WhirledTraveller Samba Member
Joined: January 09, 2008 Posts: 1399 Location: Cambridge, MA
Posted: Sat Mar 24, 2012 8:31 am Post subject: |
I bought an alternator from that ebay guy which was a stock 55amp supposedly rewired to 75 amp, much cheaper than the proper 70 amp alternator and drops right in no need to muck with pulleys and backplates.
I can't say for sure whether it's putting out 75 amps, but the voltage is rock steady at all RPM's which is more than I can say for the Bosch unit it replaced which lasted all of one year.
Even with a fridge and propex heater, your amp demand may be less than you think. Fridge = 5 amps maybe, propex = 2 amps. Charging two batteries is no big deal for the stock alternator, the real problem is steady draws like the 20amps of the BA-6 heater or big audio systems. You will find that with constant voltage charging in an automotive system, the amperage the batteries draw during charging levels off at a pretty modest level for most of the charge. Putting in a bigger alternator doesn't change a whole lot especially if you're using a standard charge relay which is inherently limiting.
There's a simple way to test this without an ammeter, just a voltmeter. Take your bus with fully charged batteries and run it, rev the engine just a bit, and take note of the system voltage at the battery. It should be around 14 volts.
Now run your house battery half way down and repeat the same test with all your accessories on. If it's still at 14 volts then the alternator is big enough and any bigger is just a waste of time. _________________ 1977 Westy, Automatic. Big Valve heads, CS Cam. |
gatorjos Samba Member
Joined: April 19, 2003 Posts: 406 Location: San Francisco
Posted: Tue May 21, 2013 7:41 am Post subject: |
WhirledTraveller wrote: |
That's probably from the guys in Van Nuys that I'm looking at. I assume they add some more windings to the stock alternator or so. I am calling them in a bit to see if they have one in stock.
You can put an inductive clamp-style amp meter around your charge cable rev the engine to see what it's putting out. I spliced my house battery with a 40A relay and 10AWG, so I should be able to push lots of current that way
Were you able to use the stock voltage regulator with the 75A alternator?[/quote] _________________ 1977 Westfalia Weekender Berlin "The Kitebus" aka " Colonel Mustard"
Previous romances:
1972 Ghia cabriolet (full body-off restoration -- stolen after five years of ownership)
2004 Passat 1.8T (manual)
http://21stcenturyhobo.com |
1975 Kombi Samba Member
Joined: August 12, 2007 Posts: 2452 Location: Acton, Ontario, Canada
Posted: Tue May 21, 2013 8:09 am Post subject: |
webwalker wrote: |
kamara wrote: |
The e-bay one is 120A and fits in the stock location. |
I really want to believe that. But something tells me it is either too good to be true...or a mirage. |
http://www.ebay.ca/itm/VW-Mini-Bus-Porsche-914-Hig...0796737924 _________________ Brett
“He’s decieving you boy! Reach into his pocket and take what he’s got.” Mr. Crabbs.
75 Westy auto
03 Jetta TDI
71 SB
74 Westy
Licensed pilot (single engine land VFR)
Rust In Pieces: 72 Bug, 73 Bug, 81 Rabbit LS D 2D, 83 Rabbit D 2D, 84 Jetta TD GL, 85 Jetta D, 68 Z28 RS 302, 91 Passat 16v |
TomWesty Samba Member
Joined: November 23, 2007 Posts: 3482 Location: Wyoming,USA
Posted: Tue May 21, 2013 8:13 am Post subject: |
gatorjos wrote: |
You can put an inductive clamp-style amp meter around your charge cable rev the engine to see what it's putting out. |
Wouldn't the induction ammeter only work if he was checking alternating current? _________________ If you haven't bled on them, you haven't worked on them.
