SBD Samba Member
Joined: October 24, 2012 Posts: 3269 Location: SOUTH DAKOTA
Posted: Thu Aug 13, 2020 4:57 pm Post subject: Re: Abortion ENGINES ONLY Thread, come see the Horror! |
2% is the best my wife will let us drink. If she had her way it would be 1%!
_________________ "Just $99 down and $64 a month for 36 months buys you a brand new Volkswagen Beetle!"
mark tucker wrote: |
I wouldent waste $ or thyme on building a small motor. build it big so it dosent have to work hard.remember it's only as fast as your foot alows it to be unless you build a small turd then it just stinks as it squishes up through your toes when you step on it. |
DrHAX Samba Member
Posted: Fri Aug 28, 2020 7:41 pm Post subject: Re: Abortion ENGINES ONLY Thread, come see the Horror! |
Here’s my current bastard. Trying to sort out the dual Kadrons, the drivers side is backfiring. Maybe shaming it will get it to magically work _________________ Signed by the rather insane, ambitious, and very stubborn Darko |
Ceckert64 Samba Member
Joined: September 16, 2015 Posts: 1957 Location: Manitowoc, WI
cdennisg Samba Member
Joined: November 02, 2004 Posts: 20271 Location: Sandpoint, ID
Posted: Fri Aug 28, 2020 8:47 pm Post subject: Re: Abortion ENGINES ONLY Thread, come see the Horror! |
Love the dual oil filter setup. And the air cleaners are cool, too.
Get that thing sorted out and drive it! _________________ nothing |
Chickensoup Samba Member
Joined: January 06, 2018 Posts: 5368 Location: Good Hope, GA
Posted: Fri Aug 28, 2020 8:53 pm Post subject: Re: Abortion ENGINES ONLY Thread, come see the Horror! |
clean that hoe! re locate the oil filters, remount the coil and external voltage regulator, find some smaller oil bath or air cleaners, re route your fuel line. the belt guard can stay, i kind of like it. with these adjustments IMO that engine will look killer. for now, end caps will be just fine for the fresh air outlets.
or, do what you want with it, and do what makes YOu happy, BEcause, its your car... _________________ -'85 c10 5.3 LS, 222 cam, long tubes, x pipe, 3 inch spin tech's
'65 Tourist Delivery Build
'66 RIP
'69 RIP
Hosea 4:6 "My people are destroyed for lack of knowledge" |
Posted: Fri Aug 28, 2020 10:14 pm Post subject: Re: Abortion ENGINES ONLY Thread, come see the Horror! |
If you decide to ditch those air cleaners, I want 'em. I will (hopefully) be in your neck of the woods soon. _________________ nothing |
SBD Samba Member
Posted: Sun Aug 30, 2020 8:32 pm Post subject: Re: Abortion ENGINES ONLY Thread, come see the Horror! |
DrHAX wrote: |
Here’s my current bastard. Trying to sort out the dual Kadrons, the drivers side is backfiring. Maybe shaming it will get it to magically work |
I kinda' like the direction this one's headed. _________________ "Just $99 down and $64 a month for 36 months buys you a brand new Volkswagen Beetle!"
Glenn Mr. 010
Joined: December 25, 2001 Posts: 76908 Location: Sneaking up behind you
Posted: Mon Aug 31, 2020 3:54 am Post subject: Re: Abortion ENGINES ONLY Thread, come see the Horror! |
Gotta be a mess to replace the oil filters. _________________ Glenn
Member #1009
#BlueSquare |
FarmerBill Samba Member
Joined: July 25, 2017 Posts: 766 Location: New England
Posted: Mon Aug 31, 2020 8:16 am Post subject: Re: Abortion ENGINES ONLY Thread, come see the Horror! |
The old David Brown tractors had canister style filters installed similar to that. When you loosened the bolt the oil would run down the block and on to the frame rail so you needed a catch pan three feet long if you didn't want to get oil on the floor. I made a sluice out of aluminum flashing that I wired under the canister to direct the oil over the rail and into a bucket. |
GArBa Samba Member
Joined: January 27, 2014 Posts: 2105 Location: Milano, Italy
Posted: Mon Aug 31, 2020 9:41 am Post subject: Re: Abortion ENGINES ONLY Thread, come see the Horror! |
but... but it's like on a Daytona engine! So it MUST be good, right? ...right?
_________________ cars:
'97 type 1 1600i
'14 type AA Seat Mii (sadly dead after 270.000 km)
'22 type C1 T-Cross
'23 type AC3 Hyundai I10 (VW no longer makes small cars!)
moped:
'82 Benelli Magnum 3v |
Posted: Mon Aug 31, 2020 10:24 am Post subject: Re: Abortion ENGINES ONLY Thread, come see the Horror! |
Glenn wrote: |
Gotta be a mess to replace the oil filters. |
Maybe. Plenty of modern cars have filters like that (usually just one) and are very easy and tidy to change. I am guessing it helps to have a relief valve at the bottom of that filter housing, so oil has a chance to mostly drain out of the filter before you remove it.
