What is the coolest bay window option/accessory? |
Ambulance fan(S) |
20% |
[ 16 ] |
Rack |
13% |
[ 11 ] |
Dash Clock |
25% |
[ 20 ] |
Gas Heater |
41% |
[ 33 ] |
Total Votes : 80 |
ratwell Samba Member
Joined: April 26, 2003 Posts: 8717 Location: Victoria, BC
Posted: Wed Aug 20, 2003 8:05 pm Post subject: |
Sorry,
I guess the clock missing the red second hand, along with the fuel gauge and overall glare through me off. The older style trip speedo looks like this.
In my original post I didn't mean the black one didn't exist, just that I'd never seen one. _________________ '78 Westfalia CDN
'76 Doublecab
Read the Baywindow FAQ
notsobigkahuna Samba Member
Joined: February 11, 2002 Posts: 464 Location: Sandbanks Ont. Canada
Posted: Thu Aug 21, 2003 6:32 am Post subject: bus option |
i'm not sure, but i believe there is a guy in my group with a MINT sage 78 westy from CA , he has a balck face speedo with trip.
also i once read that in europe you could get a water heater for an air cooled bus - hot shower! |
spectral method Samba Member
Joined: August 19, 2003 Posts: 37 Location: Melbourne, Australia.
Posted: Thu Aug 21, 2003 8:13 am Post subject: |
What about those petrol burning high flow auxiliary heating unit? I know they sound dangerous, but if they operate anything like the butane burning things you see used to heat marquees, even my girlfriend would be warmed up enough to get her gear off.... and we all know that THAT is really the best accessory of all... |
Posted: Sat Aug 30, 2003 11:55 am Post subject: |
I hate to dig up this old debate about the color of the speedo but there are 3 speedos like I implied in my earlier messages. Forgetting about the trip varieties, there exists...
- 68-72 speedo with grey disk in the center
- 73-74 speedo with greyish face and no disk
- 75-79 speedo with black face
I'm not 100% positive when the faces changed but the tip off is that the screws that hold the face on are silver instead of black and the needle is elongated and obviously different. _________________ '78 Westfalia CDN
'76 Doublecab
Read the Baywindow FAQ |
psteve Samba Member
Posted: Mon Sep 01, 2003 12:06 pm Post subject: speedometer |
Here is the speedometer I made from Scirocco parts and my 71. It matches the clock that I made from a Squareback clock.
Bajatacoma Samba Member
Joined: August 05, 2003 Posts: 675 Location: the Great State of Denial
Posted: Mon Sep 01, 2003 6:48 pm Post subject: |
Alright, explain how you made a speedo from Scirocco parts- that is too cool! _________________ '78 Westy
Who is the happier man, he who has braved the storm of life and lived or he who has stayed securely on shore and merely existed?
Hunter S Thompson |
chabanais Samba Member
Posted: Mon Sep 01, 2003 8:38 pm Post subject: |
I am very impressed by your trip speedo. That is the best replica I've seen. The only way to tell it's not real is the numbers or a different font. You should make those and sell them. How did you cut out the trip numbers?
Very nice indeed. _________________ "I spud therefore I yam." |
Chris181Westy Samba Member
Joined: August 05, 2003 Posts: 148 Location: Michigan, The Third Coast!
Posted: Mon Sep 01, 2003 9:04 pm Post subject: |
I had those white spoke Wolfsberg hubcaps on my 71 Westy. I wanted to keep the hubcaps before I sold it but the rims looked like hell underneath. Those are near impossible to find! |
psteve Samba Member
Posted: Mon Sep 01, 2003 10:32 pm Post subject: Speedometer |
Don't know what year the Scirocco was, the part # was 811520272. It is a plastic piece with the mile and trip mile wheels mounted in it. My face
plate mounted right to it with the 2 chrome screws so that was easy. I used my 71 mechanical part and mounted it to the plastic piece with 3 new holes I had to drill. The reset button was the wrong angle so I made a spacer and glued that to it to make it stick straight out. The lens is plexy glass, I could not drill a hole in the original glass. There is speed pointer return spring for calibrating the needle. Before I took the speedometer apart I hooked it up to my cordless drill, the 1st click I think around 27 mph and the 2nd was around 43 mph, the electric drill was 91 mph. I adjusted the spring accordingly. The hard part was cutting the holes in the front using the face plate from the Scirocco as a template. I scroll sawed the holes close to the size then used a small file to finish them. I used some gray touchup paint my wife had for the edges and repainted the needle white to match the clock. Psteve |
JDawg Samba Member
Posted: Mon Sep 01, 2003 11:00 pm Post subject: |
That's impressive work! Like chabanais said, you should market those. |
Airsick Samba Lowering Squad
Posted: Tue Sep 02, 2003 5:05 pm Post subject: |
I like the bud pipes and j's found when restoring one! |
BigElipso Samba Member
Joined: May 19, 2003 Posts: 289 Location: West Michigan
Posted: Wed Sep 03, 2003 2:00 pm Post subject: |
Coolest option would be an engine. Sure wish I had one in mine.....
