'66 Project build on a budget of budgets
Page: Previous  1, 2, 3, 4, 5, 6, 7, 8, 9
sportin-wood
sportin-wood is offline
PostPosted: Sat Nov 12, 2016 8:05 pm    Post subject: Re: '66 Project build on a budget of budgets Reply with quote
6 months later and a little progress update. Had the passenger side front bumper mount, 3 fender weld nuts and front apron welded in place. It's not pretty looking, but the slag is being ground smooth with a flap disk, then coated with some rattle can primer,
Click here to see my 66 project bug.
"Relax, all right? My old man is a television repairman, he's got this ultimate set of tools. I can fix it." --- Jeff Spicoli
EA812
EA812 is offline
PostPosted: Sun Nov 13, 2016 7:16 am    Post subject: Re: '66 Project build on a budget of budgets Reply with quote
I hate to point this out but all that rust and paint had an effect on them wields.
Project 66 Daily Driver http://www.thesamba.com/vw/forum/viewtopic.php?t=538786&highlight=
Herbie build
http://www.thesamba.com/vw/forum/viewtopic.php?t=336044
sportin-wood
PostPosted: Mon Dec 26, 2016 9:58 pm    Post subject: Re: '66 Project build on a budget of budgets Reply with quote
Actually, there isn't much rust, if any, in the welded area. I have a crappy MIG welder that my buddy was using to weld with. The wire feed wasn't working right, and the intensity setting didn't seem to be working. But the welds are holding really good, which I'm happy about.
I took a few minutes to heat the door and quarter sound deadening tar boards with a propane torch, and they came off like butter.
Before
After
The sticky residue came completely off, but left a brown staining, which will be sanded, painted, and covered with new sound deadening anyway.
sportin-wood
PostPosted: Tue Aug 29, 2017 7:51 pm    Post subject: Re: '66 Project build on a budget of budgets Reply with quote
Took advantage of nice North Central Texas weather and had a buddy weld up my rear bumper mounts.
I also had a fender nut welded in place on the driver's side front fender area as well as a flange nut for the driver's side headlight bucket, but I made the mistake of trying to run a screw through the nut, not realizing there was some slag splatter on the threads that eventually caused the screw to bind and subsequently snap off. [email protected]!! Next step is to try drilling out the screw without srewing it up completely....
sportin-wood
PostPosted: Sun Oct 29, 2017 7:31 am    Post subject: Re: '66 Project build on a budget of budgets Reply with quote
Enlisted the help of a couple of guys from work to lift the body off the body dolly, and onto the chassis.
It's nice to see it as 1 piece again - it's been a long time.
Bala
Bala is offline
PostPosted: Tue Oct 09, 2018 7:48 am    Post subject: Re: '66 Project build on a budget of budgets Reply with quote
Just went through you're entire thread. We have a very similar approach to our projects. Very Happy
Any updates?
1976 Westy
1966 Beetle
sportin-wood
PostPosted: Tue Oct 09, 2018 8:44 am    Post subject: Re: '66 Project build on a budget of budgets Reply with quote
Man, I am at a stand still! Iím actually at a point where I need to get body work & paint done. Then the reassembly starts. Funds have just not been available, but Iím hoping to get it painted soon. Kinda wish I had the option of getting body work & paint done when the body was off the chassis, but it wasnít an option...
Page 9 of 9
