hobbybob517 Samba Member
Joined: June 02, 2011 Posts: 1194 Location: Netherlands
Posted: Tue Mar 20, 2012 1:13 am Post subject: engine tin mystery hole |
what is this hole?
_________________ THE BUILD http://www.thesamba.com/vw/forum/viewtopic.php
SBD wrote: |
3 million rpm? Well there's your problem! No wonder it blew up! |
Joel Samba Member
Joined: September 04, 2006 Posts: 11099 Location: NSW Australia
Posted: Tue Mar 20, 2012 3:32 am Post subject: |
Reverse light wires. _________________ Quick little bug, you got a Porsche motor in that?
1974 Germanlook 1303 2.5 Suba-Beetle |
60ragtop Bonneville Belt Bitch
Joined: March 13, 2006 Posts: 7800 Location: Big Wonderful WYO 82401
Posted: Tue Mar 20, 2012 5:43 am Post subject: |
missing tin,as you can see the push rod tubes from that angle _________________ Rick
Certified Mechanic by the State of Michigan in 1977
ASA certified in 1987
Certified Hunter Wheel Alignment Master Technician 1986
tasb wrote: |
I've restored a large number too, but I don't toot my horn quite as loud.
sb001 wrote: |
maybe he just snapped cause his car sucked |
Posted: Wed Mar 21, 2012 3:32 am Post subject: |
60ragtop wrote: |
missing tin,as you can see the push rod tubes from that angle |
yea i know still building as you can see, i need to put the "sled" tins on. _________________ THE BUILD http://www.thesamba.com/vw/forum/viewtopic.php
SBD wrote: |
Posted: Wed Mar 21, 2012 3:33 am Post subject: |
Joel wrote: |
Reverse light wires. |
thanx, on a 73 super, do these wires connect to the coil? or the trans? _________________ THE BUILD http://www.thesamba.com/vw/forum/viewtopic.php
SBD wrote: |
Glenn Mr. 010
Joined: December 25, 2001 Posts: 76897 Location: Sneaking up behind you
Posted: Wed Mar 21, 2012 3:48 am Post subject: |
hobbybob517 wrote: |
do these wires connect to the coil? or the trans? |
Yes... They get power from the coil and the switch is in the tranny. _________________ Glenn
Member #1009
#BlueSquare |
Posted: Wed Mar 21, 2012 3:50 am Post subject: |
Glenn wrote: |
Yes... They get power from the coil and the switch is in the tranny. |
what colour should the wires be? and does the coil one go on the #1(green) or the #15(black)
what colour is the trans wire, also is there a ground in there? _________________ THE BUILD http://www.thesamba.com/vw/forum/viewtopic.php
SBD wrote: |
Joel Samba Member
Posted: Wed Mar 21, 2012 4:36 am Post subject: |
Its all black and goes to the coil positive.
hook it to the low tension side (green) and you got yourself a kill switch.... that only works in reverse _________________ Quick little bug, you got a Porsche motor in that?
Posted: Wed Mar 21, 2012 5:57 am Post subject: |
thanx, i assume it goes from the light to the trans and then back to the coil? _________________ THE BUILD http://www.thesamba.com/vw/forum/viewtopic.php
SBD wrote: |
ashman40 Samba Member
Joined: February 16, 2007 Posts: 15982 Location: North Florida, USA
Posted: Wed Mar 21, 2012 6:04 am Post subject: |
thanx, i assume it goes from the light to the trans and then back to the coil? |
Positive current flow actually starts from the positive (#15) coil terminal; through an 8A in-line fuse; through that hole to the reverse switch in the nose of the transmission; from the switch back though that hole into the engine compartment; to a Y-splitter; and then on the the L and R reverse lights where they are grounded at the tail light assemblies.
Between this hole and the reverse light switch, both black wires on my car are inside a black sheath/sleeve to keep them together. I'm assuming that was stock. _________________ AshMan40
Posted: Wed Mar 21, 2012 6:11 am Post subject: |
thanx,
i will be fixing that along with the headlight later on. _________________ THE BUILD http://www.thesamba.com/vw/forum/viewtopic.php
SBD wrote: |
zadieman Samba Member
Posted: Wed Mar 21, 2012 11:01 am Post subject: |
How about the rubber grommets that protect the wires going through the firewall. I have three different sizes. I seem to only find one. ANYONE?? |
Posted: Wed Mar 21, 2012 3:48 pm Post subject: |
i think all the holes are 16.5 mm and the grommets are the same for the tail light wires and some holes in behind the dash. _________________ THE BUILD http://www.thesamba.com/vw/forum/viewtopic.php
SBD wrote: |
