EMPIImp69 Samba Member
Joined: April 17, 2006 Posts: 3374 Location: Dirty Jersey
Posted: Wed Feb 08, 2012 9:33 am Post subject: Anyone make a custom linkage for Kadrons? |
The PO made a pretty nice linkage setup for these. I didn't play with them enough yet to figure out how the linkage goes, but I'd like to see more pics of homemade and custom linkage setups for these carbs. Please don't tell me the carbs are shit and they suck, go get some Webers or Dellortos instead, etc. Just looking for some custom and cool linkages for these carbs, thanks.
Linkage hard to see in the pic I know..
_________________ 1963 Ragtop Bug |
wompninja Samba Member
Joined: July 06, 2008 Posts: 2147 Location: Salt Lake City
Dale M. Samba Member
Posted: Wed Feb 08, 2012 9:50 am Post subject: |
wompninja wrote: |
Looks like the standard hexbar style, they just used round stock and its home made. |
Sort of think same thing.... Copy of "hex" bar...
Posted: Wed Feb 08, 2012 10:17 am Post subject: |
Gotcha, thanks guys. I know from using the stock linkage, they can suck pretty bad. _________________ 1963 Ragtop Bug |
rickb67 Samba Member
Joined: August 02, 2009 Posts: 39 Location: pittsburgh, pa
Posted: Wed Feb 08, 2012 5:24 pm Post subject: |
Check out www.lowbugget.com or call him he is very helpful with Kadron's. He will recommend jet sizes and anything else that you may need. Best of all he sells a very simple linkage that works and it adjust very simply. |
modok Samba Member
Posted: Wed Feb 08, 2012 5:32 pm Post subject: |
funny you asked, i just made one myself
Hold on I'll take a pic, prepare to be astounded |
Posted: Wed Feb 08, 2012 7:43 pm Post subject: |
modok wrote: |
Lets see it _________________ 1963 Ragtop Bug |
Chuey Samba Member
Joined: October 18, 2010 Posts: 858 Location: Oceanside, California
Posted: Wed Feb 08, 2012 9:17 pm Post subject: |
Gene berg has a linkage for them. I have one on my 1600 bus engine and it works great.
Chuey |
modok Samba Member
Posted: Thu Feb 09, 2012 1:49 am Post subject: |
I made the manifolds as tall as possible, that is why I elected to have the right side go over the top
The axis of the center thingy is at an angle, but the angle does seem to better match the angle the cable comes through, and make the links closer to parallel, so it works out
The links are steel pushrods, the center pivot is a bicycle hub
The cable pulley should prevent the cable breaking next to the clamp, which can be a problem otherwise with an arm rather than pulley, I tried to make a pulley myself but failed , so I just cut a slice of idler pulley
Posted: Thu Feb 09, 2012 7:03 am Post subject: |
Wow Modok , that's some thinking and innovation right there. Did you have to cut down the fan shroud on the left too? _________________ 1963 Ragtop Bug |
auslander Samba Member
Joined: January 07, 2003 Posts: 1831 Location: Heart Of Dixie
Posted: Thu Feb 09, 2012 12:13 pm Post subject: |
I'd love to see some hexbar style linkage for some kads... _________________ Zombie
Wandering...Have you found what your looking for?
66 POS Bus
69 Class 11 Beetle
71 Cat-Look Beetle
64 Old Skool Baja
74 "Swamp" Thing
!!! F**k Cancer !!!
Time's Tide will Smother You
"You can't throw a rock in Long Beach without hitting a tweaker" Steve Tucci |
ralf Samba Member
Posted: Thu Feb 09, 2012 12:58 pm Post subject: |
thats wat i plan to experiment on....
im gona be using scat universals
but i have a complete ict hex linkage set...
planning to make a base for the hex bar... centerd according to the shroud.. so it would be offset at the base of the filter (like idf hex) then use berg style Z bent threaded rods to retain travel at left n right side
_________________ Flow Through a Curved Conduit
porting my SP head for my brother's project
https://youtu.be/OS_mVjQuqgk |
vaughn bros. Samba Member
Joined: October 13, 2003 Posts: 2395 Location: Hickory, NC
Posted: Thu Feb 09, 2012 3:53 pm Post subject: |
Is this thread just for dual Kadrons? How about single Kadron? |
Max Welton Samba Member
Joined: May 19, 2003 Posts: 10697 Location: Black Forest, CO
Hotrodvw Samba Member
Posted: Thu Feb 09, 2012 5:11 pm Post subject: |
nice work _________________ '67 Sunroof
Eric
78x94 with IDA's....oober fun
Horsepower is an addiction........Addictions cost
lots of money!
Hose & Fittings |
ralf Samba Member
Posted: Thu Feb 09, 2012 5:20 pm Post subject: |
yes indeed awesome Max,
seen that for ages, and i must say every idea i have for the hex bar kadron
is inspired by that work _________________ Flow Through a Curved Conduit
modok Samba Member
Posted: Thu Feb 09, 2012 5:46 pm Post subject: |
EMPIImp69 wrote: |
Wow Modok , that's some thinking and innovation right there. Did you have to cut down the fan shroud on the left too? |
if nothing else it's a testament to mig welding
The fan shroud was already modified, that whole "engine" is just a mock up fixture, though I may use the shroud with the kadrons, or not, I have not decided yet |
Chuey Samba Member
Posted: Thu Feb 09, 2012 10:22 pm Post subject: |
Max, why did you modify the linkage? Was it not built for Kadrons in the first place?
Chuey |
