Vinnems Samba Member
Joined: December 23, 2008 Posts: 1183 Location: Simi Valley, CA
Posted: Mon Feb 13, 2012 11:17 pm Post subject: Engine install question |
Trying to put engine back in, having some trouble. First, I know it's the right clutch and clutch bearing assembly and all that (same ones I pulled out going back in). I have it almost in, everything is all lined up. It can almost reach the bolts, and the flywheel is sticking out like a few milimeters. I'm rocking the sucker all over and pushing but it's not going in. I can feel clearance all around the flywheel so I know it's not hitting on that. Anything I might have missed? I have the stick installed but not the pedals, if that matters. Engine is a turn key, also, with just the carbs removed to make it fit. |
Glenn73 Samba Member
Joined: May 30, 2011 Posts: 1190 Location: West Jordan UT
Greezy Joe Samba Member
Joined: April 12, 2010 Posts: 1534 Location: Crawfordville, Fl
Posted: Tue Feb 14, 2012 5:14 am Post subject: |
^^^^ and loosen the clutch adjustment _________________ Current:74 Ghia Coupe w/ 2276
71 Ghia Vert w/ 1835
07 GMC Truck
12 Jeep Wrangler
73 Harley FLH 93 cid
89 Harley 883 Sportster (1200)
Owned before: 58, 69 Ghia Coupes, 64 Canvas Sunroof, 68, 72, 73, & 74 Bugs, 63 Single Cab, 65 Bus, 66 & 70 Camper
" Duct tape can't fix stupid, but it'll muffle the sound". |
gt1953 Samba Member
Posted: Tue Feb 14, 2012 6:17 am Post subject: |
Generally it is the clutch alignment. Secondly the clutch needs to be loosened. Be patient and recheck the clutch alignment with proper alignment tool. _________________ Volkswagen: We tune what we drive.
72 type 1
72 Squareback
Posted: Tue Feb 14, 2012 9:36 am Post subject: |
My stick isn't aligned so I can only get it in first and second (or third and fourth). Is this alright for lining it up? |
twomonkeysayoyo Samba Member
Joined: November 17, 2009 Posts: 651 Location: Carrollton, GA
Posted: Tue Feb 14, 2012 9:40 am Post subject: |
also make sure the donut is removed out of the center of your pressure plate.
I would put it in 1st (or reverse) and as you are trying to get the motor on the shaft rock the car back and forth, slightly spinning the shaft to align it with your shovenings. _________________ ---
Looks like trouble. |
Cusser Samba Member
Joined: October 02, 2006 Posts: 31379 Location: Hot Arizona
Posted: Tue Feb 14, 2012 11:49 am Post subject: |
twomonkeysayoyo wrote: |
also make sure the donut is removed out of the center of your pressure plate. |
He said it was the same clutch setup as what had been in there. _________________ 1970 VW (owned since 1972) and 1971 VW Convertible (owned since 1976), second owner of each. The '71 now has the 1835 engine, swapped from the '70. Second owner of each. 1988 Mazda B2200 truck, 1998 Frontier, 2014 Yukon, 2004 Frontier King Cab. All manual transmission except for the Yukon. http://www.thesamba.com/vw/forum/album_page.php?pic_id=335294 http://www.thesamba.com/vw/forum/album_page.php?pic_id=335297 |
Valnar300 Samba Member
Joined: March 18, 2010 Posts: 342 Location: Garden Grove, CA
Posted: Tue Feb 14, 2012 12:36 pm Post subject: |
I usually just put it into 4th and have someone spin one of the wheels while I'm pushing on the motor. _________________ Cars So Far:
-73 Super Beetle
...well I didn't say it was a long list. |
Posted: Tue Feb 14, 2012 12:58 pm Post subject: |
Will it be obvious when the spines line up? Like it will suddenly start slidng easier, or am I going to have to keep turning the crank or the transmission and keep pushing until it finally gives? |
Posted: Tue Feb 14, 2012 1:04 pm Post subject: |
Yeah, it should just slide forward once the splines are aligned. _________________ Cars So Far:
-73 Super Beetle
Whiteboyspooky Samba Member
Joined: February 13, 2011 Posts: 129 Location: los angeles
Posted: Tue Feb 14, 2012 9:57 pm Post subject: |
Hey Val, that wheel trick worked like a charm! I put the stick in fourth (or second, it's not centered so who knows) and I jacked up one side. I then turned the wheel a little bit, and then pushed. I did that two or three times until it lined up with the splines and it went in easier than a drunk prom date
I also, strangely, would like to thank the previous owner of my car for letting the rear package tray rot out. It made it a lot easier to tighten the bolts and hook up the fuel line and wiring. |
