vw76westy Samba Member
Posted: Mon Mar 05, 2012 1:13 am Post subject: low idle, 2.0 FI |
long story... short
i have a 2.0 fi type-4 engine that has just been rebuilt
i have been struggling with low idle from
the break-in to a couple 100 miles of driving
dwel is set
timing is correct
after turning the idle adjusting screw about 5-6turns out
the idle is barly high enough to keep the bus on
with no change if i continue to turn the screw out
if i barly tap the throttle, the rpms go from 500 to 550
then drop back down to 500(held consistantly)
a little more gas (held consistantly)the rpm's jump to 1300-1400
i made it a point to try to give it just enough gas (gas pedal) to
keep rpm's at 1000 but finding that sweet spot is near impossible
with rpm's staying abnormally low then suddenlly moving to high
1 valve adjustment has been made already (hydrollic lifters)
fuel pressure is 35 psi with no change at low rpm or high rpm
i have looked & looked for vacumm leaks but cant find any
fuel pump seems to be working properly
i have a clean,rust free gas tank
fuel filter & fuel lines are new
other than the low idle the engine & fi "seem" to be running fine
i have good power at high rpm
a little sluggish on take off (low rpm)but still in the ballpark of normal
im stumped............ _________________ order your BAY WINDOW T-SHIRT here http://www.thesamba.com/vw/classifieds/detail.php?id=1526918
quote from bay window bus buyers guide........
The Type 4 engine is considered by many to be VW's finest air-cooled motor, |
Westfabulous Samba Member
Joined: January 07, 2007 Posts: 4207 Location: The tropic of Canada, dodging the giant flying moose of Surrey!
Posted: Mon Mar 05, 2012 8:29 am Post subject: |
It sounds a lot like a vacuum leak to me. Checked your intake gaskets, CSV gasket, and injector O rings as well? The intake gaskets are easy to get hung up on the engine tin....I made this mistake myself. _________________ *****************
"I will gladly pay you Tuesday for a hamburger today." |
SGKent Samba Member
Posted: Mon Mar 05, 2012 9:05 am Post subject: |
did you make any changes to the FI system or are the parts the same as what were on the other engine? _________________ “Most people don’t know what they’re doing, and a lot of them are really good at it.” - George Carlin |
pb24ss Samba Member
Joined: June 30, 2005 Posts: 1665 Location: sitting around the fire with the bluegrass band - colorado
Posted: Mon Mar 05, 2012 9:36 am Post subject: |
double relay / AAR bad? |
Posted: Mon Mar 05, 2012 11:31 am Post subject: |
all the gaskets & o-rings are new
except for the plenum to intake boots & gassket for csv (did not remove)
i reused all the fi parts that were on before _________________ order your BAY WINDOW T-SHIRT here http://www.thesamba.com/vw/classifieds/detail.php?id=1526918
SGKent Samba Member
Posted: Mon Mar 05, 2012 11:38 am Post subject: |
just to be sure, the screw you are adjusting is the big one on the throttle body? _________________ “Most people don’t know what they’re doing, and a lot of them are really good at it.” - George Carlin |
Posted: Mon Mar 05, 2012 1:33 pm Post subject: |
SGKent wrote: |
just to be sure, the screw you are adjusting is the big one on the throttle body? |
yes
i have to take it half way out just to keep
the bus from dieing but no matter how
far out i take it the idle wont reach
900-1000rpm _________________ order your BAY WINDOW T-SHIRT here http://www.thesamba.com/vw/classifieds/detail.php?id=1526918
SGKent Samba Member
Posted: Mon Mar 05, 2012 1:48 pm Post subject: |
make sure the plug on the back of the AFM is plugged in. _________________ “Most people don’t know what they’re doing, and a lot of them are really good at it.” - George Carlin |
Amskeptic Samba Member
Joined: October 18, 2002 Posts: 8568 Location: All Across The Country
Posted: Mon Mar 05, 2012 5:18 pm Post subject: |
SGKent wrote: |
make sure the plug on the back of the AFM is plugged in. |
He said "other than the low idle the engine & fi "seem" to be running fine i have good power at high rpm."
VW76Westy, have you visited the inside of the AFM yet? It would help our diagnoses if you could tell us if nudging the little dancing wiper in the CCW direction helps the idle speed recover.
Colin _________________ www.itinerant-air-cooled.com |
SGKent Samba Member
Posted: Mon Mar 05, 2012 10:15 pm Post subject: |
two engines can have slightly different air to fuel mixtures if the cam, valve sizes etc are slightly different.
