seandoyle Samba Member
Joined: March 19, 2012 Posts: 2 Location: Dallas United States
Posted: Mon Mar 19, 2012 10:43 am Post subject: New to the world of VW with a 1993 Eurovan with trans issue |
Hi Eveyrbody, I finally got the bus I have always wanted and it drove and the 5 speed shifted great on the test drive. After buying the van and taking to the car was the next day, I was backing it into my garage and could not get the van out of reverse? The shifter was stuck in reverse and I got it unstuck, but the van wont go into any other gears even though it is free from reverse.
My limited research leads me to think it is a linkage problem with some of the plastic parts in the linkage.
Any ideas here are greatly appreciated!
Sean |
r39o Samba Polizei
Posted: Mon Mar 19, 2012 11:00 am Post subject: |
Welcome to the herd.
Yes, likely some part in the shift linkage is not well.
Can't say what, though.
You are going to have to get in or under and look.
Try vagcat.com and look at the parts involved.
Maybe you will get an idea.
Good luck.... _________________ "Use the SEARCH, Luke" But first visit the Vanagon FAQ!
snowsyncro Samba Member
Joined: January 11, 2009 Posts: 1557 Location: East Preston, Nova Scotia, Canada
Posted: Mon Mar 19, 2012 1:52 pm Post subject: |
Shift linkage is a common problem. There is a plastic ball (#16 in the Bentley photo) on top, up near the firewall, this wears and pops out. Take a look at these photos, it might help. That is a temporary repair (unless it works) using a piece of aluminum welding wire to keep the ball in place. This reminds me, I must put that on a list of things to to someday -- been like that for about five years now.
Don't be fooled by the closest bit of welding wire in this photo -- that is holding up something else. Look beyond that, down deeper where the rusty bits are.
RonC |
Posted: Mon Mar 19, 2012 1:58 pm Post subject: Thank you! |
Thanks from Texas!
Sean |
JPrato Samba Member
Joined: December 15, 2006 Posts: 788 Location: Livonia, NY
Posted: Mon Mar 19, 2012 1:58 pm Post subject: |
congrats, now on to your second purchase, a Bentley manual for your new pride and joy. It should give you the info you need to check the linkage and any other problem you might have with it. Unless you have a manual you are just guessing at issues.
http://www.bentleypublishers.com/volkswagen/repair...ebahn.html
Not cheap, but the best investment you can make by far. Even if you don't do all your own wrenching it can help you diagnose problems and let you fix the things you can. _________________ Joe
87 Syncro Tin Top project
84 Westy, 2.5L Subaru power
06 Subaru 2.5 turbo in waiting
46 Cessna 140 |
Posted: Mon Mar 19, 2012 2:03 pm Post subject: Re: Thank you! |
seandoyle wrote: |
Thanks from Texas!
Sean |
You are welcome. Texas is one of my favorite places -- I have done quite a bit of work there.
See what I did there? Up here we would spell 'favourite'!
RonC |
terraprojects Samba Member
Joined: August 16, 2021 Posts: 4 Location: Joshua Tree, California
Posted: Mon Aug 16, 2021 10:40 am Post subject: Bentley Catolog page with part #2? |
snowsyncro wrote: |
RonC |
Anyone have the page or two before the one pictured from the Bentley Catalogue?
I need to know what part #2 is and associated bushings to order and install on my Eurovan.
David |
1994Karuso Samba Member
Posted: Mon Aug 16, 2021 11:26 am Post subject: Re: New to the world of VW with a 1993 Eurovan with trans issue |
Does this link to purchase the part I need look legit to you and anyone else?
https://www.bks-tuning.com/7d0711561.html |
Posted: Mon Aug 16, 2021 11:42 am Post subject: Re: New to the world of VW with a 1993 Eurovan with trans issue |
You need to be careful here because the early year vans used a ring to connect to a ball on the shift lever while the later year vans have a hook and hole.
Here is the hook version you listed. Note that it is different than the ring in the 7zap diagram.
https://www.ebay.de/itm/172971343085
Posted: Mon Aug 16, 2021 11:46 am Post subject: Re: New to the world of VW with a 1993 Eurovan with trans issue |
Thanks for that knowledge! |
Posted: Thu Aug 19, 2021 5:18 pm Post subject: Re: New to the world of VW with a 1993 Eurovan with trans issue |
1994Karuso wrote: |
https://www.ebay.de/itm/172971343085 |
Any idea where I can order the "O" connection type along with the gaskets on each end? (Rather than the hook which you noted.)
It's a 1993 VW Euro Weekender.
I really appreciate the information!
-David |
Posted: Thu Aug 19, 2021 9:08 pm Post subject: Re: New to the world of VW with a 1993 Eurovan with trans issue |
The bushings you can order from your local VW dealer.
See around 3:41 mark
https://www.youtube.com/watch?v=XHe2xAh399Y
The metal shaft is NLA AFAIK. Maybe you can find a used one, or have a welder fix the one you have. |
