Merian Samba Member
Posted: Mon Jan 12, 2015 3:20 pm Post subject: |
is it possible to just use the grilled frame from those Benz's? then you would not need to do the cutting, ring surround, etc. |
wtcumby Samba Member
Joined: September 26, 2010 Posts: 114 Location: PORTLAND
Posted: Fri Feb 27, 2015 11:45 pm Post subject: |
I might be possible. Would you just section out the middle of the van grill? I think all but one of the connection points grill-van are around the lights so there would need to be some customization to connect it all. Give it a whirl and post up some pictures! _________________ I've got the vanagon fever |
randiego Samba Member
Joined: October 13, 2008 Posts: 75 Location: San Diego
Posted: Tue May 19, 2015 9:15 am Post subject: |
Anyone know the part number for this? It would be great to be able to source just the grill piece by itself. _________________ '85 GL, 1.9, 4spd (Sold, we'll miss it)
'89 Carat, Bordeaux Red, 4spd 2.1 |
thatvwbusguy Samba Member
Joined: April 18, 2007 Posts: 1712 Location: Newmarket, New Hampshire
Posted: Tue May 19, 2015 10:22 am Post subject: |
The real SA Grill is only available "grey market" direct from VW of South Africa, so knowing the part number would be of little use.
If there was a cheaper way to bring them into the country, one of the major vendors or someone with deeper pockets than me would be doing it and making big bucks on them _________________ Jay Brown
'85 Zetec Westfalia
Newmarket, NH
If you want others to be happy, practice compassion.
If you want to be happy, practice compassion. |
Posted: Tue May 19, 2015 11:14 am Post subject: |
No, I get that - I'm just interested to know. By the way, I've read all your posts, they are super informative
Anyone know the VW SA part number for this grill? _________________ '85 GL, 1.9, 4spd (Sold, we'll miss it)
thasty07 Samba Member
Posted: Wed Sep 30, 2015 8:22 am Post subject: |
Here is my take! I used 7" LED lights that I got off amazon. They are 81w I believe and they ROCK!
To mount them I didnt have to bend metal like the other setups, simply flipping them upside, I was able to use the stock mounting hardware and run a bolt up through the metal behind the dash and the glove box. Access was fairly simple and I was able to get them in there pretty quick. Only major work that I had to do was to shave down some of the drivers side heat fins on the LED back, due to that extended area on the drivers side. Simple grinder action and it was done in 15 minutes.
Wired into the high beams off a relay, so they are now, always tied into the HB. Which has been so great on the back roads where deer are the number one fear!
RainierSyncro Samba Member
Joined: February 26, 2013 Posts: 809 Location: Seattle
Posted: Wed Sep 30, 2015 10:07 pm Post subject: |
Got a link to those LED lights? |
big swifty Samba Member
Joined: August 21, 2007 Posts: 246 Location: Formally in Republic of VT; now in Hollywood, FL
Posted: Mon Jun 13, 2016 4:13 pm Post subject: Re: Lowbuck SA grille |
A productive Sunday.
_________________ Evan
1987 Vanagon Syncro // Westfalia pop-top graft // Factory new ALH. 11mm IP. AFN 110 RC 2,3,4 // S7 turbo// Titan P502's
2013 Golf 4d TDI. No mods. Yet.
[1991 Jetta coupe TD. Giles Superpump. Custom tall 5 speed. SOLD |
Joined: April 29, 2015 Posts: 704 Location: Berkeley Ca
Posted: Mon Jun 13, 2016 4:37 pm Post subject: Re: Lowbuck SA grille |
^^ looks killer |
Forthwithtx Samba Member
Joined: July 14, 2014 Posts: 717 Location: Fort Worth
Posted: Tue Jun 14, 2016 4:24 am Post subject: Re: Lowbuck SA grille |
This mod may become so commonplace that next owners may believe they were an option. I did mine over a year ago, but never (specifically) posted the results:
Now I need to do something about the foggy insides... _________________ Cheers!
-Karl
'84 GL with 2001/2004 Subaru 2.5L |
jmranger Samba Member
Posted: Tue Jun 14, 2016 6:03 am Post subject: Re: Lowbuck SA grille |
big swifty & Forthwithtx: you both used 6" ceiling lighting rings? |
silverbulletuk Samba Member
Joined: February 02, 2010 Posts: 206 Location: NW Surrey, UK
Posted: Tue Jun 14, 2016 8:09 am Post subject: |
randiego wrote: |
Anyone know the VW SA part number for this grill? |
Twin light grille is 22S 853 641 A It has fixed pins that locate into the headlamp bracket clips
Badge is 701 853 601 F, 125mm, Transporter 1985-2004 _________________ 1986 syncro twin-slider rhd, 3.2S Oettinger wbx6
1990 SA Microbus - Supercharged wbx going in with UN-1 trans.
www.025motorsport.com |
Posted: Tue Jun 14, 2016 3:32 pm Post subject: Re: Lowbuck SA grille |
jmranger wrote: |
Yes. From Home Depot speed shop. I just replicated what Jay (thatvwbusguy) described. I placed my inner lamps more outboard as scobax suggested. I plan on putting some black paint on the adjuster screws. I wired mine as high beams only. _________________ Evan
Posted: Tue Jun 14, 2016 4:43 pm Post subject: Re: Lowbuck SA grille |
^^^ditto all^^^
Except it may have been the Lowe's Performance Center. _________________ Cheers!
-Karl
Slider2 Samba Member
Posted: Thu Dec 22, 2016 3:42 am Post subject: Re: Lowbuck SA grille |
Following this thread (thanks to the originators!) I've had a go too.....
Not finished yet - still have to make the lamp brackets - but so far so good.
Mine uses Mk2 golf gti spotlamps - a complete setup cost me £30 on ebay a few weeks back.
I copied the spotlight rings in solidworks and modelled the grille louvres. The end CAD was then 3d printed in ABS and bonded to the grille with sikoflex pu adhesive.
I've shared the CAD files on grabcad if anyone else wants to have a go.
Personally I don't like the look of the SA grille and I certainly don't like the £260 it costs....
http://grabcad.com/library/vw-t3-t25-vanagon-spotlight-rings-1
I did 18 2d versions of the grille louvre profile to get a fit I was happy with and printed out 7 rings to get the print quality and lamp position where I think it looks best! |
unibagel Samba Member
Joined: December 02, 2004 Posts: 529 Location: Bflo, NY
Posted: Thu Dec 22, 2016 5:14 am Post subject: Re: Lowbuck SA grille |
Well done Slider2!! |
jacobh Samba Member
Joined: April 06, 2014 Posts: 21 Location: The Netherlands
Posted: Thu Dec 22, 2016 7:27 am Post subject: Re: Lowbuck SA grille |
Wauw!....
This is very nice. Thank you for sharing.
Jacob |
kryptkat Samba Member
Posted: Thu Dec 22, 2016 10:06 am Post subject: Re: Lowbuck SA grille |
I made mine out of sheet metal.
ohhorob Samba Member
Joined: September 26, 2013 Posts: 212 Location: Santa Cruz
Posted: Thu Dec 22, 2016 10:11 am Post subject: Re: Lowbuck SA grille |
Slider2 wrote: |
... 3d printed in ABS ... |
Keep an eye on the raw ABS printed part.. folks report deterioration with prolonged exposure to UV light, although black ABS is apparently more stable.
Some filament manufacturers (Taulman3d) recommend painting the printed part with something UV stable. Otherwise there seems to be a few filament options with better UV tolerance. _________________ "Gundy" - '85 Westfalia
GoWesty 2300cc, Digijet |
