Bus VS bug front tin
busmania
busmania is offline
PostPosted: Mon Mar 05, 2012 7:06 am    Post subject: Bus VS bug front tin Reply with quote
I am converting the engine I am building (1776) to a doghouse set up. The front tin that was on there was from a baywindow and more square. I pulled the longblock from a 70 bay. I would rather not use it as someone just cut a hole for the neck that goes through the tin from the fan shroud. They didnt do a very good job. So, I bought a used piece this past week but am starting to wonder if it is for a bug. How do I tell the difference? Is there a difference?
Busryder
Samba SuperHero
Busryder is offline
PostPosted: Mon Mar 05, 2012 8:10 am    Post subject: Reply with quote
Just to be clear.... Front is Front?
Would you be speaking of the bell housing tin?
If so.... hazetguy has a pic up of a 55' bus specific front tin in the gallery.
There are others there too, I also seem to remember a not too recent thread on this subject.... but I'm still sipping my coffee over here on the Left coast. #Sleep
The kids are starting to get up now... doubt I'll have time to search for it for you now. I did try though...
Lind wrote:
Apparently I was just the lucky asshole that showed up at the right time.
I am a Dick, hear me roar- Laughing
Me, an OVP Lifer...
busmania
busmania is offline
PostPosted: Mon Mar 05, 2012 8:12 am    Post subject: Reply with quote
Yep, front is front. Bellhousing tin is what I am talking about. Ill go search Hazetguy's gallery. Thanks for the tip!
Busryder
Samba SuperHero
Busryder is offline
PostPosted: Mon Mar 05, 2012 8:13 am    Post subject: Reply with quote
http://www.thesamba.com/vw/forum/album_page.php?pic_id=215195
Me, an OVP Lifer...
Clara Premium Member
Clara is offline
PostPosted: Mon Mar 05, 2012 10:35 am    Post subject: Reply with quote
post a pic of your tin.
This is a doghouse bug front tin.
This is what you want if you put a doghoused motor in a split bus:
cdennisg
cdennisg is offline
PostPosted: Mon Mar 05, 2012 1:23 pm    Post subject: Reply with quote
The blue one on the bottom is a front tin for a doghouse cooler in an early bay. Only offered in '71, they can be tough to find.
Clara's post above shows the beetle front doghouse tin, which fits beetles and split buses. That is the one you need.
nothing
DownRiver
DownRiver is offline
PostPosted: Sat Apr 06, 2013 7:25 am    Post subject: Reply with quote
Would this front tin work with a doghouse motor on a 67 doublecab?
This one has the slot cut out, passenger side. Would this need to be covered?
Is this a better choice? Part # 113 119 517 S
RPGreg2600
RPGreg2600 is offline
PostPosted: Sat Apr 06, 2013 7:33 am    Post subject: Reply with quote
Yes, the second one is better since it doesn't have the extra oval shaped hole. They are both for a bug I believe (the smaller round hold on the passenger side is for the reverse and/or brake light wiring. Either one will work, just plug or tape up the extra holes. You will never see it when it's installed.
