extending the passenger/driver battery box
Page: Previous  1, 2
almo
almo is offline
PostPosted: Tue Nov 17, 2015 11:10 pm    Post subject: Re: extending the passenger/driver battery box Reply with quote
Diggin this up
Anyone done this to a syncro? I'm worried about the tire clearances at full lock and compression? I've got 215/75/15's 2" gw lift?
Would the corner still have to be cut off the box??
This make big difference on battery size.
Jordauto what are you running? I'm curious if u have a 2wd did you cut the corner
Cheers
San Francisco/Mayo Ireland
1986 2.1L Westy 2wd 4-spd Sold!!!!
1987 2.1L Westy syncro
2005 Subaru legacy 2.5Gt Wagon 5sp MT
jordauto
jordauto is offline
PostPosted: Wed Nov 18, 2015 12:32 am    Post subject: Re: extending the passenger/driver battery box Reply with quote
Hey there Almo, my Westy is 2wd, and I have General Grabber AT2 tires. 205/75R15. My ride height is about an inch higher than stock. You can see my pics at the bottom of the previous page. I cut the corner because I was worried about hitting under full compression. I drive a lot of old and sometimes deactivated logging roads. It has never hit though. I've done a couple of these boxes in vans now. But only 2wd.
Team WorldTour Premium Member
Team WorldTour is offline
PostPosted: Thu Mar 30, 2017 8:37 am    Post subject: Re: extending the passenger/driver battery box Reply with quote
Hey jordauto- do you have a schematic for your revised box design I could use over here in Germany?
I promise it will be for personal use, and not for profit.
1990 Feldjäger Syncro AAZ
Click to view image
H6 Subaru Engine Swap Thread
WV2ZZZ25ZFH094138(x)/ WV2YB0257LH057308(x)/ WV2ZZZ25ZLG113270/
"Where am I going? And what am I doing in this handbasket?" -Nicodemus Jordan
View user's profile Send private message Send e-mail Visit poster's website AIM Address Facebook Gallery Classifieds Feedback
jordauto
jordauto is offline
PostPosted: Thu Mar 30, 2017 9:12 am    Post subject: Re: extending the passenger/driver battery box Reply with quote
Team Worldtour. All the dimensions for the box are on page one of this thread. You need to make an access hole with cover so you can get the upper control arm camber adjusting bolt out to service upper control arm bushings etc. The leading edge corner should be mitred off for tire clearance. Have a look at my pics on page one. I don't have any more detailed drawings. I have been using a standard group 24 battery with lots of extra room in the modified box. But a group 27 should also fit. I'll know for sure in a few days as I'm just in the process of installing a 12 volt fridge, solar, and the biggest battery I can fit.
avernon82
avernon82 is offline
PostPosted: Thu Apr 06, 2017 7:20 am    Post subject: Re: extending the passenger/driver battery box Reply with quote
I have my upper control arm bolt installed backwards so it removes toward the front of the van. Seems like it doesn't matter which way it's installed. If you flip the bolt, there should be no need for the access hole.
avernon82
PostPosted: Thu Apr 06, 2017 1:21 pm    Post subject: Re: extending the passenger/driver battery box Reply with quote
is this dumb of me? Could this cause a problem? It's been like that for over a year.
Page: Previous  1, 2
Page 2 of 2