BTW I found the wickedest bong in a bus I was stripping down last year. I'm almost afraid of it. |
VWMIKE76 Samba Member
Joined: February 21, 2006 Posts: 669 Location: lynnwood, washington
Posted: Mon May 03, 2010 8:08 pm Post subject: |
bump _________________ Mike
77 westy Mac n cheese aka "Mac"
71 crew cab "Damien" sold and missed lots!
78 westy "Doc". in very good hands of a fellow samba member!
79 hardtop landmark "Shaggy II" |
Stuartzickefoose Samba Post Whore
Joined: February 07, 2008 Posts: 10350 Location: SoCal for now...
Posted: Mon May 03, 2010 8:33 pm Post subject: |
my bus has the chrome door covers on it, factory. although the PM (previous moron) did a shitty pait job and managed to hit nearly every piece of chrome and the pop top on the car...grr...
also have the rear hatch net and all the original curtains...
_________________ Stuart Zickefoose
206-841-7324
[email protected] |
ratherb-buggin Samba Member
Joined: January 30, 2005 Posts: 986 Location: Shawnee, KS
Posted: Mon May 03, 2010 9:29 pm Post subject: |
Racks always complete the overall look, I have yet to have a clock that actually kept time/worked correctly, ambulance fans are cool but kinda noisy, gas heaters... well... who doesn't love heat... in a VW! One of my favorites for bays are the factory jail bars, deluxe bumper trim and a BERG SHIFTER!! Gotta love the Berg baby, no more sloppy seconds.. thirds or fourths! Most of all SLOPPY FIRSTS!!
Keep on Truckin! Bays rule! |
norcalmike Samba Member
Joined: May 14, 2005 Posts: 4784 Location: Marina, CA
Posted: Mon May 03, 2010 11:15 pm Post subject: |
having experienced the joy of gas heat, i declare that the winner |
bigbore Samba Member
Joined: December 19, 2003 Posts: 3297 Location: Wasilla Alaska
Posted: Tue May 04, 2010 12:09 am Post subject: |
I think this roof drawer in my 71 westy is pretty cool. Some people here was calling BS (Iam sure some still do) but if it were homemade someone went to alot of trouble to get the right wood make the right joints and use the right nails and for what? then a guy in England posted he also has one of these drawers.
_________________ where its cold and snowy |
nezz Samba Member
Joined: January 13, 2006 Posts: 412 Location: Coimbra-Portugal
Posted: Tue May 04, 2010 12:14 am Post subject: |
the coolest one has to be the km you put into the bus and the experiences/stories that come along
and a pet...
the one in my bus I like a lot is the front bench seat. another one, hard to find in Portugal, is the early dash clock |
Mr. Loaf Samba Member
Joined: March 30, 2005 Posts: 2098 Location: Okra, Oklahoma
Posted: Tue May 04, 2010 4:29 am Post subject: |
I never thought it was that cool but a lot of woman would vote for the Z-bed! _________________ Never drive faster than your Angel can fly
$24,100 was too hard to resist................. |
Desertbusman Samba Member
Posted: Tue May 04, 2010 5:00 am Post subject: |
Mr. Loaf wrote: |
I never thought it was that cool but a lot of woman would vote for the Z-bed! |
At a show last Saturday some woman was checking mine over real carefully and got all the more excited with pics of the rear extended sleeper and the extra room. Then she asked if it had a toilet. I said yes, a 5 gallon bucket with a toilet seat. She got a frown and left before I could tell her the bucket goes in a pop-up privacy shelter that also has a solar shower. _________________ 71 Superbug
71 Westy |