Raul - I want you to screw the speed screw in and tell me if screwing it in will drop the idle speed. Once it starts to drop, turn the bus off and count the turns in until it stops. Let me know how many.
Next, back it out to where it was just before the idle speed dropped. Then go to the mixture screw on the AFM and turn it exactly 1 turn in. That will richen it. If the RPM speeds up go to two turns. If there is no change at 1 turn, back it out 1 turn to where it was. Now go one turn out (lean) and see if the RPM speeds up or slows down. If it speeds up go to 2 turns. When you are done put it back to where it was when you started and post here. _________________ “Most people don’t know what they’re doing, and a lot of them are really good at it.” - George Carlin
Posted: Mon Mar 05, 2012 10:50 pm Post subject: |
Since this is a fresh rebuild, I am trying to consider any possibility. Have you checked the harness connectors to see if they are right? Could the AAR connector be on the CSV, or something like that, causing the CSV to pee endlessly?
How's the exhaust? Stinky rich? _________________ *****************
SGKent Samba Member
Posted: Mon Mar 05, 2012 11:01 pm Post subject: |
Westfabulous wrote: |
How's the exhaust? Stinky rich? |
I thought about these things too. On the butterfly there is a flat spot. When the butterfly is closed that flat spot aligns with a big flat headed screw which is the speed screw. When the screw is all the way in there is no room around that butterfly for air to get into the engine. When it is all the way out, air goes through that opening. Since using the throttle to goose the engine works, we know that the engine can draw more air and go faster. However since that screw isn't making it speed up past 500 RPM we can guess that the passage when open won't flow more than enough air for 500 RPM. What we have to establish is can it shut down the air. If yes then we probably don't have a vacuum leak. However if it won't shut down the speed then we have air getting around the throttle body and that will then be why the RPM won't speed up. By adjusting the mixture so see what it does we can then guess whether we are lean or rich.
Another way he could test it is to pull a hose off the plenum and see if it speeds way up. If it does then the mixture is way rich and your guess that it could be mixed up plugs is reasonable. A leaky EGR could also cause the symptoms as it injects lots of oxygenless air. _________________ “Most people don’t know what they’re doing, and a lot of them are really good at it.” - George Carlin |
Posted: Tue Mar 06, 2012 12:44 am Post subject: |
ill do these test tomorrow
didnt have time today
while i was trouble shooting i did count the turns
if i turn the idle screw all the way in
in takes 5 1/2 turns out for it idle hi enough to stay on
after 6 turns i dont notice any change in the idle
if it was a vacumm leak
would that mean that the leak is so small it only affects
vac at low rpm's
making it twice as hard to find ?? _________________ order your BAY WINDOW T-SHIRT here http://www.thesamba.com/vw/classifieds/detail.php?id=1526918
SGKent Samba Member
Posted: Tue Mar 06, 2012 9:58 am Post subject: |
that screw on the throttle body is a bypass of the throttle plate. It does the same thing as stepping on the gas a little.
If the air to fuel ratio is too rich or too lean that could cause it to struggle to run right. So could low compression or the auto trans putting too much a load on the engine or the timing being off. The question is which of those is the culprit and what is causing that?
You might also so a cylinder balance test where the plug wire on each cylinder is pulled from the cap one at a time to make sure all are running with the same strength. _________________ “Most people don’t know what they’re doing, and a lot of them are really good at it.” - George Carlin |
Posted: Tue Mar 06, 2012 9:17 pm Post subject: |
adding to this
if i turn the screw in, the idle will go down & die
now,
turning mixture screw on the afm 1-2-3 turns (3 turns in closes it all the way)
in or out did not make a differance
5 turns out & it dies
if i disconect the vacumm line from the plenum (runs to decel & fuel reg)
the idle does go up a barly noticable amount and it gets rough
while playing with the throttle
Colin |
the wiper moves fine
i tried 2 other afm's thinking it might be the needle
but the bus continues to run the same
regardless of which of the 3 afm's i use
(granted 1 does keep the bus "on" a little better & another afm
seemed to give a little better power at high rpm
could it be the throttle body......
after feathering the gas
idle will be at 500 right...
if i pull back alittle on the throttle to make sure the cable is not keeping it open
the idle will kind of go down (but not really)
when i go to open it again, it feels stuck at first pull
then feels fine
remember how i said ...as you give it gas
rpms do not go up then jump to 1500+
if i start at a high rpm, i can slowly (very slowly)
release the throttle and the rpm's will go down to 1000,950,
then i can hear/feel it go out of tune
& the rpm's drop to 500 before i completly let go of throttle
(this done at the throtle not the gas pedal) _________________ order your BAY WINDOW T-SHIRT here http://www.thesamba.com/vw/classifieds/detail.php?id=1526918
SGKent Samba Member
Posted: Tue Mar 06, 2012 10:02 pm Post subject: |
you made some headway. Turning the throttle body screw in causes it to die so we know that the throttle body is working and that it needs the air from the throttle plate to run.
