64 rusty bus project
Page: 1, 2, 3, 4, 5  Next
demon1018
demon1018 is offline
PostPosted: Sun Apr 01, 2012 6:20 pm    Post subject: 64 rusty bus project Reply with quote
thought id start posting pics of my bus . ive been working on lowering it since i got it . i put a bug irs in the rear that im going to us hydraulics to adjust the spring plates . havent got that far yet though. went through a few ideas for the front and finally came up with this . its not done. still gona beef it up ,close up the hole in the middle of the tube and such but got it in the bus today and it works great. im using hydraulics to turn the torsion leaves.
i narrowed the beam 2" and put about 7degrees caster in it . the cylinders are the same ones the lowrider guys use to hop there impallas but i cut them down so i have only 3 " of stroke . i used 2 cylinders because to shifter rod has to go thru the center of the beam and i plane on using a rack and pinion steering so that will go thru the center as well. still some work to go but just wanted to share this . here are some pics of my bus. yes those are bullit holes in the windows.
Culito
11010101
Culito is offline
PostPosted: Sun Apr 01, 2012 7:39 pm    Post subject: Reply with quote
Nice!
I'd be interested in seeing how you did the hydraulics for the rear suspension.
© CJ Industries, Inc.
'64 standard w/2.0L type 4
'62 bug
johnnypan wrote:
G-wood Todd
G-wood Todd is offline
PostPosted: Sun Apr 01, 2012 7:46 pm    Post subject: Reply with quote
Nice work on that beam. That bus definitely has some attitude.
campingbox Premium Member
campingbox is offline
PostPosted: Sun Apr 01, 2012 7:56 pm    Post subject: Reply with quote
Sweet. I love me some hydro's.
You should stack cinder blocks in the rear corners so you can drive on three wheels.
Busryder
Samba SuperHero
Busryder is offline
PostPosted: Sun Apr 01, 2012 8:36 pm    Post subject: Reply with quote
Now when do the Hot Chick's come in?? Very Happy
Lind wrote:
Apparently I was just the lucky asshole that showed up at the right time.
I am a Dick, hear me roar- Laughing
Me, an OVP Lifer...
PostPosted: Sun Apr 01, 2012 9:49 pm    Post subject: Reply with quote
Now when do the Hot Chick's come in?? :D
Wow, that is incredible. Did something break?
Tyler 5447
Tyler 5447 is offline
PostPosted: Sun Apr 01, 2012 9:57 pm    Post subject: Reply with quote
If that was a limiting chain by the right rear wheel, I don't think it was doing its job.
demon1018
PostPosted: Mon Apr 02, 2012 3:53 am    Post subject: Reply with quote
Sorry , it won't three wheel. I live down a dirt road. I just need it to come up so that I can get to the pavment . The 2 cyl are connected. They act as one.
demon1018
PostPosted: Mon Apr 02, 2012 5:17 pm    Post subject: Reply with quote
anybody ever try this? i flipped them then cut the spindle off and moved it 2" higher
EmpiGT
EmpiGT is offline
PostPosted: Mon Apr 02, 2012 5:29 pm    Post subject: Reply with quote
How are you going to mount the backing plates? or brake calipers if you are going disc brakes?
demon1018
PostPosted: Mon Apr 02, 2012 5:56 pm    Post subject: Reply with quote
im using mustang 2 rotors. i found the bearing part #s here on the samba so they slide right on the spindles . they needed a spacer made that slides on the spindle first before the inner bearing .the seal rides on the spacer so i didnt need to worry about the orginal place the seal rode on . i have corvette calipers that i want to use cause i have them Very Happy . the rears will be no prob but the front a little more difficult. mainly because of the 14" wheels but I like the wheels
demon1018
PostPosted: Mon Apr 02, 2012 7:06 pm    Post subject: Reply with quote
heres a video of my first test of the front end. it doesnt have the new spindles on yet . thats tommorrow . i dont think ill be able to see it work to well after that . the bumper should touch the ground. still need flow controls to slow it down when it comes down.
http://www.youtube.com/watch?v=Xk29DP6bUoY
GLHTurbo
GLHTurbo is offline
PostPosted: Mon Apr 02, 2012 8:03 pm    Post subject: Reply with quote
sounds menacing!
1957 Beetle
1966 Bus
61TXghia
61TXghia is offline
PostPosted: Mon Apr 02, 2012 8:07 pm    Post subject: Reply with quote
did you film it from the front, I bet i looks sick going up and down.
62 Standard Type 2 (Nothing Fancy)
my bus: http://www.thesamba.com/vw/forum/viewtopic.php?t=464719
bill may wrote:
Camping is cheaper than therapy.
demon1018
PostPosted: Tue Apr 03, 2012 3:12 am    Post subject: Reply with quote
I'll film it from the front tonight after I put the spindles back on
demon1018
PostPosted: Tue Apr 03, 2012 5:19 pm    Post subject: Reply with quote
i put the spindles back on tonight . it looks perfect. in the first pics i posted the front tires touched the front of the wheel well. that is what stopped it from going down any more but with the new spindles the bumper touches the ground and there is about 1/4" between the tire and foward wheel well. I love it!
demon1018
PostPosted: Tue Apr 03, 2012 5:28 pm    Post subject: Reply with quote
http://www.youtube.com/watch?v=v8oIQrXe0xI
hers a video of the front workin
demon1018
PostPosted: Tue Apr 03, 2012 5:36 pm    Post subject: Reply with quote
and another
http://www.youtube.com/watch?v=-WNqW8iHT7w
ratherb-buggin
ratherb-buggin is online now
PostPosted: Tue Apr 03, 2012 7:38 pm    Post subject: Reply with quote
Cool videos! Seems like a cool idea!
61TXghia
61TXghia is offline
PostPosted: Tue Apr 03, 2012 9:30 pm    Post subject: Reply with quote
In the event of a hydraulic failure, will it dump to the ground? What does that do to the inside of the beam? It looks crazy man. I like it.
Page 1 of 5
