andrewtf Samba Member
Joined: August 10, 2011 Posts: 602 Location: Illinois
Posted: Wed Mar 21, 2012 1:34 pm Post subject: hydraulic lifter source? |
My engine has three bad Hydraulic lifters - they will not pump up with the oil pressure. Is there a source for new or replacement ones? And are they the same on a 1.8L and 2L engine? Thanks in advance. |
borninabus Samba R&D Dept.
Joined: May 18, 2006 Posts: 4538 Location: Arizona Highways
Posted: Wed Mar 21, 2012 1:47 pm Post subject: |
there are many sources for hyd lifters...
1.8s were solid lifters from the factory
only 78-83 T4s were hydraulic. _________________ 88 Van WBX, A/T - 13 JSW TDI 6M/T - 2012 Touareg TDI Sport |
tootype2crazy Samba Member
Joined: October 08, 2007 Posts: 1276 Location: St. Louis Missouri
Posted: Wed Mar 21, 2012 3:28 pm Post subject: |
You might try reading ratwell's info on hydraulic lifters. He has some info on getting them to pump, such as changing the oil two times in a small time frame. Cleanliness of the oil system is the primary issue with them, so some kind of case clean out and thicker oil could get them to pump. Also if the bus has been sitting a long time it could take 30 mins of running to get them to pump. Alternatively, you could take them out and pump them yourself. _________________ air-cooled or nothing for me
1978 Sunroof Deluxe Bus (daily driver)
1978 Transporter (mom's, making into a camper)
1970 Single Cab 2.1 turbo/EFI 6 Rib, 78 front beam, vanagon backing plates on rear (project)
2001 GTI VR6 (wife's) |
old DKP driver Samba Member
Joined: March 30, 2005 Posts: 4145 Location: Los Gatos,Ca.
Posted: Wed Mar 21, 2012 5:55 pm Post subject: hyd lifters |
AsTooType2 suggested,Fix the 3 that are bleeding down and
keep the oil clean. or you may need a whole set of lifters
to go with that new camshaft you will need when it goes Flat.
camshaft and lifter hardness vary from vendor to vendor. _________________ V.W.owner since 1967 |
busdaddy Samba Member
Joined: February 12, 2004 Posts: 51144 Location: Surrey B.C. Canada, but thinking of Ukraine
Posted: Wed Mar 21, 2012 5:59 pm Post subject: |
Adjusting the offending lifters to zero lash for a short while sometimes fixes them as well, use a tiny bit of preload on them like 1/8 turn so you don't pound the circlips out. _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
