hobbybob517 Samba Member
Joined: June 02, 2011 Posts: 1194 Location: Netherlands
Posted: Thu Feb 23, 2012 12:55 am Post subject: Stock wheels don't fit |
Hi guys,
a while back i did a disc conversion on the front,
i used my drum spindles and my stock shocks.
now i'm trying to get my stock wheels back on, and they are hitting the shocks,
i guess i could get spacers, but i'd rather have the wheels fitting good.
i have these wheels...
i wouldn't mind having the old style wheels with the chromed cap,
would that fit? i'm not sure what the stock ET is for those wheels _________________ THE BUILD http://www.thesamba.com/vw/forum/viewtopic.php
SBD wrote: |
3 million rpm? Well there's your problem! No wonder it blew up! |
johnR Samba Member
Joined: August 25, 2009 Posts: 668 Location: Virginia
Posted: Thu Feb 23, 2012 10:29 am Post subject: |
This is the first time I've heard of a disc conversion reducing track width. |
Posted: Thu Feb 23, 2012 10:35 am Post subject: |
it's weird right?
here's the disc mounted on the spindle and shock...
SBD wrote: |
Vinnems Samba Member
Joined: December 23, 2008 Posts: 1183 Location: Simi Valley, CA
Posted: Thu Feb 23, 2012 10:54 am Post subject: |
So, are you saying that the same wheels fit perfect when you have drums and no that you have discs they don't fit? Because that it very strange. Don't know what disc kit you bought, but maybe it's not as thick as the drums were? I don't know what the tolerances they build these discs to are. |
Joel Samba Member
Joined: September 04, 2006 Posts: 11099 Location: NSW Australia
Posted: Thu Feb 23, 2012 1:15 pm Post subject: |
Both sides or just one?
It could just be a case of EMPI hit and miss quality but a few other things come to mind, especially if its only one side.
Play in the balljoint or wheel bearings can cause that.
As can a bent strut or 2 bolt struts having worn bolts that bolt them to the spindle.
Also what size tyres are those? they are very low profile and look abit wide, that can cause it too. _________________ Quick little bug, you got a Porsche motor in that?
1974 Germanlook 1303 2.5 Suba-Beetle |
marchanel Samba Member
Joined: December 19, 2011 Posts: 754 Location: Near Seattle
Posted: Thu Feb 23, 2012 5:45 pm Post subject: |
So what is hitting the shocks?......the tires or the wheels. Those tires look kind of wide to me. |
johnR Samba Member
Posted: Thu Feb 23, 2012 5:56 pm Post subject: |
Compare a drum to the rotor. What's the difference in width from the spindle mount to the face of the drum vs face of the rotor?
One option is Topline Maxx struts which have a coil much narrower than stock. Or maybe you can find a different (narrower) spring for your stock strut.
http://www.superbeetles.com/performance101/may2.htm |
johnR Samba Member
johnR Samba Member
Posted: Thu Feb 23, 2012 6:14 pm Post subject: |
...I'm a bit bored and learning about Super's suspensions... Maybe another choice is Topline's Sport+ coils, $110/pair. They might address the problem.
http://toplineparts.com/products/sportsprings.htm |
flyboat Samba Member
Posted: Thu Feb 23, 2012 6:55 pm Post subject: |
Not suggesting anything about your mechanical prowess, but did you leave out the outer race on the inner bearing? You know, the one you have to pound in with a punch. _________________ 79 super Vert
62 Ragtop Bug
66 tintop Westy
Porsche 914
09 Z06 Vette track car |
Posted: Fri Feb 24, 2012 12:17 am Post subject: |
flyboat wrote: |
Not suggesting anything about your mechanical prowess, but did you leave out the outer race on the inner bearing? You know, the one you have to pound in with a punch. |
first of all, would never hit a bearing race with a punch,
i warmed the disc up gently, had the race in the freezer for a day, then you can just drop it in and let it set.
second it's on both sides, all the ball joints are new, in fact, the whole front end is new apart from the shocks and the spindles.
i was thinking of getting the topline suspension set (i have the 3 bolt by the way) but i figured i might just get different wheels,
o and for the low and fat tires, never caused a problem with the drums, drove fine,
i have thw low n wides on 'cause i live in the netherlands, everything is flat, so i don't realy need big tires.
SBD wrote: |
Bruce Samba Member
Joined: May 16, 2003 Posts: 17285 Location: Left coast, Canada
Posted: Fri Feb 24, 2012 12:24 am Post subject: |
Vinnems wrote: |
So, are you saying that the same wheels fit perfect when you have drums and no that you have discs they don't fit? |
My guess is that he had some stock wheels on it with the drums and they fit. Then he put the discs on and tried to fit a different set of stock wheels and they don't fit.
It's because he's got wheels for a Karmann Ghia or a Type 3. The offset is greater, and they don't fit Super Beetles. _________________
Posted: Sat Feb 25, 2012 12:22 am Post subject: |
Bruce wrote: |
Vinnems wrote: |
It's because he's got wheels for a Karmann Ghia or a Type 3. The offset is greater, and they don't fit Super Beetles. |
nope, same wheels, same shocks, same spindles, same car. _________________ THE BUILD http://www.thesamba.com/vw/forum/viewtopic.php
SBD wrote: |
Posted: Sat Feb 25, 2012 10:36 am Post subject: |
Are those 14" wheels? They look small. My '72 standard uses 15" wheels. What size wheels are recommended for your SB? |
Chris Vellat Samba Member
Joined: April 09, 2004 Posts: 1590 Location: Seattle, WA
Posted: Sat Feb 25, 2012 10:52 am Post subject: |
Perhaps a staggered set? Didn't put the front rims on back and vice-versa?
The rears look like 5.5 ET26 (low backspace) reverse-center sport bug rims...on front it's harder to say... _________________ (3) '69's
'67 Baja
'74 Super
'73 Bay
(2) '77's |
Posted: Sat Feb 25, 2012 11:02 am Post subject: |
I would guess that the discs you put on are designed to work with stock wheels and tires. I don't think those wheels are stock for that car. |
ashman40 Samba Member
Joined: February 16, 2007 Posts: 15982 Location: North Florida, USA
Posted: Sat Feb 25, 2012 12:37 pm Post subject: |
Can you post the actual tire size you are running and possibly the wheel specs (width and back spacing/offset)?
And if you don't mind... please stop referring to your front dampers as "shocks".
They are actually "McPherson struts" (spring and cartridge damper combo). With struts you replace the "strut" or the "cartridge"... no "shocks" involved.
It could well be that the tolerances of the Empi disc kit are off just enough to get your tires rubbing.
If the tire is rubbing at the top ,have you tried to adjust camber (positive camber)?
Worse case, you could add a small spacer (I can't believe I'm suggesting this)... or get smaller diameter springs (assuming they are rubbing on the springs). _________________ AshMan40
johnR Samba Member
Posted: Sat Feb 25, 2012 1:04 pm Post subject: |
I ran a 5.5" (195/60's) set comprised of ET26 Sport rims in back (w/3/8" spacers) and ET40 914 Sport rims on front...the difference is 14mm or ~9/16". You can see how the poster may have an issue if he has a mis-matched set of rims.
I've been at car shows and pointed out to guys their rims vary in offset from side-to-side on the same axle...stuff gets mixed up.
If you do need a spacer, Audi lug-bolts from the 80's are a bit longer, but also M14x1.5 ball-seat...check clearance to drum brake linkage. _________________ (3) '69's
'67 Baja
'74 Super
'73 Bay
(2) '77's |
