early Samba Member
Joined: January 19, 2012 Posts: 185 Location: Glen Carbon, IL
Posted: Mon Mar 19, 2012 7:12 am Post subject: 73 SB front Suspension - Strut Upper Bearing Mounting plate |
when / how do you determine its time to replace the upper Strut Bearing mounting plate?
plates currently have some play ( side to side ) as mounted on strut but they do spin just fine. no binding .
what are you looking for to determine they need to be replaced? _________________ early-
Barnfind westy project
my 73 sports bug project build
http://www.thesamba.com/vw/forum/viewtopic.php?t=497088
Current Projects :
73 Sport Bug - L13M gone now
67 Westfalia
57 oval window ragtop - sold june 2021
61 sedan
68 Corvette Roadster - Small Block, 4 Speed
86 GMC Sierra Classic- 4x4, Shortbed
94 Harley Flstn |
19super73 Hardcore Stock Nazi
Joined: October 18, 2007 Posts: 4351 Location: Cité Soleil
early Samba Member
Posted: Mon Mar 19, 2012 8:45 am Post subject: top bearing plates |
I'm not sure if they are original or not. i'll have to get the magnifying glass and check the numbers. The springs are Red and im not sure if that is OEM or not either but they are a bit rusty.
I may as well replace the plates since i have the body off the frame and its all apart right now, guess I was just trying to save a hundred bucks where I can
thanks! _________________ early-
Current Projects :
67 Westfalia
61 sedan
94 Harley Flstn |
