kuleinc Samba Member
Joined: August 10, 2007 Posts: 1604 Location: East Bay Area, California
jsmitch11 Samba Member
Joined: July 02, 2011 Posts: 337 Location: Seattle, WA
Posted: Sat Feb 11, 2012 11:08 pm Post subject: Re: New Gowesty Hookups, has anyone tried them? |
kuleinc wrote: |
My hookups are pretty beat, not rust behind kitchen yet, want to keep it that way. Black plastic is cracking, time to get new. Should I get new delta Six stuff or new gowesty stuff?
Anyone used either and can recommend one over the other would be great. |
I havn't got these yet but they look appealing to me as well. Especially the air hose one that I can use with my ARB compressor! |
madspaniard Samba Member
Posted: Sat Feb 11, 2012 11:15 pm Post subject: |
If you are just worried about water getting in and rust, simply replace the gaskets/seals with new ones (I think VanCafe sells them too) and tint the hookup boxes that are not cracked with Forever Black. _________________ 1991 Westy auto w/ Peloquin TBD
"The only difference between me and a madman is that I'm not mad” - Salvador Dali |
70coupyel Samba Member
Joined: September 06, 2006 Posts: 1657 Location: So.Cal
Posted: Sat Feb 11, 2012 11:27 pm Post subject: |
I'm pretty sure that most of our vendors are using Delta Six hook ups. Don't forget the foam gaskets. _________________
TheAndante wrote: |
Saying that specs are different than dimensions doesn't make sense. Porsche specs/VW specs/engineering specs are nothing but a series of dimensions,sizes,percentages,measurements, etc. |
http://www.thesamba.com/vw/forum/viewtopic.php?t=338946&highlight=
70 KG Coup
83 Westy Waterboxer |
vwbeta Samba Member
Joined: February 16, 2011 Posts: 71 Location: Mar Vista, CA / Palm Springs, CA
Posted: Sat Feb 11, 2012 11:31 pm Post subject: |
I have the GW kit sitting in my house unopened right now..just as soon as I get home I will check them out!
I bought em because the ones on joel were in rough shape, cracked and i Broke he water fill last camp. I bought a new cover from busdept but the plastic was thin and much lighter weight, or the mold was thinner. Whatever, wasn't happy. Then I started sourcing used parts and had neglected to clean them paint and install when I saw the GW ones, and well..money was apparently burning a hole in my pocket so I pulled the trigger.
I'll compare and post pics
Chris _________________ 1987 Westfalia 'SloJoel' Vanistan 2.2 + WBXaustSS |
Altoona Samba Member
Posted: Sun Feb 12, 2012 12:41 am Post subject: |
Cool thanks for the link. _________________
TheAndante wrote: |
70 KG Coup
Wellington Samba Member
Joined: September 21, 2004 Posts: 1890 Location: Montreal
Posted: Sun Feb 12, 2012 3:25 am Post subject: |
http://theskylightguy.com/
I believe he bought the Delta six molds............his sky light is excellent quality. |
82WestyMan Samba Member
Joined: December 28, 2006 Posts: 1098 Location: Western OR
Posted: Sun Feb 12, 2012 6:21 am Post subject: |
So let me get this straight
... for the 'Complete Set of Three"
GoWesty - $139.95
TheSkyLightGuy - $189.95
usually i expect dinner, drinks and wet kiss first
... "I'm just not that kind of girl" _________________ "The floggings will continue until morale improves"
"I never did give anybody hell. I just told the truth and they thought it was hell" - Harry S. Truman
82 Westfalia - w/ a Raby 'Camper Special' engine |
Orngbug74 Samba Member
Joined: August 04, 2010 Posts: 69 Location: New London, Wisconsin
Posted: Sun Feb 12, 2012 6:59 am Post subject: |
I ordered my GoWesty Kit on Friday. Can't wait to see it! _________________ Kevin
1984 Westy
1971 Westy
1974 Super Beetle
1963 Beetle, Beryl green
1964 Beetle project
1968 Bradley GT
President, Northern WI Volkswagen Club
www.nwvc.weebly.com |
Colonel_Brown Samba Member
Joined: May 25, 2010 Posts: 115 Location: Toronto, Ontario
Posted: Sun Feb 12, 2012 7:31 am Post subject: |
I have the gowesty ones, i'd say they are okay. The originals seemed better put together with less plastic then these. The key for the water tank is made from plastic too. I ended up snapping the key off in the lock first time i used it, bit of a PITA. I didnt see any better replacement options when i looked so these will have to do for me... other than the water tank key they serve their purpose fine. _________________ '84 Vanagon GL (1.9L) - "Colonel Brown"
Last edited by Colonel_Brown on Sun Feb 12, 2012 11:57 am; edited 1 time in total |
vanagonjr Samba Member
Joined: October 07, 2010 Posts: 3431 Location: Dartmouth, Mass.
msinabottle Samba Member
Posted: Sun Feb 12, 2012 3:36 pm Post subject: |
Quote: |
Can you edit to clarify which ones - GoWesty or Delta-6 from skylight guy or other vendor? |
Or the Delta 6 from GoWesty which until a short time ago they sold?
