wehrbüchse Samba Member
Posted: Tue Mar 06, 2012 11:15 pm Post subject: |
I meant a connection on the harness connector. You're right that the exact input I'm looking for is the sort people who refurb & resell would have, but I was hoping some privy soul to reveal the secrets, as such things normally go on web forum, to the benefit of (almost) everybody. The revelation of similar secrets and the consequent money saved has meant the difference between bring able to own such a high-maintenance vehivle and not. |
n2wheelies Samba Member
Joined: May 31, 2006 Posts: 65 Location: newport beach, ca
Posted: Sun Dec 10, 2017 11:13 pm Post subject: Re: What fails on Digijet ECU? Swapping mine fixed bucking. |
i have an ECU that has failed and drives, it has a part throttle buck and erratic idle. i tried everything and my no name garage buddy in eugene lent me one to try. yep, back ECU that drove great at load... _________________ '87 Vanagon Weekender 'ELNINYO'
past vw's...
'09 EOS 'petal'
'78 scirocco
'66 T2 panel dead tour vehicle, 'mr bus'
'67 13 window
'95 eurocamper 'charlie' (phish tour vehicle)
'03 Mk4 TDI 'steve'
'04 W8 Phaeton 'david' |
Pastelweis Samba Member
Joined: June 02, 2010 Posts: 92 Location: Stockholm / Los Angeles
Posted: Mon Jul 06, 2020 11:57 pm Post subject: Re: What fails on Digijet ECU? Swapping mine fixed bucking. |
Hope I’m not hijacking this thread. But I’d like to share that I had a similar issue on my 89 Vanagon GL Westy (digifant) , no bucking or misfiring but engine would randomly cut out and die or just not fire up. Sometimes it would start again after I pulled over. I had the sparks, cables, rotor and ignition coil changed, but what seems to have solved it in the end was a new relay (driver side) of the two twin relays in the black box above coil. |
