The Skylight Guy Samba Member
Joined: August 06, 2004 Posts: 47 Location: Gibsons, BC
Posted: Tue May 08, 2012 7:40 am Post subject: |
timichango wrote: |
Neither the product information about the 'new' Delta Six hookups nor the gowesty ones seem to mention anything about a Canadian version of the 110v hookup (or list it as a product), so I can only assume that it's a) an edge case that only affects a small subset of vanagon owners up here, b) an easy mod, or c) both. |
Hi Timichango,
We are located in Gibsons, BC just a short ferry ride from Horseshoe Bay, local Volks with a cause to help other Westfalia owners...if you want to keep your cord, not a problem! If you want to come visit our shop we are happy to assist you with the instal and anything else you have questions about regarding our parts, products etc...
Give us a call, it's local if you call Trevor's cell at 604-839-3597
Have a great day! _________________ Cheri & Trevor
1985 Westfalia 'Rock-on'
www.vanagonwestfaliaparts.com
Gibsons, BC Canada
604-740-1018 |
Mark Samba Member
Joined: January 20, 2003 Posts: 1523 Location: Victoria, BC Canada
Posted: Tue May 08, 2012 8:02 am Post subject: |
From the gallery, Cdn model on the left:
*not my photo*
Both use rivets to hold the conduit or male electrical plug in place. It was pretty easy to swap them over. |
kwilk Samba Member
Joined: July 25, 2010 Posts: 204 Location: Porlland,Or
Posted: Tue Apr 29, 2014 9:33 pm Post subject: hookup doors |
so my hookup doors are nice but one of the springs is not all the way inserted ( the little up and down part, not the actual horizontal spring) the part that has the spring, can anyone help me by letting me know how to get the whole spring out without ruining it? |
dschaftlein Samba Member
Posted: Mon Oct 22, 2018 4:36 pm Post subject: Re: New Gowesty Hookups, has anyone tried them? |
this weekend I took the time to install and leak test my gowesty hook up boxes. here's what i've found:
-foam gaskets don't seal very well, There was noticeable dripping from the gasket. I used butyl tape instead and the seal is perfect.
-the hook up boxes leak! especially the shore power box. I ended up taking them apart and sealing all the parts together with silicone (the shore power box is 3 pcs assembled with SS screws)
I tested all the boxes with my garden hose and they are all water tight now. |
