds. Just wipe ALL shavings out and clean.
SAFETY WARNING!!!
Keep all shirts, rags, dreads, ties, mullets, and fingers away from the started gear. _________________ Eric - Defender of Injustice
http://www.lasvegasvwclub.com/ |
Posted: Sat Jul 29, 2006 10:26 pm Post subject: |
DubStyle wrote: |
HBB what bus do you speak of? Did you move up in the VW world and buy that logo'd panel? |
Quote: |
Posted: Fri May 16, 2003 11:57 pm |
shit, i dont even remember what bus that was? _________________ OGST | CU05 | OGJHC
1970 baja|1953 oval
Wanted: two beat up, ugly, curb rashed 6" phone dial wheels |
Zundfolge1432 Samba Member
Posted: Mon Jul 31, 2006 8:26 am Post subject: |
mulk wrote: |
SAFETY WARNING!!!
Keep all shirts, rags, dreads, ties, mullets, and fingers away from the started gear. |
I am going to call this bullshit as you make no mention of gland nut to center the flywheel on the mainshaft.... And as you described it the starter would simply bind or worse hurt your hands .......
The foolproof safe way if people dont know where or how much to cut is this--> leave off the clutch pressure plate and install engine just lining up with trans , turn engine over using a big wrench at the crank pully nut then tighten and turn tighten and turn untill you are all in ..
Now remove the engine clean out all the shavings and install clutch pressure plate and pat yourself on the back for a job well done.. No it wont weaken anything as the material removed is negligible and if done as I've described won't be too much, also is safe from fire because some folks have become carried away using die grinders and igniting the magnesum alloy case........ It make a spectacular fire that you can't put out and don't do like one dumbass I know and piss on it, he ended up in the emergency room with burns to his jewels........
Jim- |
Posted: Mon Jul 31, 2006 8:56 am Post subject: |
Are you that dense? I'm pretty sure they installed the other stuff. And yes it can be done this way. There is another thread here on the Samba about doing that exact thing. _________________ Anthony
SBS #1
SBS #1 on FB
Posted: Mon Jul 31, 2006 4:34 pm Post subject: |
good suggestion tightening the engine up and turning the crrank nut. i think that method sounds a little safer than using the starter. i guess you could line the engine up and barely start the nuts and use the starter to turn over the motor a few times, then tighten the nuts a little then repeat.
i really dont like the idea of starting a fire. _________________ WANTED:
Thomas Jefferson |
mulk Samba Member
Posted: Mon Jul 31, 2006 4:41 pm Post subject: |
Zundfolge1432 wrote: |
mulk wrote: |
SAFETY WARNING!!!
Jim- |
Call it what you will.............. This is NOT a high-speed operation. Between the tip of the mainshaft fitting within the flywheel, and the flywheel fitting within the lip of the tranny case, its pretty much a self centering task. The gearing on the starter and flywheel won't send it spinning like a top. It's LOW speed. Don't be fooled.
So if you can get your nards back from your gal, maybe you should give it a try before calling "Bullshit"...........
Safety warning still applies! _________________ Eric - Defender of Injustice
SkooobaSteve Samba Member
Joined: March 23, 2005 Posts: 3152 Location: Dothan Alabama
davebuckholts Samba Member
Joined: February 06, 2004 Posts: 2173 Location: South GA
Posted: Tue Aug 01, 2006 7:44 am Post subject: |
LJ just finished this on his DD panel. Ground it out with a die grinder and a burring bit. Still had to do some grinding with the flywheel.......tighten til you can barely spin with the pully nut; turn, turn turn. Repeat.
BTW, the trans case is AL, isn't it? Don't think that catches fire like Magnesium, does it? _________________ My '66 RHD Japanese bug build..which has stalled!
http://www.thesamba.com/vw/forum/viewtopic.php?t=471759&postdays=0&postorder=asc&start=0 |
Erik G Samba Member
Joined: October 16, 2002 Posts: 13270 Location: Tejas!
Posted: Tue Aug 01, 2006 7:49 am Post subject: |
no, the trans case is mag. Ask norcalnick, he was grinding one about a month ago, slipped and hit the studs, and went up in flames. luckily it just burnt his nasty body hair, no real harm was done _________________ Stop dead photo links! Post your photos to The Samba Gallery! |
