vaughn bros. Samba Member
Joined: October 13, 2003 Posts: 2395 Location: Hickory, NC
Posted: Tue Mar 20, 2012 8:38 pm Post subject: kinda Bullet Proof 1776 build, Thanks if you can help. |
I am going to build my brother a 1776. I have never built anything above 1641 but I know how to measure and get shit right.
I looked at older post and want to put together a very nice engine.
The only requirements would be the 100 mile round trips to the Farmington Bug Bash(and all that implies) and 5 miles to work. I'm starting with nothing. It will all be store bought. Vehicle is early Type I. Most likely a fresh recommended config trans (swing).
My brother wants 36 HP shroud. He wants vintage valve covers. He wants dual 48's but may be too big. But I am the builder so he gets what I give him.
I've heard and read to start with:
China frowned upon
DPR Crank
UDO Lifters
best case? AS41,Auto Linea, someones bubble top?
best heads? Mofoco, Aircooled.net, Sir Berg?
best about everything else.
...the rest of the parts are always argued about. Its all based on what I can get my hands on during the next 4-8 months(machined parts may be slow). Thanks in advance if you add your 2 cents worth. I would like to base this build on what happens on this thread. I also apologize for another damn 1776 thread. Andy. |
66brm Samba Member
Joined: January 25, 2010 Posts: 3676 Location: Perth Western Australia
Posted: Tue Mar 20, 2012 9:00 pm Post subject: |
I'll have a stab at it, AS41 case drilled and tapped for full flow, agree on the crank, get a set of stock rods with upgraded bolts, mahle forged P&C's, cam.......Engle W110 with Engle lifters, DRD L3 heads with match ported intakes, 1.25 rockers, DRLA 36 or 40's,1 1/2 merged headers (with heat if he cry's) compression 8.5:1, ACNets hd alu pushrods,Bosch 019 distributor, german blue coil, berg linkage, 26mm oil pump, all the german tins except for the 36 style shroud.
Get a Scat shroud from Awesome powder coat set up for using the stock thermostat flaps _________________ Aust. RHD 66 Type 1
Aust. RHD 57 Type 1 Oval
modok wrote: |
I am an expert at fitting things in holes, been doing it a long time |
Posted: Tue Mar 20, 2012 9:14 pm Post subject: |
66brm wrote: |
Get a Scat shroud from Awesome powder coat set up for using the stock thermostat flaps |
Thank you. No heat required. 10-4 on the shroud and stat. Any flywheel suggestions? Who's 1.25:1 rockers? Cam / Crank gears? Bearings? Would you get a Berg prepped AS41 case? Maybe Glenn will part with a 019. Thanks again. |
jfats808 Samba Member
Joined: December 10, 2007 Posts: 5022 Location: oahu hawaii
Posted: Tue Mar 20, 2012 9:15 pm Post subject: |
I just built a 1776 for a customer last October. He drives it about 75-80 miles a day and I couldnt get him to drive it nice for the first 500. He drives it all over the place. Steve Tims stage 1 40x35 match ported to 40 dells, cbperf straightcuts, Scat c45 cam, Bugpack forged 1.25s, manton lifters, rebuilt stock rods, AA 90.5s, 69mm dpr crank, scat lifters, melling oil pump, ss braided full flow set up, 1.5 deep dump, @ 9.2 cr. He requested a longblock broken in by me and wanted to put together the top half himself. Crated the block and dialed his carbs and he drives it everywhere .....fast.
C45 is close to a w120. That would be a nice build for u imo and his. Lol. _________________ 2276 IDA's 86C 11-1 DD !
2017 48 Trijet DRLA's W125
Rockstar Suzuki wrote: |
You might as well put 10 year build in your bullshit sig, as it will NEVER run. Also your a dick |
You can always learn something new, even from a fool.
Check your oil levels routinely! |
Posted: Tue Mar 20, 2012 9:24 pm Post subject: |
jfats808 wrote: |
C45 is close to a w120. That would be a nice build for u imo and his. Lol. |
The Steve Tims Heads were highly recommended on most 1776 build post. I'm kinda on the fence over CR. I don't know whats best either lower or higher? |
Posted: Tue Mar 20, 2012 9:30 pm Post subject: |
Also, do you let the head supplier also mate your P&C's? Does the case supplier need to see the heads and P&C's? Is there a common group of parts that need to matched instead of everything coming from all directions? |
Posted: Tue Mar 20, 2012 9:34 pm Post subject: |
What type of wrist pin retainers are favored nowadays? Spiral? |
modok Samba Member
Joined: October 30, 2009 Posts: 26781 Location: Colorado Springs
Posted: Tue Mar 20, 2012 9:41 pm Post subject: |
Get crank, flywheel AND rods from DPR, balanced
Having done this, any clips will work, the stock ones or tru-arc, you need a lot of RPMS and/or crappy parts to unhook the clips, you should have neither problem |
Posted: Tue Mar 20, 2012 9:46 pm Post subject: |
modok wrote: |
Thanks Modok. This sounds perfect and that's what I will do. This issue is settled. |
Posted: Tue Mar 20, 2012 10:54 pm Post subject: |
Buying the rods crank and flywheel from dpr as a set is great advice. I had the rods already but did get the crank and lightened flywheel from Jose. The cr has to be determined by cam, head choice and driving intent. Basically your combo. _________________ 2276 IDA's 86C 11-1 DD !
