35.5 X 33mm valves in a Mexican cylinder head?
Alexmobil
Alexmobil is offline
PostPosted: Sun Mar 11, 2012 8:32 am    Post subject: 35.5 X 33mm valves in a Mexican cylinder head? Reply with quote
Can I install a set of 35.5mm(intake) X 33mm(exhaust) valves in a mexican head (043 101 375 ) for a 1600cc stock beatle? Could improve the flow in the head? or I could ruin it? The mexican head has 33 X30 valves.
Thanks in advance.
Alex
mark tucker
mark tucker is offline
PostPosted: Sun Mar 11, 2012 9:21 am    Post subject: Reply with quote
probably.check the od of the seats.if done with the proper raidi valve job it will up the velosity&flow.you may need to unshroud the valves in the chamber too.
ALB
ALB is offline
PostPosted: Sun Mar 11, 2012 9:22 am    Post subject: Reply with quote
You could, but what are the ports cast like? do you have a 35x32 dual port head to compare them to? Will you be installing larger seats?
On a lifelong mission to prove (much to my wife's dismay) that Immaturity is Forever!!
Alexmobil
PostPosted: Sun Mar 11, 2012 11:16 am    Post subject: Reply with quote
thanks for the answers.
I will install larger seats since the valves are bigger.
Yes, I have a 35 x32 valve to compare the ports Ill post the pics ASAP
modok
modok is offline
no, the seats are too small