We also know that opening the screw on the AFM allows more air to bypass the vane which makes the mixture leaner as the vane opens less. Since closing it does little but opening it kills it, we know that the engine is running lean.
You have a vacuum leak. Get the vacuum tester - aka Mighty Vac out and test each of the diaphragms - can on distributor, FPR, Decel, and canister purge on the air filter. If your engine has a vacuum line to the trans check that too. Some Plenums have two nipples instead of one so make sure you don't have a plenum with two hose nipples and one is open. If those pass, block the brake booster and see if that changes anything. If the EGR is hooked up, make sure the valve is closing at idle.
If that fails, remove the PCV valve and vent it to the air, cover the hose inlet with something that won't get sucked into the S-boot. If you have an air leak into the case and the PCV valve is bad it can let unmetered air into the S-Boot.
Simply put, something is causing the engine to be lean. _________________ “Most people don’t know what they’re doing, and a lot of them are really good at it.” - George Carlin |
Posted: Tue Mar 06, 2012 10:41 pm Post subject: |
you know im surprised that given how often the pcv needs replacing
and that a good used one is so hard to find
that noone has come up with a solution for some kind of replacment
of this part
Quote: |
You have a vacuum leak. Get the vacuum tester - aka Mighty Vac out |
this might sound a little funny to you but...
i dont have a vacuum tester or mighty vac
and if i did have one i would not know how to use it
to find a vacuum leak,
i have always inspected each hose &
made sure all connections are 100% because in my vw youth
all the problems i ever had were vacuum leaks
but i guess this day was going to come sooner or later
by the way we are discussing my yellow westy
not the orenge 9-seater automatic _________________ order your BAY WINDOW T-SHIRT here http://www.thesamba.com/vw/classifieds/detail.php?id=1526918
SGKent Samba Member
Posted: Sat Mar 10, 2012 8:52 pm Post subject: |
alright here is where im at......
I had the chance to get a snorkel hooked up
and so I was able to get the afm dialed in.....
according to the machine it was running a little rich
also got the timing checked to be dead on 7.5 - 28
the timing was a little advanced before
but now that the timing & air mix is good
I just cant keep the bus “on” at idle
one by one
I disconnected the y-connector & capped off plenum -no change
I tried a different AAR with the old vacuum line & a new elbow no change
replaced the S-boot- no change
replaced the throttle body, new gasket -no change
disconnected the vacuum line(goes to fuel reg) from plenum & capped it -no change
I capped off the hose from the breather (pcv valve) -no change
I tried capping the hose to decel valve (from s-boot)–no change
I removed the clamps from the plenum to intake boots (very large 2inch hose)
& spun the hoses hoping for any change (I had to practically take them off to here them leak)
Then wrapped them with a heavy duty vinyl tape (maybe a crack or hole in the middle of hose)
Before re-clamping them –no change
What now……….
Im starting to fall apart here (no really depression is starting to set in)
Im ready to file down the flap inside the throttle body & pretend the problem went away
Could something be going on with the motor
It seems like the engine is starving for more air
If I had a vacuum leak & unmetered air was getting in
wouldn’t I have a “lean” mixture
for the record the egr is capped off at the plenum
if i place an object over the gas pedal
to bring the idle hi enough to keep it on,(this technic keeps throttle stable)
then disconnect the spark plugs, i do notice a equal change on all 4 plugs
although the "change" is very small _________________ order your BAY WINDOW T-SHIRT here http://www.thesamba.com/vw/classifieds/detail.php?id=1526918
Posted: Sat Mar 10, 2012 8:59 pm Post subject: |
one more thing in the beginning i could not
get it to idle at 900-1000
now i cant get it to stay on at idle
but i can get to idle at 950-1000 if i give it a some gas
the problem has not changed though
just a drop more gas & the idle will jump _________________ order your BAY WINDOW T-SHIRT here http://www.thesamba.com/vw/classifieds/detail.php?id=1526918