I am very intrigued by these--and Winston's need en banc replacement. If the plastic IS thicker and UV resistant, that would be wonderful. The spring latch is NOT my favorite design of Winston's sub-assemblies. I worry on the tank fill if you HAVE to use their hose gizmo, I prefer using my own narrow long hose that goes into the tank and doesn't allow any room for leaking. I also didn't mind locking the filler neck, I have the older version with the metal key and it was comforting.
I await developments!
vwbeta Samba Member
Posted: Sun Feb 12, 2012 8:57 pm Post subject: |
I opened the box..
First blush..way way better than the delta6 remakes, much heavier duty and thick like the original..perhaps even thicker plastic. Hinge seems way better, with built in stops.
I will do a direct comparison and photos tomorrow, but so far I am pleased.
Posted: Sun Feb 12, 2012 9:01 pm Post subject: |
This is great news, since they are about the same price as the new delta six units. Mine are pretty cracked, and so far behind my kitchen has no rust, but it seems water will get in from the hookups soon, so I need to do SOMETHING, and just replacing the seals is not something I can do, the frames are cracking, maybe original, a lot on my van is... _________________ Check out our Our youtube channel: Https://www.youtube.com/channel/UC-EbskIxNm6SYzsq4ugG81A
http://www.thesamba.com/vw/forum/viewtopic.php?t=496946 1987 VW Vanagon Westfalia with 1.8T |
GBA 88West LA Samba Member
Joined: September 04, 2008 Posts: 1279 Location: New Hampshire
Posted: Mon Feb 13, 2012 9:34 am Post subject: |
i put the gw on two years ago they have held up well still look new comparable product everything matches up for on the backside of them for connections but as with the og's dont be too aggressive mounting them the screws supplied if i remember correctly are not the same size as og ones a little thinner , these smaller ones can pull through the plastic housing causing some issues so go gentle on the screws, i actually pulled them all off after initial mount and retained the old screws _________________ 88 Westy GL Vanaru 07 2.5 EJ25/AA Trans/oiling plates, 1.14 3rd-.77-4th..solar powered cabin |
Posted: Mon Feb 13, 2012 9:44 am Post subject: |
GBA 88West LA wrote: |
i put the gw on two years ago they have held up well still look new comparable product everything matches up for on the backside of them for connections but as with the og's dont be too aggressive mounting them the screws supplied if i remember correctly are not the same size as og ones a little thinner , these smaller ones can pull through the plastic housing causing some issues so go gentle on the screws, i actually pulled them all off after initial mount and retained the old screws |
If you put them on 2 years ago, they are the Delta 6 units, not the new GW designed ones. |
Posted: Mon Feb 13, 2012 9:48 am Post subject: |
i dont think the GW ones said delta six on them , pretty sure they were repos/ at the time delta six was NLA they werent sold as a kit thru GW i had to piece meal them individually ..not sure what they are _________________ 88 Westy GL Vanaru 07 2.5 EJ25/AA Trans/oiling plates, 1.14 3rd-.77-4th..solar powered cabin |
chimivee Samba Member
Joined: September 23, 2009 Posts: 741 Location: Orange, CA
Posted: Mon Feb 13, 2012 10:55 am Post subject: |
i dont think the GW ones said delta six on them , pretty sure they were repos/ at the time delta six was NLA they werent sold as a kit thru GW i had to piece meal them individually ..not sure what they are |
I don't believe the Delta Six units were branded as such in any conspicuous way. Whereas the new GoWesty hookups appear to have the GW logo right on the front.
_________________ -James
86 Syncro Westy, etc |
vwbeta Samba Member
Posted: Mon Feb 13, 2012 1:46 pm Post subject: |
Some pics below -
first of all here is the comparison of them all front and back of cover.
2012 GoWesty, new Delta 6 cover and Original Delta 6
now side by side.
this is Original Delta 6, New Delta 6, and GoWesty 2012
note that in the above, the GoWesty appears the thinnest - HOWEVER - in the following pic you can see that the GW 2012 doesnt have the cutout that the Delta 6 does - so the GW is actually thicker across - it is solid and not hollow feeling
SO. the original Delta 6 and the new Delta 6 are extremely close in size and identical in design - but the new plastic is somewhat warped/rippled, and feels lighter-weight. I think you can see in the photos that it is also shinier, more glossy and less matte. i didnt put on the new delta 6 cover because it didnt match the old plastic at all - i know some of that is because it is weather-beaten, but i really feel like it is a DIFFERENT plastic.
The GW design, imho - feels more like the original in texture and is heavier as it doesnt have the undercut/hollow inside on the cover. the full enclosure feels sturdy, and seems well designed. time will tell.
already happy about the 3-way door catch..no more springing back enclosure! i'm happy! i bough the kit and will be getting them all installed this week.
chris [who is not affiliated with GW or Delta 6] _________________ 1987 Westfalia 'SloJoel' Vanistan 2.2 + WBXaustSS |
