buzz n maz Samba Member
Joined: September 06, 2006 Posts: 74 Location: Devon, United Kingdom
Posted: Sun Feb 12, 2012 3:02 am Post subject: Barndoor sunroof |
can anyone advise me....
i know that barndoor sunroof rails have a slot for a kinda delux trim..
but do standard/microbus's also have rails with this delux trim or are they more like the later ones (plain)??
i have no reason to believe that my rails are not the original but they have no delux trim slot!!
hope this question makes sense....
cheers buzz |
bigbulli Samba Member
Joined: September 30, 2000 Posts: 575 Location: ENGLAND
Posted: Sun Feb 12, 2012 4:27 am Post subject: |
Number 55? 241 875 719 - protective strip. Taken from the Type 2 Parts Manual (1950-1954)
_________________ 1954 Barndoor
1955 Oval |
EverettB Administrator
Joined: April 11, 2000 Posts: 69829 Location: Phoenix Metro
Posted: Sun Feb 12, 2012 9:57 am Post subject: |
thanks... but i guess best show you what i have...
cheers buzz |
Concept1 Samba Member
Joined: September 07, 2004 Posts: 334 Location: Calgary, Canada
Posted: Sun Feb 12, 2012 11:32 am Post subject: |
From what I've seen, all barndoors use the rail with the vinyl trim, and they are exactly the same as '55-'58 rails. The header bows are slightly different, but most other parts are identical. _________________ C-1 |
Rusting Hulk Samba Member
Joined: August 20, 2002 Posts: 646 Location: Malvern UK
Posted: Sun Feb 12, 2012 11:38 am Post subject: |
All the ones i've seen have the 'trim' in. Strange that your rails may have been changed. I know autocraft were going to repro the early rails... _________________ 64 356 C Coupe |
Posted: Sun Feb 12, 2012 11:54 am Post subject: |
i have looked at autocraft and theres is the same as mine....(on there web)
ken... do you have any detail pictures of either of yours???
also the workmanship that you have done on that bus is second to none!! |
j.pickens Samba Member
Joined: December 03, 2002 Posts: 9791 Location: Exit 7, New Jersey
Posted: Sun Feb 12, 2012 2:24 pm Post subject: |
From '55 non barndoor sunroof bus.
Took this from the Samba gallery, not my bus.
Should be same profile as your bus.
You can see some of the seal at the front.
_________________ Founder and Chairman Emeritus, ECMSAS
BeaterBarndoor wrote: |
i wish more people would actually drive their vws rather than just talking about what they have in the garage. |
Red Fau Veh wrote: |
If you've seen one sunroof swivel seat kombi, you've seen them all! |
Posted: Sun Feb 12, 2012 2:38 pm Post subject: |
buggar..... thanks!! now i know what i need..
cheers buzz |
DSweinhagen Samba Member
Joined: July 30, 2002 Posts: 382 Location: Phoenix, AZ
Posted: Mon Feb 13, 2012 10:56 am Post subject: Re: barndoor sunroof |
buzz n maz wrote: |
cheers buzz |
Deluxe and non-deluxe sunroof parts are the same. What year is your bus?
The very early stuff is all different and the rails do not take the rubber moulding, along with the header bow being different. My '51 standard sunroof is this way, and the '52 deluxes I've seen are the same. I've always assumed this goes with the deep skylights, but not sure? _________________ David S |
Posted: Mon Feb 13, 2012 11:42 am Post subject: |
Oops, David S. Knows far more than I.
The key thing is what year/VIN your bus is. _________________ Founder and Chairman Emeritus, ECMSAS
Posted: Mon Feb 13, 2012 12:28 pm Post subject: Re: barndoor sunroof |
buzz n maz wrote: |
This is the '53 deluxe. Feb 13, 1953 Vin# 20-044994
I don't have the original rails for the '52 bus, but I do have a set like the ones form the '53 and they fit perfectly.
