Mid West Dubber Samba Member
Joined: July 11, 2011 Posts: 315 Location: Natimuk, VICTORIA, AUSTRALIA
Posted: Thu Sep 23, 2021 6:59 pm Post subject: Re: Rusty's '63 11 window |
Right side battery tray required some slight adjustments...
Now in and fitting much better...
Posted: Wed Sep 29, 2021 2:42 am Post subject: Re: Rusty's '63 11 window |
The left side was much the same as the right, rear corner rusted out and beat up and full of bog. Vents were bent, twisted and split. Off it comes...
The front section of the left wheel arch was hacked open and was caved in. Photo doesn't show it very well. Was lucky enough to get an original section to repair this... Still needs to be finished off and the lower section repairing but much better
OvalinAz Samba Mini Tech
Posted: Sat Oct 02, 2021 5:07 pm Post subject: Re: Rusty's '63 11 window |
More paint and surface rust removal...
Posted: Sun Oct 10, 2021 2:05 am Post subject: Re: Rusty's '63 11 window |
Small repair on the left side D pillar...
Outriggers and inner sill welded in on the left side...
Getting the lower C pillar clamped and tacked...
Trial fitting the rear cargo door and side panel to see how everything lines up...
Getting the rear corner sorted with the side panel clamped in place. Painted in behind the rear corner before it was welded in place and tail light hole is cut...
Mr Margaret Scratcher Samba Member
Joined: February 10, 2013 Posts: 246 Location: Cambridge UK
Posted: Mon Oct 11, 2021 2:25 pm Post subject: Re: Rusty's '63 11 window |
Mid West Dubber wrote: |
I think I'm going to have a similar thing on the 12V tray I have for my 66 - was what you did to pul the corner radius in so that the outer edge would sit flush against the inside of the side of the rear corner? |
Posted: Mon Oct 11, 2021 6:32 pm Post subject: Re: Rusty's '63 11 window |
Mr Margaret Scratcher wrote: |
Yes that is correct, I ran a cut off wheel around the radius and tacked it in place until I was happy with how the shape fit the inside of the rear corner |
scrivyscriv Samba Electrician
Joined: October 04, 2011 Posts: 2922 Location: Memphis
Posted: Mon Oct 11, 2021 10:28 pm Post subject: Re: Rusty's '63 11 window |
Excellent job on the roof. That's how it's supposed to be done! I'm a big fan of using 3M panel bond with a spot welder. I'm curious, though, since you spotted the roof in, why not spot the other similar areas? _________________ Robert in Memphis
Engine rebuild thread
If you're ever in the Memphis area, you are welcome to stop by for advice and help. |
Posted: Tue Oct 19, 2021 7:31 am Post subject: Re: Rusty's '63 11 window |
Brilliant thanks. I've been tapping mine with a hammer to try to avoid cutting but in reality it's just making it all a bit out of shape on the top.
Did you also do the Mike Fn Garage method of tack welding along the top edge rather than punching and welding along the flange? |
Posted: Tue Oct 19, 2021 1:17 pm Post subject: Re: Rusty's '63 11 window |
No I marked the top and bottom, pulled it out and drilled holes around the corner and plug welded from the outside |
Posted: Fri Oct 22, 2021 5:27 am Post subject: Re: Rusty's '63 11 window |
Ah thanks! |
Posted: Fri Oct 22, 2021 3:56 pm Post subject: Re: Rusty's '63 11 window |
Finishing off the rear wheel tub repair. Lower sections welded on and welded to the inner sill...
Posted: Fri Nov 05, 2021 7:03 pm Post subject: Re: Rusty's '63 11 window |
Some work on the passenger side B pillar. The Klassic Fab inner pillar didn't have this little pressing. My OCD kicked in so I transferred if from the OG panel onto the new one...
Also the front section of the new B pillar didn't have the door striker adjustment ribs. So I measured off the old one and transferred it to the KF one...
The window frame rot on the passenger side cut out and repaired...
Posted: Wed Dec 08, 2021 1:11 am Post subject: Re: Rusty's '63 11 window |
Engine lid stripped and then a quick sandblast in the areas which were showing signs of rust. All cut out and repaired...
Posted: Thu Dec 23, 2021 1:42 am Post subject: Re: Rusty's '63 11 window |
Engine lid hanger welded in place. The top edge was rusty so made up two new sections and got them welded in and dressed up.
Hope everyone has a good Christmas and gets a break. Looking forward to getting this build thread up to date and getting cracking on the bus again.
1970PAKombi Samba Member
Joined: July 10, 2019 Posts: 264 Location: Denver, PA
Posted: Thu Dec 23, 2021 7:15 am Post subject: Re: Rusty's '63 11 window |
Looks like it's coming very well, great skills and amazing restore! |
Posted: Mon Dec 27, 2021 2:17 am Post subject: Re: Rusty's '63 11 window |
Rear hatch stripped and sandblasted. Some paint on the inside before the skin got welded in place...
Posted: Sat Jan 15, 2022 3:20 am Post subject: Re: Rusty's '63 11 window |
Cargo door side B pillar fitted and welded up. This was a tricky repair as I had to redo both hinge mounts. The autocraft skin required some tweaks to the hinge mount as it was nearly 4mm out of alignment. Happy with the outcome, still some grinding to finish off...
Posted: Sun Jan 23, 2022 12:46 am Post subject: Re: Rusty's '63 11 window |
Need to get this build up to date as I approach the 12 month mark of the build. Short side is on. Paint and weld through primer in the structure and inside of the skin. Some excess glue to clean off and welds to grind...
Posted: Wed Jan 26, 2022 1:39 am Post subject: Re: Rusty's '63 11 window |
Left side battery tray and splash panel welded in. This battery tray required a little more re shaping then the right side but I forgot to get pics.