Visit: www.tomcoryell.com and check out my music! |
Posted: Tue May 21, 2013 8:27 am Post subject: |
TomWesty wrote: |
gatorjos wrote: |
Wouldn't the induction ammeter only work if he was checking alternating current? |
No, it works for DC. I used one to check how much current was going to my house battery. _________________ 1977 Westfalia Weekender Berlin "The Kitebus" aka " Colonel Mustard"
Previous romances:
Posted: Tue May 21, 2013 11:06 am Post subject: |
I talked to Bob -- very nice guy and ordered a 75A for $99. They take the stock alternator and put in a Mercedes stator making it 20A more juicy. They also sell the AL108X for $175, but I'm cheap
Number is 818 442 9082 BNR parts in Van Nuys _________________ 1977 Westfalia Weekender Berlin "The Kitebus" aka " Colonel Mustard"
Previous romances:
jstrother123 Samba Member
Posted: Sat Nov 30, 2013 8:31 pm Post subject: |
Sorry to join in this discussion so late, but do you have contact info for the Van Nuys guys you talked to? Thanks.
Jim |
Posted: Sat Nov 30, 2013 9:54 pm Post subject: |
Jim,
I put the name and number in the post above.
Cheers,
Jos _________________ 1977 Westfalia Weekender Berlin "The Kitebus" aka " Colonel Mustard"
Previous romances:
Vince Waldon Samba Member
Joined: November 07, 2010 Posts: 451 Location: Edmonton, Alberta
Posted: Sat Nov 30, 2013 10:04 pm Post subject: |
gatorjos wrote: |
The actual answer is: it depends.
The inexpensive inductive-clamp ammeters only work on alternating currents because they use a simple loop to inductively couple to the changing electric field set up by alternating current.
More expensive clamp-on ammeters also have a Hall-effect transducer to measure static magnetic fields and are therefore able to properly measure DC current as well.
How to tell? DC clamp-on ammeters will usually be labeled as such...they are quite a bit more expensive and the manufacturer generally wants you to know why you are paying more money. The cheap clamp-on ammeters from Harbour Freight etc.... usually just good for A/C amps. _________________ Vince Waldon Edmonton Alberta CANADA
1970 baywindow |
Posted: Sat Nov 30, 2013 10:10 pm Post subject: |
Thanks, for some stupid reason I read that as a part number. I need to read things more carefully in the future.
Jim |
1967250s Samba Member
Posted: Mon Dec 02, 2013 1:35 am Post subject: |
Don't see how the stock regulator would work for very long. All the charging wires would need to go up one or two sizes. Are you sure it's ok? I'd sure be interested in putting a good electric heater somewhere. |
DougB Samba Member
Joined: January 09, 2007 Posts: 1076 Location: Falls Church, Virginia, USA
Posted: Wed Jun 29, 2016 10:29 am Post subject: Re: 70 amp alternator |
Hello all,
Just wanted to check in to see how those with the higher output alternators from the eBay guy in Van Nuys are fairing...any issues with them so far? Seems like a great option but, like another past poster said, it seems a bit too good to be true.
Thanks,
- Doug _________________ '75 Campmobile (tin-top to SpaceRoof)
'73 Fastback
'52 BMW R67/2
'41 Zundapp KS600
'55 Puch SGS250
A very, very understanding wife |
BayCreamPuff Samba Member
Joined: August 10, 2015 Posts: 769 Location: Oakland, CA
Posted: Wed Jun 29, 2016 10:42 am Post subject: Re: 70 amp alternator |
DougB wrote: |
Hello all,
Thanks,
- Doug |
Installed mine in April. No issues. They give them a light coat of silver paint to make them look nice. Rubbed off a lot of it wiggling the damn thing into place. _________________ Cream Puff
'79 CA Stock FI Deluxe Campmobile
Earl Grey
'87 GoWesty 2.2 Westfalia
Marsha Mellow
'00 Eurovan VR6 Full Camper |
Posted: Tue Jul 05, 2016 6:02 am Post subject: Re: 70 amp alternator |
DougB wrote: |
Hello all,
Thanks,
- Doug |
Mine is still going strong from early 2012. I can't really vouch for whether it's truly 75 amps or not but it works without issue. _________________ 1977 Westy, Automatic. Big Valve heads, CS Cam. |
DougB Samba Member
Posted: Tue Jul 05, 2016 8:48 am Post subject: Re: 70 amp alternator |
Good to hear...just got my eBay bucks certificate for this quarter so I might apply it to a purchase of one of these things.
