peasant Samba Member
Posted: Tue Feb 21, 2012 10:18 pm Post subject: How to know if align bore was done? |
Hi all,
I have a 2.1 wbx case and was wondering how to know if has had align bore done?
I did a search but just a few posts about where to get one done.
I think that it has because it is a rebuild and has the yellow sticker. I heard all the ones with the yellow sticker have been align bored.
What are some opinions on if this case is usable? Are bearings available, or only standard sizes? _________________ 89 wolfsberg weekender carat
89 Westfalia |
Zeitgeist 13 Samba Member
Posted: Tue Feb 21, 2012 10:33 pm Post subject: |
measure the bore and compare to specs. Do you have the main bearings that last ran in the case? _________________ Casey--
'01 Weekender --> full camper
y u rune klassik? |
Posted: Tue Feb 21, 2012 10:36 pm Post subject: |
yes, the bearings are still on the crank, only one of them is atill on each half of the case. To get the measurement should the case halves be attached? _________________ 89 wolfsberg weekender carat
89 Westfalia |
Posted: Tue Feb 21, 2012 11:36 pm Post subject: |
vanagonjetta wrote: |
yes, the bearings are still on the crank, only one of them is atill on each half of the case. To get the measurement should the case halves be attached? |
The numbers on the bearings will tell you if it has been line bored or not. |
Posted: Sun Feb 24, 2013 10:04 pm Post subject: |
Zeitgeist 13 wrote: |
measure the bore and compare to specs. Do you have the main bearings that last ran in the case? |
I cannot find the specs for the case bores anywhere I have looked. I have looked in the bentley, another vanagon manual I have, and here on the samba. Do you know where I would be able to find them?
Wildthings wrote: |
The bearings say this on them:
The #1 number is 025 501D then is says Germany CdL
The #2 number is 025 531C
The #3 number is 025 561B Germany CdM
#4 doesn't say anything on it
The #1 and #2 do not seem to look terrible, I have an untrained eye though. The 3 and 4 are still on the crank. Just trying to figure out the most sensible solution. I would like to rebuild this case economically on a lower budget.
It would be my first rebuild and I would use it as a learning experience and mostly just use it around town. I have been tempted by a conversion but still have an affinity for the waterboxer and would use the learning experience to maybe build a better higher budget one in the future.
Thanks for any advice on the subject _________________ 89 wolfsberg weekender carat
89 Westfalia |
tencentlife Samba Member
