lostinbaja Samba Member
Joined: December 19, 2004 Posts: 4036 Location: Frankfort, Illinois
Posted: Sun Dec 29, 2013 1:19 pm Post subject: |
The things that makes a a buggy drive in the sand so well, is the fact that they are typically so light they float in the sand. I can really tell the performance difference between my Baja and my Manx in the sand.
It looks like you have a good build going, don't let me slow you down. _________________ Jerry...
If it's being towed, it must be a trailer!
"Vee Grow Too Soon Oldt Und Too Late Schmardt"
RIP Morgan
My photos
http://www.manxgallery.org/gallery/album92 |
herbsflat4 Samba Member
Joined: February 20, 2012 Posts: 159 Location: Greenville, SC
Posted: Tue Jan 23, 2018 11:18 am Post subject: Re: Herbsflat4 - Spatz Dune Buggy Build |
Holy time lapse Batman.
Well since 2013 I have moved to a new state, got married, moved again, changed jobs, bought a house and paid off our debts (minus the mortgage). So yea those are my excuses for not really making much progress but really I just haven't been excited by the project until recently. I have struggled and struggled with the steering setup and think I am finally pointed in the right direction but I will post more pics of that later. What you see below was temporary to just drive it around the backyard.
To provide an update and some pictures see below.
Here is the chassis and I just needed to take a ride and have some fun so I put it all together the best I could and drove it around the back yard.
Then after the fun was over I have been working on other fiberglass repairs. I joke with my co-workers saying "I'm glad I am not building a boat!"
Finishing glassing on the dash (which I had to substantially cut to fit my body)
I also added material to the body flange since it was so thin and cracked in spots. Now time to sand a bit and flip it back over for fitting on the body again.
Would love any feedback and always looking for advise on how to properly work on this thing! |
stevemariott Samba Member
Joined: November 09, 2003 Posts: 1052 Location: Portland, OR
Posted: Tue Jan 23, 2018 9:13 pm Post subject: Re: Herbsflat4 - Spatz Dune Buggy Build |
Man, looking good - I dig the Centerlines and 914 seats! Keep up the good work _________________ 1963 Manx copy
1968 Bus |
Posted: Thu Feb 08, 2018 8:49 am Post subject: Re: Herbsflat4 - Spatz Dune Buggy Build |
Thank you!
Some more updates on my steering adventure.
My drawing and part descriptions
Initial layout and fitting of parts. The steering shaft is not in its final position yet. Need to check alignment with dash and hood before final welding.
Here is the secondary shaft bearing installed at the bottom of the column tube. I still need to consider a way to affix the bearing in the tube similar to how it is preloaded on the top of the tube and steering wheel.
Here is the 2x1" tubing tacked in place with exhaust clamps tacked in place too. Feels pretty good and solid and allowed me to put the steering wheel in a spot that is comfortable for me without worrying about the rag joint angle and alignment. |
Posted: Sun Jan 26, 2020 8:20 pm Post subject: Re: Herbsflat4 - Spatz Dune Buggy Build |
Well, long story short I took the buggy to someone to help finish and they never did anything with it for about a year. So I just got it back in my garage and picked up where I left off.
Still working to restore the hood flanges so I have some material to bolt the hood to the body.
On another note - I could use some help.
Do you have to run a fuel return line for a electric fuel pump setup with carbs? My setup would be
Fuel tank > into carter fuel pump > into Mallory fuel pressure regulator > into carbs.
Will that work okay? I ask because Mallory suggests the carb setup below which shows a return line.
If I do plumb a return line should it come to the top of the tank or bottom? Also if only the fuel cap is vented is that enough? |
slalombuggy Samba Member
Posted: Sun Jan 26, 2020 9:34 pm Post subject: Re: Herbsflat4 - Spatz Dune Buggy Build |
A return line gives you much more stable fuel pressure. I tried it both ways and really only had success using a return line. I like returning fuel into the top of the tank so the return fuel has no restrictions.
brad |
Posted: Mon Jan 27, 2020 6:22 am Post subject: Re: Herbsflat4 - Spatz Dune Buggy Build |
slalombuggy wrote: |
brad |
Many thanks for the reply Brad.
So can you help again? How would you setup the return line? See pictures below with questions.
Gas Tank image with questions
Gas tank image only
Filler neck close up
Small tube close up (Not sure what to do with it)
Posted: Mon Jan 27, 2020 5:27 pm Post subject: Re: Herbsflat4 - Spatz Dune Buggy Build |
You could put a loop of rubber hose on that small fitting for a vent. The filler vent would be a good place to put the return line from the regulator.
brad |
oprn Samba Member
Joined: November 13, 2016 Posts: 12744 Location: Western Canada
Posted: Mon Jan 27, 2020 7:01 pm Post subject: Re: Herbsflat4 - Spatz Dune Buggy Build |
That little fitting hooks into the evap control system on a later smog Beetle.