Thanks! _________________ '75 Campmobile (tin-top to SpaceRoof)
'73 Fastback
'52 BMW R67/2
'41 Zundapp KS600
'55 Puch SGS250
69BahamaYellow Samba Member
Joined: April 22, 2011 Posts: 536 Location: Talbott, TN
Posted: Tue Jul 12, 2016 5:10 am Post subject: Re: 70 amp alternator |
DougB wrote: |
Just wanted to check in to see how those with the higher output alternators from the eBay guy in Van Nuys are fairing |
If you're talking about Custom Alternators (that's where I got mine), the quality of their rebuilds seem pretty good. The staff there is super helpful also. I've only had mine since January, but it's working great with no issues. Mine started out as a Bosch 70 Amp, that they upgraded to 110 Amp. Only thing to be aware of is they seem to be a small family business, so they close up shop completely for vacations and such, and if you happen to need support at one of those times, you'll have to wait till they return |
gleason Samba Member
Posted: Wed Nov 02, 2016 8:01 pm Post subject: Re: 70 amp alternator |
Ok, opening an older post here. I'm looking at putting and electric compressor in for my AC in my 74 9 pass. Came with a 1700, PO replaced with a 1600 and generator/regulator. Building a 2.0 for it so I would like to have a 75 amp alternator. "I talked to Bob -- very nice guy and ordered a 75A for $99. They take the stock alternator and put in a Mercedes stator making it 20A more juicy. They also sell the AL108X for $175, but I'm cheap Laughing
Number is 818 442 9082 BNR parts in Van Nuys" From a previous post. Seems like they are on ebay now for like $275, quite a bit more than the $99 of the previous post. Any info on this? I'd sooner have a stock style with more amps and avoid all the problems and different parts noted above in getting what I want, but a little pricey? Or am I just cheap?? http://www.ebay.com/itm/VW-Mini-Bus-Porsche-914-Alternator-75-Amp-High-Amp-Generator-/282047978942 |
twinfin Samba Member
Joined: June 20, 2006 Posts: 62 Location: Santa Cruz, California
Posted: Sat Nov 12, 2016 4:54 pm Post subject: Re: 70 amp alternator |
Same here. Wondering why the big price hike from $99 to $275. In only a few years
I see two companies on ebay offering the higher output alternators that were mentioned here. They are "bnrparts" for $275 plus $20 Shipping and "eagleautoelectric" for $250 plus $20 Shipping.
There listed as a AL75x that have been upped from stock 55amps to a higher output of 75Amps.
I wonder if the alternators wiring harness needs to be upgraded?
...also they look to offer at times the AL108X 70amp model upped to 120Amps
I need to order one asap. My alternators bearing just froze and smoked the belt! _________________ ________________________________
"It's knowledge to learn from your mistakes. But it's wisdom to learn from others!"
“He that goeth to bedde wyth Dogges, aryseth with fleas.”
"The Blue Submarine"
1977 Campmobile, Type 4 2.0 liter Federal, Non-Catalyst, Fuel Injected with Valvetrain from the type4store, 411 Heat Exchanger Preheaters, S&S Header, Supertrapp Silencer. ...and a lot of help from Clatter and TCash and friends! |
Posted: Sat Nov 12, 2016 5:07 pm Post subject: Re: 70 amp alternator |
Well they told me the cores have went up so much. I guess the Mercedes or what ever they use are in short suppley. He told me $200 if I send him a core 55amp. What I like is that nothing else has to be changed. No fan or housing or anything. Supposed plug and play and charge like crazy! No a camper or a big stereo useage or anything, but I want to make sure I have enough as I may put electric compressor for my AC in the future. |
Posted: Mon Nov 14, 2016 9:19 am Post subject: Re: 70 amp alternator |
Anybody know what size stator is in the 55 amp? I talked to a local rebuilder and he said if we can find the dimensions of that, he can look up to see what else might be available. If my alternator is ok EXCEPT swapping a new stator, he tells me that we would be @ about $60-75!!! I may have to send him one of mine just to see what we can do.. |
