dhaavers Samba Member
Joined: March 19, 2010 Posts: 7756 Location: NE MN (tinyurl.com/dhaaverslocation)
Posted: Fri Feb 23, 2018 10:01 pm Post subject: Re: What PORTABLE fridge do you use? |
Interesting - looks to be close relative of the budget priced "SMAD" & "Outsunny" found here on eBay...???
Evacool (OZ website DOES specify DANFOSS BD35-F compressor):
SMAD (FWIW - unit in one picture is labled "DELLA"):
https://www.ebay.com/itm/Smad-1-0-1-7-cu-ft-Truck-...riwx26Dhsw
Outsunny (no longer available...???):
https://www.ebay.com/itm/Outsunny-42QT-Portable-Mi...7675.l2557
Truly worth a look, >>>IF<<< if fact using a Danfoss compressor...???
- Dave
(Yes - I'm fridge shopping on a budget...) _________________ 86 White Wolfsburg Westy Weekender
"The WonderVan"
shagginwagon83 Samba Member
Joined: February 07, 2016 Posts: 3800 Location: VA/TN
Posted: Sun Feb 25, 2018 12:44 pm Post subject: Re: What PORTABLE fridge do you use? |
Those with the Westy interiors. How did you power your fridge? I now have a fuse panel under the sink...But confused where to put a power outlet. I could also hardwire if but I think a 12v outlet would be best. _________________ Brandon
Instagram @joannthevan |
kamzcab86 Samba Moderator
Posted: Sun Feb 25, 2018 1:01 pm Post subject: Re: What PORTABLE fridge do you use? |
shagginwagon83 wrote: |
Those with the Westy interiors. How did you power your fridge? I now have a fuse panel under the sink...But confused where to put a power outlet. I could also hardwire if but I think a 12v outlet would be best. |
I cut the 12V plug off and hard-wired my ARB (which ARB says is okay to do, provided it's fused) to a Blue Seas fuse panel under the sink. It's also plugged into the 110V outlet in the cabinet.
If you plan to use the fridge in other vehicles, then keeping the plug is wise. _________________ ~Kamz
2016 Golf GTI S
Posted: Fri Mar 16, 2018 10:33 am Post subject: Re: What PORTABLE fridge do you use? |
OK...my turn to play...I finally jumped in on this budget-friendly $400 "brand-name-but-Chinese" unit...OEM!!! (FWIW)
https://www.pplmotorhomes.com/parts/rv-appliances/...ge_CC-40US
Currently on Amazon & elsewhere for $500 but had recently been as low as $343 before spring price jump... <shrug>
Full 40-quart, 23" wide footprint, fold-out-of-the-way handles <only one year warranty> but that's
all I was going to get in my price range anyway... Online reviews are sparse but very good.
Arrived beautifully - triple boxed (!!!) & powered up perfectly. I filled it with beverage cans/bottles
& ran it for a week on house power to get a feel for controls, basic operation, temp settings, etc...
The interior temp. readout is not particularly accurate (shows about 7°F lower than actual)
but I've verified that setting @ 30°F gives me actual minimum of 35°F (min @ bottom of
compartment just after compressor turns off) to max of 40°F (max @ top of compartment
just before compressor turns on). This is a range I'm comfortable with & I also have a small
wireless thermometer to monitor actual interior temps, so...
TODAY...I started the "real world" test (similar to djkeev on p.5 of this thread)
- everything set up out of the sun in our ~65°F interior entryway...
- fridge ~80% full with beverage containers, pre-chilled to operating temp...
- connected to my relatively new (6/17) Group 24 deep cycle battery,
. . . rated "690 Marine cranking amps" & "101 ah @ 1a"...
- battery cut-out on fridge set to LOW (10.1v cut out/11.1 in)...
- monitoring time, temp, voltage etc. for duration of battery capacity...
So far, so far...I'll keep you posted!
- Dave _________________ 86 White Wolfsburg Westy Weekender
"The WonderVan"
Posted: Fri Mar 23, 2018 8:25 am Post subject: Re: What PORTABLE fridge do you use? |
Well, consider me impressed! ...and/or very lucky...???
This morning I just hit the 1-week mark on my "best case scenario" test with the Dometic CC-40 (above)
running solo on 12v and...only just this morning finally dipped below 12.2 volts! Kept consistent temps
the whole time, swinging no more than 2°F above/below set temp of 37°F. Love it!
I don't know if that means by fridge is awesome, or the battery or BOTH!
This weekend I'll recharge the battery & start one final "workout" test, pulling cold beverages
out all week & replacing with warm (room temp) cans. I'll keep all y'all posted!
