Cross shaft bushing kit way to small
Vanapplebomb
Vanapplebomb is offline
PostPosted: Wed Mar 07, 2012 9:46 am    Post subject: Cross shaft bushing kit way to small Reply with quote
Hey dudes,
I have a type 1 AH code transmission. The cross shaft was all messed up when I got it, so I ordered a cross shaft bushing kit to set her right. This one...
Well, everything accept the spring and set screw was wayyyy to small for the shaft. Good thing it was only 8 bucks Rolling Eyes
Any ways, I saved all the parts from the one that was on I pulled. The snap rings, washer, and bronze bushing with the ??plastic?? inner sleeve look like they are in good shape. The rubber bushing on the other hand...its dry rotting.
Also, there was only one rubber thing on the shaft I pulled out...arn't there supposed to be two?
What do I do about the rubber part?
I thought about using the rubber pieces that came with the new kit and stretching the living daylights out of them to fit them over the cross shaft. I'm just afraid that they will rip while on the shaft Confused
Your input is golden, thanks!
1800 Type 4 Berrien 295
mcmscott
mcmscott is offline
PostPosted: Wed Mar 07, 2012 9:50 am    Post subject: Reply with quote
You have a 72 or later trans, these all had larger crosshafts, if you use a hd kit with large bronze bushing no rubber sleeves will be used
Vanapplebomb
PostPosted: Thu Mar 08, 2012 11:02 am    Post subject: Reply with quote
Yes, it is a 72 Transmission. How important are those rubber pieces, all it look like to me is that they keep the grease around the plastic part inside that metal bushing.
And whats this about the heavy duty kit?
mcmscott
mcmscott is offline
PostPosted: Thu Mar 08, 2012 11:55 am    Post subject: Reply with quote
The hd kit, or bushing, replaces the steel sleeve, plastic bushing, and rubber seals with a one piece bronze bushing
jsturtlebuggy
jsturtlebuggy is offline
PostPosted: Thu Mar 08, 2012 12:19 pm    Post subject: Reply with quote
Weddle now has oil impregnated bronze cross shaft bushings in both 16mm and the later 20mm size.
These work better than the brass ones in a transmission that not seeing constant maintenance such a racing trans would see.
Joseph
Fair Oaks/Orangevale, CA
Elrod Motorsports
Motion Tire Motorsports
Into Volkswagens since 1960
mcmscott
mcmscott is offline
PostPosted: Thu Mar 08, 2012 12:28 pm    Post subject: Reply with quote
I use the oil impregnated bushings in all the Mendis I build
jsturtlebuggy
PostPosted: Thu Mar 08, 2012 12:49 pm    Post subject: Reply with quote
Scott,
What I was saying is that on a street car there really is not a way to regrease the brass bushing without taking it apart, (maybe a zerk fitting could be installed) so over time the grease dries out and shaft starts sticking or binds up.
So the oil impregnated bronze bushing makes more sense to use.
They work great in all applications.
In the early swing axles transmission for a time period VW used the oil impregnated bronze bushing for the cross shaft before changing to the plastic w/rubber bushings inside the aluminum sleeve.
Joseph
Elrod Motorsports
Vanapplebomb
PostPosted: Thu Mar 08, 2012 4:13 pm    Post subject: Reply with quote
Alright, thanks guys.
What about those rubber pieces inside. What should I do about those? Is it possible to just find some o-rings to fit in to hold the grease?
mcmscott
mcmscott is offline
PostPosted: Thu Mar 08, 2012 6:05 pm    Post subject: Reply with quote
jsturtlebuggy wrote:
Scott,
I agree 100 %, most silicone bronze bushings are impregnated any way, I was not trying to confuse the op by giving more options, my bad
jsturtlebuggy
PostPosted: Thu Mar 08, 2012 8:30 pm    Post subject: Reply with quote
Van,
Get one of these from Weddle Industries (805) 562-8600
They come in both 16 and 20mm sizes.
What you have from your video from another thread is the 20mm size.
Make sure you have the inner snap ring and washer on shaft so it lines correctly.
These bronze bushings work great if using a stronger pressure plate, will help keep cross shaft from moving at angle when stepping on pedal.
Also make sure arms are welded on shaft for TO bearing. The stock welds can break loose.
Joseph
Elrod Motorsports
Bruce
Bruce is offline
PostPosted: Fri Mar 09, 2012 1:40 am    Post subject: Reply with quote
.... on a street car there really is not a way to regrease the brass bushing without taking it apart, (maybe a zerk fitting could be installed) so over time the grease dries out and shaft starts sticking or binds up.
It takes years, if not decades of daily use for the lube in there to dry out. As long as the mechanism is taken apart, cleaned and re-greased, you're good for many years.
I know a guy who rebuilds gearboxes and when he gets a trans, he grabs onto the arm and levers it against the spring. If it moves freely, he leaves it alone, not taking it apart to clean and re-lube it.
jsturtlebuggy
PostPosted: Fri Mar 09, 2012 8:53 am    Post subject: Reply with quote
It all depends on how vehicle is being used on how long it will last.
Using it in dusty, dirty, muddy, and water such as were a Dune Buggy will go, things get gummed up faster then just driving on pavement.
Joseph
Elrod Motorsports
Vanapplebomb
PostPosted: Fri Mar 09, 2012 9:34 am    Post subject: Reply with quote
Thanks jsturtlebuggy for 1, watching my silly little videos Laughing and 2, for your help. You too mcmscott.
...Say, if thats all it is, I could probably just make one of those bushings. I don't have access to the impregnated stuff, but a grease groove shouldn't be any problem to make.
A grease groove should help keep that stuff in there a long time.
Yeah, hmm...So I'm thinking that if it ever does dry out, then the set screw could be removed, and a zerk screwed in, give it a small pump, remove the zerk, and thread the set screw back in.
Vanapplebomb
PostPosted: Wed Apr 04, 2012 12:19 pm    Post subject: Reply with quote
I have seen a lot of bug pack urethane bushings for the large cross shafts. Does anyone know about the quality?
mcmscott
mcmscott is offline
PostPosted: Wed Apr 04, 2012 3:23 pm    Post subject: Reply with quote
there OK I still prefer the bronze bushing
Vanapplebomb
PostPosted: Wed Apr 04, 2012 8:15 pm    Post subject: Reply with quote
I am also having trouble finding the smaller bushing for the other side of the cross shaft, the one thats pressed into the case. It is a bit sloppy. The shaft could wiggle around in it a little bit. It was minimal, but I think it could definitely be better.
69 GVert
69 GVert is offline
PostPosted: Sun Oct 11, 2020 4:20 pm    Post subject: Re: Cross shaft bushing kit way to small Reply with quote
Regarding the red urethane bushing. I put one in 20 years ago and the car has not been driven more that 30 miles since. I found that the urethane had swelled up on both sides and would not slide out. I ended up cutting the exposed parts off just the get the shaft out and am in the process of drifting the remainder of the bushing out now. Going with bronze.
Aircooled? Drive one a day, that's all I ask!
mark tucker
mark tucker is offline
PostPosted: Mon Oct 12, 2020 8:29 am    Post subject: Re: Cross shaft bushing kit way to small Reply with quote
I drilled my shaft and added a zerk to the end of it for greezzing it.along with a intersecting hole drilled in the shaft at the main pressure/load location so the gresse gets where it needs to be. I also true up the shafts, most are bent...yes even new ones, I reckon it's from the weld pulling it wonkey, some more than others. my gold iridited ones were worse.( bugpoop I think) I also remachined a big shaft to put in my rino case that took the small shaft along with making a bush to fit it.