Glenn Mr. 010
Posted: Mon Aug 31, 2020 11:47 am Post subject: Re: Abortion ENGINES ONLY Thread, come see the Horror! |
cdennisg wrote: |
Glenn wrote: |
Your picture is of a Subaru... I have 2 of them. There's flanges around the filter that all the oil drips into.
Most filters have a anti-drainback valves so they are not empty at startup. There's oil in the filter and with that double mount, it will run down the engine. _________________ Glenn
Member #1009
#BlueSquare |
Posted: Mon Aug 31, 2020 2:58 pm Post subject: Re: Abortion ENGINES ONLY Thread, come see the Horror! |
Glenn wrote: |
cdennisg wrote: |
Glenn wrote: |
Most filters have a anti-drainback valves so they are not empty at startup. There's oil in the filter and with that double mount, it will run down the engine. |
Yep, I immediately thought of modern Subarus when I searched for the photo.
Yes, the filter contains an anti-drainback valve (usually) which will help keep too much oil from escaping when removed, too.
I have no doubt the VW engine filter adapter thingy would be a little messy, but I am betting that with it being located up high, if you take your time draining the engine oil, at least a bunch of the oil in the filters will drain out into the adapter before you pull the filter.
A pile of rags would be handy, too. _________________ nothing |
DrHAX Samba Member
Posted: Wed Sep 02, 2020 11:00 pm Post subject: Re: Abortion ENGINES ONLY Thread, come see the Horror! |
The 356 air cleaners ain’t going anywhere ( actually I’m a bit worried about them being stolen actually ) I hunted them down specifically for this. The dual oil filter mount was something I got for 15$ shipped here a few years ago. Mounting them upside doesn’t worry me as they’re so high up. Basically just crack the seal and let it drain. Mercruisers have their filters mounted the same way and that’s what the boat guys use.
Though I did find the vacuum leak there’s a hole drilled through the intake on one side. it looks like somebody was trying to drill them
For the stock location pin but did it backwards leaving a hole there.
Trying JB weld to see if it works if not I’ll ask my hot rod friends if any of them have a tig welder so i can tig the hole shut. Used to Weld boat noses for pontoons aluminum is something I know well _________________ Signed by the rather insane, ambitious, and very stubborn Darko |
Posted: Thu Sep 03, 2020 8:30 am Post subject: Re: Abortion ENGINES ONLY Thread, come see the Horror! |
HAHA I did not realize they were 356 air cleaners, I just though they looked neat. Now I know why!
JB weld should work fine on that manifold, as long as you clean and prep the surfaces well. _________________ nothing |
Da TOW'D Samba Member
Joined: December 25, 2005 Posts: 1321 Location: Bella Coma Canada
Posted: Fri Sep 18, 2020 2:11 pm Post subject: Re: Abortion ENGINES ONLY Thread, come see the Horror! |
quote
Though I did find the vacuum leak there’s a hole drilled through the intake on one side. Shocked it looks like somebody was trying to drill them
drill and tap it for a vacuum gauge
looking good _________________ '57 type 1 Blackberry
'58 SC Ruf
'62 type 3 Notch
'92 Eurovan Willy DD
and NUTS |
Posted: Fri Sep 18, 2020 2:20 pm Post subject: Re: Abortion ENGINES ONLY Thread, come see the Horror! |
Our friend Gundy giving Merroly's bug some much needed horsepower in 1972
I have that bug now
cheers
Hank _________________ '57 type 1 Blackberry
'58 SC Ruf
'62 type 3 Notch
and NUTS |
Posted: Fri Sep 18, 2020 4:15 pm Post subject: Re: Abortion ENGINES ONLY Thread, come see the Horror! |
I know it is likely a reflection, but it appears to have either lightning or cobwebs from the coil to the distributor. I prefer to think its lightning! _________________ nothing |
busdaddy Samba Member
Joined: February 12, 2004 Posts: 51128 Location: Surrey B.C. Canada, but thinking of Ukraine
Posted: Fri Sep 18, 2020 4:39 pm Post subject: Re: Abortion ENGINES ONLY Thread, come see the Horror! |
cdennisg wrote: |
I know it is likely a reflection, but it appears to have either lightning or cobwebs from the coil to the distributor. I prefer to think its lightning! |
That's not lightning, it's the badass, it's so strong it's visible. The orange manifold ends surely add at least 5 hp as well. _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
SBD Samba Member
Posted: Fri Sep 18, 2020 6:20 pm Post subject: Re: Abortion ENGINES ONLY Thread, come see the Horror! |
I thought it was just a mass of PURE ENERGY flowing from the coil to the distributor! _________________ "Just $99 down and $64 a month for 36 months buys you a brand new Volkswagen Beetle!"
