buzz n maz Samba Member
Joined: September 06, 2006 Posts: 74 Location: Devon, United Kingdom
Posted: Mon Feb 20, 2012 10:07 am Post subject: |
52 deelux wrote: |
My mid '52 Deluxe sunroof does NOT have the beading. It is the same as the equivalent split window beetle rail. The rails are very similar to yours BUZZ but it appears that your extrusion has half of the rebate for the beading. Are you sure the other half hasn't been removed and polished out?
No photos at the moment but try to get some later. |
well that was what i thought when i saw the delux trim one at the weekend.... so i had a close inspection, but there seems no evidence cut/grind or polish marks anywhere....
looking at the picture of the early ones above... they look very simular to that.... |
low54 Samba Member
Joined: March 19, 2004 Posts: 424 Location: cotswolds-england
Posted: Tue Feb 21, 2012 11:01 am Post subject: |
It looks very factory buzz maybe the factory tried a different idea for a month or so then decided to swap back ? _________________ 65 original paint so42 dormobile
52 original paint 52 split beetle |
Mr. OGPaint Samba Member
Joined: September 24, 2010 Posts: 823 Location: Oregon
Posted: Thu Apr 09, 2020 7:21 am Post subject: Re: barndoor sunroof |
Concept1 wrote: |
The '53 deluxe (the last known deep sky light)
And the '54 Kombi June 2, 1954
The entire sunroof section on the '52 and '53 are a separate stamping, that is just spot welded into an opening in the roof. This change seems to me it would be after the deep skylights.
Deep skylights ended in early 1953, the above posted brown roof is the newest known deep skylight compared to an original 54 Sunroof Kombi.
Focusing on the header detail difference, can anyone add any input on when these details changed on the sunroof opening? Were these details changed at the same time as the switch from handmade deep skylights? _________________ https://instagram.com/mr.ogpaint
Patrick Hall |
EmpiGT Samba Member
Posted: Wed Jul 08, 2020 3:44 pm Post subject: Re: Barndoor sunroof |
Does anyone have a picture of the hornbecker sunroof rails? It should have the pre rubber trim rails.. So are the pre rubber trim rails basicly the same as the post rubber trim rails(late 59 and newer)? |