My Carter pump with a pressure regulator seems fine without a return line. |
Posted: Tue Jan 28, 2020 6:58 am Post subject: Re: Herbsflat4 - Spatz Dune Buggy Build |
oprn wrote: |
10-4 OPRN. Do you use a vented gas cap or have a separate tank vent?
Thanks again Brad. I was thinking the same thing and just plugging the evap port and relying on the vented gas cap only.
Also - I laid up another layer of chopped mat on each hood flange. I think I am getting close with the hood repairs. One more layout on the outer edges and then I will check fitment and try to mount the windshield!
Passenger side inside edge
Driver side inside edge
Posted: Tue Jan 28, 2020 9:26 am Post subject: Re: Herbsflat4 - Spatz Dune Buggy Build |
The problem with a vented gas cap in the front is gas can get sucked out of it at high speeds. When I had a front mounted tank in my buggy it would spray me with fuel at highway speeds. You don't need much or a vent just find some hose that fits that evap fitting and make a 6" loop in it to keep fuel from sloshing out of it and mount it up higher than the vent fitting.
brad |
oprn Samba Member
Posted: Tue Jan 28, 2020 6:15 pm Post subject: Re: Herbsflat4 - Spatz Dune Buggy Build |
Vented cap, flush mounted. Came on the Buggy when I bought it, had no idea where they got it from until I was walking along a dock at the lake looking at the boats and there it was!
Posted: Wed Jan 29, 2020 10:41 am Post subject: Re: Herbsflat4 - Spatz Dune Buggy Build |
Thanks for the follow up feedback guys. I really appreciate it.
Back down to the garage! |
Posted: Mon Feb 03, 2020 8:41 am Post subject: Re: Herbsflat4 - Spatz Dune Buggy Build |
After a lot of fitting, grinding, fitting, grinding, fitting, swearing and crawling around I have the hood bolted to the body and the windshield bolted to the hood. I know this may not seem like a huge accomplishment to most but I really struggled with this step. Is it perfect, no. But its secure and I am ready to move on to fitting the gauges and wiper motor assembly.
Hood on, no windshield.
Windshield on!
Posted: Mon Feb 03, 2020 10:29 pm Post subject: Re: Herbsflat4 - Spatz Dune Buggy Build |
Looking good!! _________________ 1963 Manx copy
1968 Bus |
66 Shorty Samba Member
Joined: May 10, 2007 Posts: 916 Location: Rhode Island
Posted: Fri Feb 07, 2020 4:48 am Post subject: Re: Herbsflat4 - Spatz Dune Buggy Build |
Sweet! I goof on how much that looks like my Spatz Buggy! LOL!
Congrats! Can't wait to see it finished! (I'm no longer building my Spatz... ) |
Posted: Fri Feb 07, 2020 5:15 am Post subject: Re: Herbsflat4 - Spatz Dune Buggy Build |
Thanks guys!
This weekend I hope to work on the battery tray, wiper motor and gauge layout on the dash.
I also want to try and work on the headlight support brackets.
I feel like I am over the hump but still a long way to go! |
Posted: Sat Feb 08, 2020 6:23 am Post subject: Re: Herbsflat4 - Spatz Dune Buggy Build |
Trust me when I say that anyone who has built a buggy appreciates how much work you've done. . It might not look like much yet, but we all know what it takes to get it to where it is. Looks great, love Centerlines on buggies although those rears look a little skinny😁
brad |
Posted: Sun Feb 09, 2020 6:20 pm Post subject: Re: Herbsflat4 - Spatz Dune Buggy Build |
Brad - Thanks! And yes I totally agree the centerlines are too skinny! I bought a set of smitty's smoothies about a year ago. I will be honest. I wouldn't recommend him or his wheels. Can you believe this? Am I missing something anyone?
The rims dont sit flush against my brake drums or rotors.....!!!! The smoothie cap clips hit the brake drum/rotor first. This leaves about a 1/8" gap between the rim and the brake rotor. This is crazy!!! What if I would have just mounted them up? Who knows what could have happened.
The best I can assume is that he forgot to countersink the rivets or something. I have sent Jim a message but no response yet.
Rim bolted in place to show you what it all looks like
Close up looking down
Another close up showing the gap
backside of the rim
Posted: Sun Feb 09, 2020 6:33 pm Post subject: Re: Herbsflat4 - Spatz Dune Buggy Build |
Anyways, here are some pictures of other odds and ends I worked on.
headlight support
Rear tray support (pass side)
Repairing my mistake on cutting out the entire battery tray! Glassing it back in.
I cut out a section of the tray over the IRS swingarm and flipped it so the swingarm wont hit the battery tray if fully compressed. I choose this since I am using a smaller AGM battery and dont need the entire battery well anyways.
Finally, I cut out a section of the wiper arm in order to fit my speedo (but I also plan to relocate the fuel guage input module). The picture doesn't really show the whole story but I will have enough room to move the speedo in and out now. I think this will be okay since I don't plan to use the wipers much but the assembly still feels really stout.
Front side for reference
Just barely enough room behind the light switch!