"The WonderVan"
Posted: Mon Apr 02, 2018 7:17 pm Post subject: Re: What PORTABLE fridge do you use? |
Quick update on the cheap Dometic: ran all week & just got below 12.0 volts on the 8th
day (today)...not even close to the HIGH battery cutoff. The thing runs quietly & seems
to work great! It feels like I should be happy with this...anyone else have an opinion?
I may yet go full geek & put it on the meter to check the actual amp draw...
Cheers!
"The WonderVan"
jackbombay Samba Member
Joined: October 19, 2007 Posts: 2723 Location: Eastern Idaho
Posted: Mon Apr 02, 2018 8:30 pm Post subject: Re: What PORTABLE fridge do you use? |
dhaavers wrote: |
day (today)... |
I'd say that is amazing!
How many AH is the battery? _________________
Gas struts to pop your top easily!
Pop Top strut kits now available for late Bay window Westies
Samba ad here.
DIY artificial rain gutters (ARGs) |
jimf909 Samba Member
Posted: Mon Apr 02, 2018 8:41 pm Post subject: Re: What PORTABLE fridge do you use? |
dhaavers wrote: |
- Dave |
I love science. I hope some additional good from cooling all those cans. _________________ - Jim
Abscate wrote: |
Posted: Mon Apr 02, 2018 8:47 pm Post subject: Re: What PORTABLE fridge do you use? |
jackbombay wrote: |
dhaavers wrote: |
day (today)... |
How many AH is the battery? |
This may be the answer, from the 3/16 post...
- battery cut-out on fridge set to LOW (10.1v cut out/11.1 in)... _________________ - Jim
Abscate wrote: |
Posted: Mon Apr 02, 2018 8:51 pm Post subject: Re: What PORTABLE fridge do you use? |
Indeed!
"The WonderVan"
Posted: Mon Apr 02, 2018 8:53 pm Post subject: Re: What PORTABLE fridge do you use? |
jimf909 wrote: |
- battery cut-out on fridge set to LOW (10.1v cut out/11.1 in)... |
Ah, well, 8 days on ~50 AH is 6.25 AH per day, impressive for sure! _________________
Samba ad here.
E1 Samba Member
Joined: January 21, 2013 Posts: 6556 Location: Westfalia, Earth
Posted: Mon Apr 02, 2018 9:09 pm Post subject: Re: What PORTABLE fridge do you use? |
Looks good Dave, Thanks for the info! _________________ ‘84 Westy, 2.1L with Digijet, 5.43 R+P, GT Gears
— Colin Chapman |
Posted: Tue Apr 03, 2018 4:12 am Post subject: Re: What PORTABLE fridge do you use? |
jackbombay wrote: |
...8 days on ~50 AH is 6.25 AH per day, impressive for sure! |
I was surprised enough I found it hard to believe & questioned my results... Thanks for the 2nd opinion!
Watch for update after I charge up the battery again & check the actual current draw...
"The WonderVan"
Abscate Samba Member
Joined: October 05, 2014 Posts: 22668 Location: NYC/Upstate/ROW
Posted: Tue Apr 03, 2018 4:24 am Post subject: Re: What PORTABLE fridge do you use? |
Is Dometic really buildingstuff in China now, instead of Ohio
_________________ .ssS! |
Posted: Tue Apr 03, 2018 4:28 am Post subject: Re: What PORTABLE fridge do you use? |
^^^ I don't know about everything, but this unit was clearly labeled "China"...
<shrug>
"The WonderVan"
djkeev Samba Moderator
Joined: September 30, 2007 Posts: 32625 Location: Reading Pennsylvania
dobryan Samba Member
Joined: March 24, 2006 Posts: 16504 Location: Brookeville, MD
Posted: Tue Apr 03, 2018 5:30 am Post subject: Re: What PORTABLE fridge do you use? |
I'm not a huge fan of the location of the power cords for that Dometic. Crazy efficient though. That being said - I'm going to probably downgrade my Dometic 75 dual zone to a Dometic 50 single zone. I don't need the second zone. _________________ Brandon
Posted: Tue Apr 03, 2018 5:05 pm Post subject: Re: What PORTABLE fridge do you use? |
dobryan wrote: |
...real world use in the Vanagon will not be as good since it will get hotter inside the bus, sun effects, opening it several times a day, etc. But it sounds like it should do well for you regardless. |
Granted. Hence, the plan to wrap in ~3 layers Reflectix for a DIY insulated cover. It will also stand on rollers ~1"
off the floor with additional foam insulation to mitigate heat soak from pavement/floor/coolant hoses beneath...
Anyway...Thanks, guys!
"The WonderVan"
Posted: Fri Apr 06, 2018 10:13 am Post subject: Re: What PORTABLE fridge do you use? |
Sold my big fridge. The Dometic CFX75 dual zone - I don't need dual zone. I think I'm now going to try the Dometic CFX50 out. I just don't like the looks of the ARB. _________________ Brandon