DSweinhagen wrote: |
buzz n maz wrote: |
cheers buzz |
The very early stuff is all different and the rails do not take the rubber moulding, along with the header bow being different. My '51 standard sunroof is this way, and the '52 deluxes I've seen are the same. I've always assumed this goes with the deep skylights, but not sure? |
The sunroof section, as in the body, is much different during the "deep skylight" era.
The '53 deluxe (the last know deep sky light)
And the '54 Kombi June 2, 1954
The entire sunroof section on the '52 and '53 are a separate stamping, that is just spot welded into an opening in the roof. This change seems to me it would be after the deep skylights.
David, Could you Take some pics of the early rails? _________________ C-1 |
Posted: Mon Feb 13, 2012 12:56 pm Post subject: |
thanks guys for your info.... my bus is a 54 rhd (aussie bus)
i have spoke to many people in the last couple of days.... and i am very confused...
the way i see it is, being the bus was not a delux... makes me think that it should prob not have the delux style moulding for the sunroof!!! but that said ( and like mentioned above) VW would have probably not made two different style mouldings through the same period...
i understand that the history is not always that clear when it come to early vw's, and also things changed depending on where it was going to be shipped to..
i would like to have the bus period correct as possible... (although i have done some bolt on modifications)...
so anymore light on the subject would be great.....
cheers again buzz |
Crashbox Samba Member
Joined: February 11, 2010 Posts: 41 Location: Germany
Posted: Mon Feb 13, 2012 1:57 pm Post subject: |
According to "Progressive Refinements" the sunroof rails were modified in December '52 (see page A-16):
_________________ '50 Type 11C
'52 Type 21A
'62 Type 111
'71 Type 23-517, SO 72/3 |
vwboop Samba Member
Joined: April 04, 2004 Posts: 716 Location: Langley, BC
Posted: Mon Feb 13, 2012 10:49 pm Post subject: |
I recall seeing literature to the effect that the rails with the insert were a recalled item and they were to be replaced when vehicles came in for service. I believe it was a note in a factory workshop manual describing sunroof installation. If anyone has an early factory workshop manual maybe they can check. I believe it was around 1958 that the change was made.. _________________ "Love and good roads" |
Posted: Tue Feb 14, 2012 9:58 am Post subject: |
vwboop wrote: |
I recall seeing literature to the effect that the rails with the insert were a recalled item and they were to be replaced when vehicles came in for service. I believe it was a note in a factory workshop manual describing sunroof installation. If anyone has an early factory workshop manual maybe they can check. I believe it was around 1958 that the change was made.. |
My '59 manual just says to renew the beading if damaged.
It could be missing an insert or update though.
The '63 manual doesn't mention the beading at all.
The change was made in '59, I posted the progressive refinements page above. _________________ How to Post Photos
deluxe hunter Samba Member
Posted: Sun Feb 19, 2012 2:26 am Post subject: |
buzz n maz wrote: |
cheers again buzz |
I have a '54 RHD sunroof also and it also has the black trim....
Posted: Sun Feb 19, 2012 12:19 pm Post subject: |
hello delux hunter, yes i have seen your thread.... interesting bus, keep us all informed how you get on with it...
thanks for shareing that pic...
although im still unsure why mine came with the rails i have??? i have been away to a vw show, i have shown some mates the rails and recon they are not even like the later style??
so still puzzelled!!!
has any one lucky enough to have early (pre 52) rail profile pic and the later (i guess, post 58)profile pic to compare?? |
52 deelux Samba Member
Posted: Mon Feb 20, 2012 2:16 am Post subject: |
My mid '52 Deluxe sunroof does NOT have the beading. It is the same as the equivalent split window beetle rail. The rails are very similar to yours BUZZ but it appears that your extrusion has half of the rebate for the beading. Are you sure the other half hasn't been removed and polished out?
No photos at the moment but try to get some later. _________________ 52 BD Deluxe
57 Ghia golde
54 Ragtop |
Posted: Mon Feb 20, 2012 7:50 am Post subject: |
Here's a picture of an end piece...
