Anyone make a custom linkage for Kadrons?
Page: Previous  1, 2
earthquake
earthquake is offline
PostPosted: Fri Feb 10, 2012 4:22 pm    Post subject: Reply with quote
Modoc
now that you used the rear hub from your bicycle how are you going to get to work Very Happy
I'm surprised no one make a cheap copy of the Berg linkage, it would so easy to make, I would but I'm not a big fan of shroud mounted linkages because the shroud can move around a bit throwing the synchronization off.
Casey
74 CLASS 11 LOOK-A-LIKE
69 DUNE BUGGY
79 INTERNATIONAL SCOUT II
05 SCION XB SERIES RELEASE 2[#437]
Kelly J. Nolte 3/20/53 - 11/6/08
http://www.rememberingkelly.com/
DEATH TO CHINGERS!
clonebug
clonebug is offline
PostPosted: Fri Feb 10, 2012 5:08 pm    Post subject: Reply with quote
Makes the Scat linkage a very reasonable price.
The amount of time and material to build that has to be at least 3 times in cost and in weight of the Scat linkage.
vwracerdave wrote:
Take a good long look in the mirror and report back on what you see.
Dauz wrote:
Locked/limited... same diff
Paul.H wrote:
That one line on that chart is probably better info than you can get from this place in a month
(Now with Water/Alcohol Injection)
Upgraded to MS-2 Extra direct fire wasted spark
http://www.shoptalkforums.com/viewtopic.php?f=3&t=127936
modok
modok is offline
PostPosted: Fri Feb 10, 2012 5:48 pm    Post subject: Reply with quote
It could just be my imagination, but think about this....
a four cylinder engine always has some torque shake, you know it tends to kind of "rotate" on the axis of the crank. Such is nature
The engine mounts being on the bottom, there is a degree of side-to-side vibration at the level of the carbs
The regular kadron linkage would be a lot more likely to vibrate due to this, compared to my linkage(both sides pull) or a hexbar type
Vibration could really wear out the throttle shaft bushings.......
Sometimes it is better to adjust the linkage with the engine running, the vibration kind of takes the play out of the joints, you know Wink
should I balance both links to within one gram? Laughing
Chuey
Chuey is offline
PostPosted: Fri Feb 10, 2012 10:14 pm    Post subject: Reply with quote
Max, Yup. Thanks for the reply. It completely cleared up my question.
Chuey
EMPIImp69
EMPIImp69 is offline
PostPosted: Thu Feb 23, 2012 7:52 am    Post subject: Reply with quote
Put the carbs on..linkage not really lining up though nwith the hole in the shroud Confused Does something look wrong?
1969 Empi Imp #1325
1963 Ragtop Bug
Use this to balance your wide 5 steelies -->
http://www.thesamba.com/vw/classifieds/detail.php?id=1830990
Chuey
Chuey is offline
PostPosted: Thu Feb 23, 2012 10:48 pm    Post subject: Reply with quote
"Does something look wrong?"
Yes. You need a Miller Light can on the left side of the fan shroud for balance.
Chuey
clonebug
clonebug is offline
PostPosted: Thu Feb 23, 2012 11:54 pm    Post subject: Reply with quote
Yes,
Not only does it not line up but now you have to find a new place to put your coil since it goes right through your mounting area.
You would be better off getting the scat linkage.......it works. Period.....
EMPIImp69
PostPosted: Fri Feb 24, 2012 6:32 am    Post subject: Reply with quote
clonebug wrote:
Yes,
Do you really think I'm worried about relocating the coil? Rolling Eyes That's the easy part..Obviously I can go out and buy a new linkage, but that's not the point here. Someone did a lot of work to make this linkage, and I'm wondering if they just designed it around an aftermarket shroud. I may just cut the throttle pull piece off and weld it back on over to the left a bit.
1969 Empi Imp #1325
1963 Ragtop Bug
EMPIImp69
PostPosted: Sat Feb 25, 2012 3:18 pm    Post subject: Reply with quote
I figured it out, the spacers on either side were reversed, so its lined up now Very Happy
1969 Empi Imp #1325
1963 Ragtop Bug
Page: Previous  1, 2
Page 2 of 2
