ragtopbaja Samba Member
oldmoparguy Samba Member
Joined: March 14, 2012 Posts: 3 Location: Charlotte, NC
Posted: Wed Mar 14, 2012 10:30 am Post subject: Re: epic engine |
Opps... 5.7L, 327 Cu. in...
That's a Corvair engine. It's not possible to get 5700cc in that crankcase. Just no room. Early Corvairs were 2400cc, later ones were 2700cc. There are some converted to 3100cc using modified 94mm T1 PC parts.
Wayne |
Boolean Samba Member
Joined: January 19, 2012 Posts: 1712 Location: Stockholm
DarthWeber Samba Member
Joined: November 24, 2007 Posts: 7543 Location: Whittier,CA
Posted: Wed Mar 14, 2012 11:22 am Post subject: |
This one is better.
Mitey62 wrote: |
Swapped the Compufire for a Bosch blue and some points I had sitting around, started 1st crank. Took her out for a drive, pulls harder, more RPM, and runs smoother. I think I'll be sticking with points from now on. |
RockCrusher wrote: |
JB weld the case halves....that'll keep the fretting to a minimum. |
Letterman7 Samba Member
Joined: March 14, 2004 Posts: 3198 Location: Downingtown, PA
Posted: Wed Mar 14, 2012 11:40 am Post subject: |
It's actually a Corvair converted for aircraft use. The reduction gear starter and the intake manifolds are tell-tail. I like the last photo that Darth posted.. Porsche flat 12 from a 917? |
Low67vdubinnocal Samba Member
Posted: Wed Mar 14, 2012 9:22 pm Post subject: |
DarthWeber wrote: |
This one is better.
That picture should be framed as true modern artwork. |
doc1369 Samba Member
Joined: March 31, 2010 Posts: 2859 Location: Las Vegas, NV, again
Posted: Wed Mar 14, 2012 10:03 pm Post subject: Re: epic engine |
oldmoparguy wrote: |
Wayne |
5700cc equals 350cu. In _________________ Fatchicks: Daily drivers, donor cars, collectibles. What can't they do? |
