borninabus Samba R&D Dept.
Joined: May 18, 2006 Posts: 4539 Location: Arizona Highways
Posted: Thu Mar 08, 2012 9:03 am Post subject: Strange Dist Cap Wear |
never seen this before.
this cap has maybe 1000 miles on it in a 78 FI bus.
any ideas
the rotor damage to the cap was from me starting it w/ the cap loose
coincidence? _________________ 88 Van WBX, A/T - 13 JSW TDI 6M/T - 2012 Touareg TDI Sport |
Dale M. Samba Member
Posted: Thu Mar 08, 2012 9:17 am Post subject: |
N0......
Rotor is analogous to weed whacker and cap is the weed....
mark tucker Samba Member
Posted: Thu Mar 08, 2012 9:22 am Post subject: |
weed wacker every time sheed slow down, must of had somethen loose. replace them both with the correct parts instaled corectly, check it again next year.add new plugs&plugwires too,iridum plugs.they take less voltage to fire and last longer under normal conditions.but if you drop a screw down the intake while it is running I dont think they will last any longer than a cheep old champeion |
DarthWeber Samba Member
Joined: November 24, 2007 Posts: 7543 Location: Whittier,CA
Posted: Thu Mar 08, 2012 11:40 am Post subject: |
When you tried to start it with the cap loose it may have knocked the carbon out of place and it got trapped at an odd angle and the rotor just ground it away. What does the rotor top look like? _________________
Mitey62 wrote: |
Swapped the Compufire for a Bosch blue and some points I had sitting around, started 1st crank. Took her out for a drive, pulls harder, more RPM, and runs smoother. I think I'll be sticking with points from now on. |
RockCrusher wrote: |
JB weld the case halves....that'll keep the fretting to a minimum. |
Posted: Thu Mar 08, 2012 12:13 pm Post subject: |
DarthWeber wrote: |
When you tried to start it with the cap loose it may have knocked the carbon out of place and it got trapped at an odd angle and the rotor just ground it away. What does the rotor top look like? |
i didn't "try" to start it; i started it
which i have done before ( ) and never seen damage like this.
the rotor looks a bit "burnt" but not worn like it ground the thing down.
i like your theory about the electrode breaking though.
i bet if i took the dist out i would find it in there somewhere. _________________ 88 Van WBX, A/T - 13 JSW TDI 6M/T - 2012 Touareg TDI Sport |
Posted: Thu Mar 08, 2012 12:17 pm Post subject: |
borninabus wrote: |
Amazing how much abuse these little motors can take! The carbon electrode is on a light spring and could have been whipped out of the cap and ??? (eaten alive!) Might be in the bottom of that distributor though, you never know. _________________
Mitey62 wrote: |
jsturtlebuggy Samba Member
Posted: Thu Mar 08, 2012 12:24 pm Post subject: |
What coil are you using? Does it have a internal or external resistor.
I have seen in the past with the wrong coil, things get burnt up such as what you have and even burn out the resistor in the rotor. _________________ Joseph
Elrod Motorsports
Motion Tire Motorsports
Into Volkswagens since 1960 |
earthquake Samba Member
Joined: January 10, 2008 Posts: 3984 Location: SANDY VALLEY, NEVADA
Posted: Thu Mar 08, 2012 6:35 pm Post subject: |
I just realized what a clear cap is good for, so you can see the food when you use your distributor as a mini food processor
Chef Casey _________________ 74 CLASS 11 LOOK-A-LIKE
69 DUNE BUGGY
79 INTERNATIONAL SCOUT II
05 SCION XB SERIES RELEASE 2[#437]
95 Chevy C3500 dually
98 Ford E150
Link to Kelly J. Nolte 3/20/53 - 11/6/08
https://time-zonelabs.blogspot.com/p/about-kelly.html
DEATH TO CHINGERS!
[From a military recruitment poster in the novel "The Stainless Steel Rat" By Harry Harrison] |
Posted: Thu Mar 08, 2012 6:51 pm Post subject: |
open or almost open wires will eat away at the center elected trode.and is very hard on coils too.I vote for a new one in the next electron voting session. |
Posted: Thu Mar 08, 2012 7:16 pm Post subject: |
earthquake wrote: |
I just realized what a clear cap is good for... |
you're gonna love my nuts _________________ 88 Van WBX, A/T - 13 JSW TDI 6M/T - 2012 Touareg TDI Sport |
Glenn73 Samba Member
Joined: May 30, 2011 Posts: 1190 Location: West Jordan UT
Posted: Thu Mar 08, 2012 9:52 pm Post subject: |
borninabus wrote: |
earthquake wrote: |
you're gonna love my nuts |
I think he said a Clear cap, not a Q oh never mind. |
