gokufreak1 Samba Member
Posted: Mon Mar 19, 2012 10:19 pm Post subject: 1971 Squareback Automatic 3rd Gear Problems. HELP!!! |
Hey guys. I'm fairly new to The Samba, and I just purchased a 1971 Volkswagen Squareback automatic Fuel Injected (Air Cooled)
I'm having some problems.
This car is my first car, and I'm eager to learn more about how to operate and service my own vehicle. I just had it tuned up. I believe that only the sparkplugs were replaced, and I think he adjusted the fourth cylinder (I THINK)
The car is definitely a project car, but the main problem right now that I have with it, is the third gear. Here's the basis of my problem:
Shifts into 2nd at around 20-25 and then accelerates to about 30-40 in 2nd, and then I ease up on the throttle to let it shift, and then it shifts into 3rd (here's where my problem is), but if I move the throttle at all while it is in 3rd, it'll just shift right back into 2nd and I am doomed to repeat 3rd falling back into 2nd.
I have no idea how to fix this. Could someone help? I don't know much about engines but I am VERY eager to get my hands dirty. Help |
Tram Samba Socialist
Joined: May 02, 2003 Posts: 22728 Location: Still Feelin' the Bern- Once you've felt it you can't un- feel it.
Posted: Mon Mar 19, 2012 10:26 pm Post subject: |
1. Check fluid level after driving and with engine at full operating temp on a level surface, engine running, trans in P or N, brake on. _________________ Немає виправдання для війни! Я з Україною.
Bryan67 wrote: |
sharkskinman Lateral Lunatic
Joined: April 26, 2006 Posts: 4030 Location: Deep In My Own Psyche
Posted: Tue Mar 20, 2012 12:50 am Post subject: |
check the fluid level at op temp in N
check the final drive hypoid oil and see if there are any ATF in it
check the vacuum module on the trans
take off the hose and see if you have oil in it (common but maybe a couple table spoons)
also see if there is ATF in it
If it has ATF in it then the diaphragm in it is bad and the whole module will need to be changed
NOW.... how far it is threaded in IS ALSO AN ADJUSTMENT
as well as the adjustment IN the module
take the hose off and take a small allen wrench and put it in the module
mark it or Remember where you start and turn it clockwise 1/4 turn
drive it
then see how it shifts
if need be put it back to og then turn it 1/4 turn counter clockwise
make sure the hose from the (plenum (center piece) "F.I." or carb) to the module is secure _________________ 74 Mexi Swamp Thing. 70 square volksrod (Swamp Rat)..65 C10
Me of Course wrote: |
Extremity is relative to how far your willing to jump |
Ward Cleaver wrote: |
You ever try a pink golf ball, Wally? Why, the wind shear alone on a pink golf ball can take the head off a 90-pound midget at over 300 yards |
PS4 "NKOGNEATO" |
KTPhil Samba Member
Posted: Tue Mar 20, 2012 9:57 am Post subject: |
Also check the adjustment of the throttle body kickdown switch. |
Posted: Tue Mar 20, 2012 3:55 pm Post subject: |
Yeah, but check the fluid level FIRST. If the level is not correct, all bets are off on anything else. _________________ Немає виправдання для війни! Я з Україною.
Bryan67 wrote: |
Multi69s Samba Member
Joined: January 24, 2006 Posts: 5364 Location: Lefty, CA
Posted: Wed Mar 21, 2012 2:09 pm Post subject: |
Does anyone have any diagrams of any of this? :O |
Posted: Wed Mar 21, 2012 2:13 pm Post subject: |
And are you referring when you say "you need a Bentley" to the repair manuals? I can't seem to find online where to purchase them. |
Posted: Wed Mar 21, 2012 11:59 pm Post subject: |
Thanks so much guys. I'll post again when I try everything out probably this weekend to report on where I'll be at. |
Mike Fisher Samba Member
Joined: January 30, 2006 Posts: 17970 Location: Eugene, OR
Posted: Thu Mar 22, 2012 6:57 am Post subject: |
VOLKSWAGEN SERVICE MANUAL Type 3 1968 through 1973 by Bentley. www.books4cars.com
Chapter 8 on the AT is very complete for rebuilding even.
The AT is known as the 003 and is a simple old Borg-Warner (USA) design.
www.bulkpart.com has rebuilding kits
If you took it to your local Automatic Transmission Shop with your Bentley for them to See what's what inside, they can fix or rebuild it. _________________ https://imgur.com/user/FisherSquareback/posts
69 FI/AT square Daily Driver
two 57 oval ragtops sold
'68 Karmann Ghia sold
KTPhil Samba Member
Posted: Thu Mar 22, 2012 8:04 pm Post subject: |
Here's the dealio. I want to check with you guys before I do anything screw anything up. The ATF levels are how they are supposed to be and no dice. So if it isn't the ATF, then what could it be? I found a way around it for the time being... I just throw it in "2" until it's to about 50 then I throw it in "D" and it stays in 3rd. |
KTPhil Samba Member
Posted: Thu Mar 22, 2012 8:41 pm Post subject: |
Ummm... check the kickdown switch and use the troubleshooting guide I linked to? |
Slow 1200 Samba Member
Posted: Fri Mar 23, 2012 11:58 am Post subject: |
have you adjusted the bowden cable? maybe your 3 position in the gate is almost 2 in the box |
Posted: Fri Mar 23, 2012 7:24 pm Post subject: |
I am sorry that I keep posting asking questions when you are all clearly answering them. But I drove it again today around 10 miles and here's what I did:
To get it into 3rd and make it accelerate without downshifting back into 2nd, I throw it into 2 and get the car to about 45-48 then throw it into Drive then let up on the throttle and it shifts into 3rd and keeps accelerating. I got it up to 70 before I decided to stop speeding...lol...
So what does this mean? If it CAN go into 3rd and accelerate, why is it only not working when it is in drive? |
Posted: Fri Mar 23, 2012 11:57 pm Post subject: |
try just flooring it
my auto can do 60 in second
im guessing trans adjustment _________________ 74 Mexi Swamp Thing. 70 square volksrod (Swamp Rat)..65 C10
PS4 "NKOGNEATO" |
Absoluteyeti Samba Member
Posted: Sun Jul 12, 2020 10:47 am Post subject: Re: 1971 Squareback Automatic 3rd Gear Problems. HELP!!! |
This old thread had most of the info i needed except i'm seeing some variation with the 70 version. Is "Drive" "3" on the selector? |
Posted: Mon Jul 13, 2020 11:43 am Post subject: Re: 1971 Squareback Automatic 3rd Gear Problems. HELP!!! |
Absoluteyeti wrote: |
Yes. Is your car a Euro? _________________ Немає виправдання для війни! Я з Україною.
Bryan67 wrote: |
